Question about HP PSC 2210 All-In-One InkJet Printer
IT DOSN'T WORK
First it didn't turn off and then it wont work for any of the functions and it makes a weird sound
  • HP Master
  • 19,396 Answers
It has a mechanical problem. Try removing cartridge and putting them back in place. Check also if the ink carriage is stuck somewhere (usually at the right hand corner). the machine will probably need disassembly to fix the problem.
Posted on Sep 29, 2009
My car wont start and electric systems seem to be spacing out
That sounds like most systems are being under-voltaged, check the battery voltage and charge it or replace it if necessary
Mar 25, 2015 | Cars & Trucks
Trying to locate turn signal relay flasher on a 2000 chevy monte carlo ss
The Monte uses a single flasher unit that integrates turn signal and flasher functions. It is mounted in a junction block that is attached to the firewall just to the left of the steering column under the instrument panel. To get at it you have to remove the the sound insulation panel that is attached to the lower steering cover and then the lower steering cover as well.
Jan 19, 2013 | 2001 Nissan Maxima
It wont turn on
Sounds like your hard disk has failed.
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Nov 30, 2012 | Computers & Internet
Headphone jack not functioning properly
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out ..is that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Dec 22, 2011 | Computers & Internet
I turn the key but the car won't start. Thinking I didn't turn it enough I turned it again and it makes a weird sound. Turned the car off and back on and it worked fine. Then today I had...
If in fact you own a 2011 Tucson, it's under warranty. You're describing a malfunctioning brake/stop lamp switch relating to the traction control light and getting into park. The other problem needs to be diagnosed by a qualified/certified Hyundai Service Technician (probably under warranty). Phone your nearest Hyudai Service Department & take it in for warranty repair (or have it towed in using your Hyundai Roadside Assistance Service (no cost to you).
Aug 27, 2011 | 2011 Hyundai Tucson
Two days ago I had my cv boot replaced because it was making a crackling sound when I would turn. Now today my car is making a weird noise. I sounds like metal is being dragged underneath my car. I was...
If the CV boot was damaged you can almost bet the CV itself needs replacing as moisture and dirt has probably ruined the joint. Replace the CV joint.
May 23, 2011 | 2004 Kia Optima
My rowena precision steam iron steam does not work
Solution for me:
I just bought a Rowenta Precision for $5.95 at Goodwill. I brought it home and it didn't work
I read about the cords and weird size screwdriver needed. It sounds like a lot of work. So what I did was push the electrical cord into the iron. it didn't seem to move but must have. The iron works perfectly now. Such a deal!
Mar 05, 2011 | Rowenta Precision DM580 Iron
My 500gb wd "my book" is making weird noises and wont show up
The whirring noise is the heads trying to read hard drive and then the weird rubbing screech sound and not showing up in your pc. sounds like the drive is dead.
Jul 14, 2010 | Western Digital My Book Essential 500GB...
Sorround sound switchboard lit up and quit working.
If the fan is making weird noises there is either something wrong with the bearing or it has ingested something.
Maybe you could look, listen closely and determine which it is. If it's foreign matter you may be able to extract or vacuum it out. If it's just bearing noise, you have to decide how bothersome it is and if a shop visit is justified. A clog is BAD because the fan is protecting the unit from high temperatures.
Feb 17, 2010 | RCA RTD300 System
HP PSC 2210 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
