Knob for settings is broke - Washing Machines
    Genius:
  • 1,036 Answers
If the actual centre is ok that drives the selector, then you just need a new knob for it. Thesec are available from online apliance centres.
If it is the actual mechanism that is broken, then this part is quite expensive - so shop around before you buy.
Posted on Sep 30, 2009
Vent control knob on our 2005 Sentra was stuck, made a loud click when turned, and now only dash vents work, no defroster...any solutions for a quick fix?
HERE'S A LINK TO YOUR SET UP,SOMETHING COULD BE BROKE,NOT LETTING YOU TO ADJUST WITH THE SWITCH,THERE ARE CABLES ATTACHED TO THE LEVERS THAT MAKE THEM TURN WHEN YOU TURN KNOB,MAY BE LOOSE,BENT OR BROKE,YOU WILL HAVE TO REMOVE THINGS AND SEE.
Oct 05, 2013 | 2005 Nissan Sentra 1.8
I have an older a/c model no. A494901 (?). The control knob broke off. Is it very hard to replace it with a new knob? And, where would I get a new knob? Thanks, -Fran O'Neill
Depending on your break is the stem leading from the settings selector switch still there or did it break to. If it broke as well you will need to replace both the selector switch and the knob. If not the knob can be obtained from your local Sears Repair Center.
Jul 05, 2011 | Kenmore Heating & Cooling
The knob broke off. How do I fix it?
well if you broke only the knob, then thats an easy fix.. just obtain part # 154535903 - KNOB and replace.
however if you broke the shaft off inside the knob you will need to procure part # 154668901 - CONTROL MODULE
remove power from the dishwasher and remove the screws holding the inner door panel to the door.
once that is removed you should see the control assembly and related wire harness that needs to be disconnected and screws that need to be removed, etc..
hope that helps,
best of luck,
ttfn
Oct 19, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Knob broke off my A/C with the peg inside!
Simple you either replace the knob assembly or use araldite and fix off the broken knob. It is only a temporary remedy and for a permanent solution please replace the knob assembly and get rid off this problem
Jul 14, 2009 | Heating & Cooling
Sunbeam Rocket Grill - knob broke - where can I find a replacement?
I contacted Sunbeam at (866) 588-1081. They are supposed to send a replacement timer knob in two weeks at no charge.
Mar 03, 2009 | Kitchen Appliances - Others
Washer pump
Unplug the unit for 10 minutes...then open the door.
Oct 02, 2008 | Splendide 6200
Bravetti Convention Countertop oven
You can order replacement knobs at http://www.euro-pro.com/europro/default.aspx Enter K4245H in the parts and accessories search box. Knobs are $1.00 each.
Oct 08, 2007 | Bravetti 35-396 Power Hand/Stand Mixer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
