Question about Jenn-Air Kitchen Ranges
We have a twenty year old electirc jenn-air range with vented cooktop. the oven and range top both stopped working. digital clock only worked when light was turned on. repair man said it was not geting 220v current. electrician said it is. dont have model number
  • Jenn-Air Master
  • 3,361 Answers
The problem may well be a loose NEUTRAL wire to the range. At the wire terminal on the range check for power from each supply leg(L1 to N) and (L2 to N) to neutral(should read 120 volts) and across each power leg (L1 to L2) should read 220 volts.
If you in fact have 220 volts into the range with good neutral contact the problem is a bad neutral(ground) in the wiring harness inside the range.
Posted on Sep 29, 2009
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
Jenn- Air cook top oven sve47500b has error # F7 and the oven will not work
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Oct 25, 2010 | Jenn-Air JED8430 Electric Cooktop
The motor in our Jenn-Air central downdraft has stopped working. It's an electric cooktop. We think it's time to replace the unit; want to keep the central downdraft format, but this time want to have...
Not a problem . take a look at Jenn-air 's dual fuel . gas top elect oven and also down draft unit . can be vented several way's .. mm hope this helps . feed back pls . 84020
Dec 21, 2009 | Ovens
Jenn-Air Electric range clock display
The problem is likely bad capacitors on the clock module. I had the same problem on a similar oven and fixed it by replacing the capacitors on the clock module. Find someone who is good with electronics to help you. The parts will be a few dollars at most. See this link for more info: http://www.badcaps.net/forum/showthread.php?t=7902
Oct 06, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Clock/oven/temp screen for a Jenn-Air electronic range #SVE87600
I believe Jenn Air will pay a portion or electronic parts replacement on their ranges less than 5 years old.
You might try unplugging the stove for 1 hour and this is supposed to reset the stove to factory settings
Sep 06, 2008 | Kitchen Ranges
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Kitchen Ranges Logo
156 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
