Question about Philips Magnavox MWR10D6 DVD Recorder
DVD recorder: Changed the settings, now
I have a huge problem, I changed the settings to my dvd recorder and now I get a black screen on the TV (a Samsung 40" LCD HD) that says "no signal". The dvd recorder model isn't exactly the one chosen, it was the closest model to mine (MAGNAVOX MDVDRW 160GB) it has a 160gb hard drive, not a combo unit.
As a result, I cannot get the mode screen at all, so I can't change the settings back.
The setting I changed was in the video preferences settings. I changed from "INTERLACED" to "PROGRESSIVE SCAN" mode. The manual states -
"If you have a standard tv, you will need to set the dvd recorder to INTERLACED mode. If your tv supports progressive scan, make sure the dvd recorder is connected to the tv using a component video cable (it is) and set to PROGRESSIVE mode. Please refer to the progressive scan setting of your tv instructions manual."
I cannot find anything in the tv insructions manual referring to progressive scan and I'm unable to change the setting back to interlaced, where the dvd recorder worked fine.
I live in Australia and both items were purchased in Aust (I'm not sure if this will make a difference to you).
I am desperate to have my dvd operational again, any advise will be very, very appreciated.
Can you PLEASE HELP?
Regards, Nikki
  • AussieMiss May 01, 2008
    Hi, i have the same problem with the same recorder also and can not get the picture back up either. I tried hitting the play button for 7 seconds and nothing! And with no picture i can not get back into the settings to see what i am changing. Any help would be great.
    Kristy
We could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Posted on Jun 01, 2008
  • 44 Answers
You have to take the dvd recorder off  progressive mode. You need to set it up with and press play on the unit and then press and hold it for 7 seconds. That will might take it off of progessive. Otherwise to show the picture you will have to use progressive cables. The progressive cables are red green blue and a red and white audio cable and then put it on your component video channel. Those are both solutions.
Posted on Jan 15, 2008
HDMI quit working with store bought DVDs
so you have to update a new firmware and then it will be ok
Dec 20, 2007 | Toshiba 52HMX84 52" Rear Projection...
Black vertical line of approx 1 mm from top to bottom of the screen at 80mm to the right of Samsung LCD TV LA40C630K1MXXs
I have hate to say it, but you need to replace your panel. Would be more cost effective to replace your set.
May 20, 2011 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung 650 lcd 40" tv picture blacks out for a few seconds.
Dude, better check your cable and also your TV's power management settings. This might also happen due a issue with the HDMI output of the satellite box.
Jan 07, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
My Samsung 40" Flat Screen LCD TV clicks a bunch of times before turning on, especially when not used, ie...overnight.
The power supply capacitors are getting bad - 1000uf 10V- they need to be changed before they blow completely - dead set.
Oct 03, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
May 19, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung LCD TV Image Retention...I Think
I have not noticed that with my set, Sony Bravia 2007 1080I.
Uh, I have a bigger problem though...
I had just paused my live tv for about 40 minutes on abaseball game and now I have green burn in.
I'm in the middle of searching the net for solutions. I have tried:
pure white screen for 30 minutes (no change)
"fuzz" for 1 hour (no change)
turn TV off for 12 hours (no change)
I'll now try to power down fully for 12 hours and see what happens.
Apr 26, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Philips Magnavox MWR10D6 DVD Recorder Logo
363 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
