I have a Simpson Eziset 950 top loader washing machine. The problem is that in normal washing cycle the machine doesn't drain the water at all. It gets stuck and the digital display shows ''HC'' and it is beeping. Only way to get it going again is to press the start button which begins the whole cycle again?
SOURCE: washing machine lid switch
used my noggin and saved $20-00
Posted on Dec 29, 2008
jtbjtb
  • 135 Answers
SOURCE: annoying beep
Open the control panel and locate the beeper. Pull off one wire and tape over it with electrical tape. Voila! Hope this helps!
Posted on Jan 01, 2009
  • 343 Answers
SOURCE: Hi, my Simpson eziset 605 doesn't hold any water.
check that the drain hose is not lower than the water level. If it is, the water will simply drain away by gravity.....Nomess
Posted on Apr 20, 2010
  • 159 Answers
SOURCE: simpson eziset 950 wont turn on
Hi there.There is a fuse inside the head panel.the fuse is a glass type about 3.5 amp.you can normally get these from an electronics shop such as **** smith or Tandy Electronics.Make sure the plug is out.the fuse is in the green circuit board.
Posted on Jun 01, 2010
  • 713 Answers
SOURCE: My Simpson Eziset 550 won't
Hi just read your posting.Now in your posting you said there were 2 lights flashing.What lights are flashing?Also on a sticker at the back of the machine there is a model number.Could you please reply back and let me know the model number and which lights are flashing.Looking forward to your reply.
Posted on Aug 18, 2010
Simpson Eziset 550 washing machine is draining water through overflow drain at top of laundry sink.
The discharge volume from your washing machine is too great for your laundry tub to handle.
Feb 05, 2018 | Simpson Washing Machines
Simpson Eziset 750 top loader washing machine won't fill with water.
might be the inlet valve has failed or the main controller
Dec 03, 2016 | Simpson Washing Machines
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
Where is the lint filter on a Simpson Eziset 950 top loader washer?
lint filters for simpons top loader is at the bottom of the center lift out piece in the agitator
just pull the lot up and the lint filter is a small pocket at the end of it
Dec 10, 2015 | Simpson Washing Machines
How to fix error E17 code on eziset 9.5 kg top loader
Supply problem.
Check to see if water hose is plugged and test water pressure.Check water valve supply shut off.
See if filter is plugged.
Run full cycle w/no clothes in washer. Add 1 cup of vinegar,no soap.
May 03, 2014 | Washing Machines
My simpson eziset 7.5 washing maching does not hold water
Be sure that the drain line is above tub level.
Dec 04, 2012 | Simpson Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
I have a 3 yr old Simpson Eziset 550 Washing machine top loader and it is getting stuck after the first wash cycle. It washes and drains but doesnt switch over to the rinse and spin cycle. Can anyone help...
Hi just read your posting.After the 1st wash cycle the machine drains the water,Is the machine continuous draining?Or does the machine stop the draining and sit there silently?Please reply with additional information and I am sure I can help you.I have worked on this machine alot so if you reply back we can rectify the problem.Looking forward to your reply.
May 14, 2011 | Washing Machines
Washing Machines Logo
319 people viewed this question
Top Washing Machines Experts
