Question about Garden
When the mower is started it runs very smoothly. The blow by from engine comes through the valve on side through floor of Carburator housing fouling air cleaner. when air cleaner off oil is sprayed on engine from bow by opening.
  • 389 Answers
REPLACE THE CRANKCASE BREATHER ON THE SIDE OF THE BLOCK. IT IS A SMALL RECTANGULAR SHAPED BOX AT THE END OF THE HOSE THAT IS ATTACHED TO THE AIR CLEANER HOUSING WHERE THE OIL IS SPRAYING IN
Posted on Sep 29, 2009
Riding mower wont start
if the carburettor is fine and the choke is working, check the ignition timing.
May 19, 2016 | Briggs & Stratton Briggs Stratton Intek V...
Idles smooth, sputters coming from muffler like its running on one cylinder
Hi T:
Interesting as smooth idle and sputter are contra-indications.
- Smooth idle should be healthy
- Sputter could indicate problem:
- mis-fire? Possible bad spark plug or bad exhaust valve. Pull spark plugs to check to see if any are fouled. Compression check will help depermine why fouling is happening.
How many cylinders?
How many Km on engine?
With engine hot, Remove oil filler cap and see if any vapour indicating blow by (bad rings)
My suggestion?
Do some more checking and reply as a comment on this post. Will assist if I can.
Cheers.
Oct 18, 2015 | Cars & Trucks
Ariens riding mower shooting mix of oil/gas up into air filter housing when running at high speed and engine dies. carburator seems to flood when first starting. what could be the problem?
Check the engine oil level, If it overfilled, drain some off. If the oil is level/full, then you may have bad rings and or valve guides.
There is a blow by tube from the crankcase that goes in just before the carb. If you have too much oil, at high speed the crankcase pressure will blow the excess oil right into the air filter. Same thing with bad rings or valve guides. The pressure blowing by the rings at high speed is over pressurizing the crankcase and causing the oil to blow into the air filter. You need to do a cylinder pressure check. Putting the piston at top dead center, and charging the piston head with air. The flywheel can not be allowed to move or it may move the piston or open one of the valves. If the pressure drops, then you will need a ring job. Squirt some oil into the piston, and re pressurize, if the pressure drops again, chances are you will need new valve guides. The oil squirted into the piston chamber will seal the rings, causing the pressure drop through the guides.
Sorry, couldn't give you better news, but your looking at an engine tear down. You might want to consider the cost of repairing vs a new mower. 12 years has served you well.
Mar 16, 2014 | Ariens Garden
My 99 buick regal cranks over and starts but has trouble running. If you give it gas to help it through the start up it levels out and runs fine. Fuel pump is good, I've changed spark plugs and wires,
sounds like a stuck open EGR valve to me , take it off of a cool engine and spray some carb cleaner around the seat see if any leaks through to the other side. If it does The valve is bad. Also check out your throttle body for carbon and gumming. W/ engine off spray an appropriate carburator
cleaner into the opening and clean throttle plate and bore with a rag until shiney. put all the air cleaner hoses back together and hold throttle to floor momentarily until engine starts, then rev up half way and release throttle twice quickly, now allow engine to idle idle should be stable and smooth. If not then check for other sources of vaccume leaks.
Apr 18, 2013 | Cars & Trucks
Hello there,when i starts z car in z morning,blue smoke comes out.Is that normal please.And z car miss fires if i accelerate suddenly.I have changed z distributor,spark plugs n wires.Z car is of carburator...
The blue smoke is OIL, coming from bad seals in the valves. It drains into the cylinders overnight and when you start the car it burns the oil off. This is probably fouling your plugs and if backfiring will fould the carburator. The miss firing is due to the age and most likely the timing of your engine, along with fouled plugs and carb.
Mar 08, 2011 | Honda Accord Cars & Trucks
Think oil ran in carb
Try to always tilt a mower with the front of a horizontally mounted engine up in the air (head with spark plug end). This will keep the oil from going places it doesn't need to go...like into the carb/air filter area and along the valves into the cylinder head and combustion chamber (unless you get lucky and the piston is running the compression or power stroke with valves closed). You probably loaded the crankcase breather with oil which in turn loaded the carb with oil when you started running it as it vents over via a metal tube an inlet in the air filter housing.
It will take a little time to get all the extra oil thru the carb. To speed this up...pull the breather off the block (on engine side opposite the carb) and stand it up or blow it out allowing all the oil to drain out. Chances are you also need to remove the spark plug and clean it also as it probably is oi-fouled which probably caused the engine to quit in the first place.
Jul 10, 2010 | Briggs & Stratton Garden
Mtd ym 21" starts but wont stay running
Just checked my dad's for same problem. First thought is its not getting gas from tank; line is clean and no holes. On his 22" MTD push, i took off the air cleaner housing to expose the carb. Sprayed carb cleaner in carb throat, checked for smooth butterfly valve action, and also cleaned small jet/opening on left side of carb housing. Put it together and it ran perfectly. Don't buy a kit until you at least try this, its cheaper!
Oct 13, 2009 | Mtd 22" Yard Machine Push Mower
TRYING TO LOCATE THE PCV VALVE ON MY 2000 FORD RANGER XLT, 3.O 6 CYLINDER HELP...
it is located on the passenger side of engine. It is mounted on the valve cover and a hose runs up to the black air intake housing, it comes from the air filter to the carburator
Sep 04, 2009 | 2000 Ford Ranger SuperCab
Mower stutters when i turn up to full throttle.
you need to clean the breather out it is located on the side of the valves it is a rectangle shape and has a hose coming out of it to the air filter have you took the carburator out and cleaned the jets as well?
Apr 02, 2009 | Garden
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
