Question about Epson Office Equipment & Supplies
Is there a workaround for using alternate brand ink cartridges in my Epson CX9400Fax printer? I have been using off brand cartridges in nthis printer for a while now but I just put in a black and it shows that it cannot recognize ink cartridge>
  • Epson Master
  • 419 Answers
You might want to try disabling the status monitor software that is installed with your printer driver.
To do this you
  • Locate your printer in Printers & Faxes
  • Right click and choose printing preferences
  • Choose the "Maintenance" tab (top right)
  • Locate the "Speed & Progress" button and click it
  • Tick the "Disable EPSON status monitor 3" box
  • Click on OK and then OK on the previous box
You should now find that any computer generated nags screens leave you alone.
This doesn't always work but it's definitely worth a try... Also worth considering that you have bought or been mis-sold cartridges that are not compatible with your printer... It does happen.
Hope that helps.
Martin
Posted on Sep 30, 2009
Epson cx9400fax error waste ink is saturated
Get the User Guide from the Epson site for your printer. If that doesn't tell you what to do go back to the site and ask the question.
Oct 16, 2014 | EPSON Stylus CX9400Fax Series
Epson wont recognize black refill cartridge.
I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunately, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps.
Jun 26, 2011 | Office Equipment & Supplies
Does not reconize non epson ink cartridge. I remove and reinstalled and it printed but now its back to not reconize cartridge.
You did not say if you were using "New-Epson Ink Cartridges", or actually using "Non-Epson Ink Cartridges" [Generic or Third-Party ink cartridges] in your printer. I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunatly, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps...Good Luck!
Jun 09, 2010 | Epson CX8400 All-In-One InkJet Printer
Epson CX9400Fax reports "Cannot recognize ink cartridges."
Confirm you are using the correct cartridge:
Ink color Part number Black 69 Black (High Capacity) 68 Cyan 69 Magenta 69 Yellow 69
If the cartridge is the correct one check the contacts on the cartridge and its holder for contamination or damage.
May 24, 2010 | Epson Stylus RX580 InkJet Photo Printer
My printer refuses to let me print when one ink color is gone
No, the CX9400 cannot be used if a cartridge is empty or missing and cannot be overridden.
Apr 08, 2010 | Epson Stylus CX9400 Photo Printer
Epson stylus cx9400fax; only the black wont print corrct, gaps, missing, illegible. all other colors work fine, have done nozzle check, head cleaning, and replace cartridge. can I take this thing apart and...
You may need to replace the inkpad, it is located under the cardrige park. Also clean the rubber sqeegee blade.
Wear cloves and use a tweezers to remove the ink pad, new ink pads are available online and thru the reatiler that sold you your printer.
Mar 11, 2010 | Epson Stylus CX9400Fax InkJet Photo...
REPLACED TWO 68 CARTRIDGES IN CX9400 EPSON
Generic carts are sometimes not recognized. Epson's chips are the cause. I solved this problem for a small investment. I purchased a CISS system for about $75.00 [ink included], that's the cost of OEM carts that do not last very long. The CX9400Fax is an Ink Hog, which is why the printer is so cheap. If you want a CISS go to http://www.inkproducts.com/ink-store/ They are great if you need help and will call you back in less than an hour. Get the Waste Ink Kit when ordering the CISS.
Apr 05, 2009 | Epson Stylus CX9400 Photo Printer
HOW DO I CHANGE THE INK CARTRIDGE IN THE EPSON CX9400
CX9400Fax, All in one?  If so; download the manual and/or Q& A and /or trouble shooting guide for instructions:
Link
Feb 07, 2009 | Epson Stylus CX9400 Photo Printer
Epson stylus cx9400fax series printer
There is no chip resetter for this model at this time. However, one is to be available in the near future. So for now you must purchase new/refilled cartridges.
Jan 24, 2009 | Epson Stylus CX9400 Photo Printer
Ink cartridge replacement
Hi-
- If a cartridge is expended, you see a message on the CX9400Fax display screen. The icon on the screen indicates which color to replace. Press OK.
- If you're replacing a cartridge before it's expended, press the Setup button, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
Hope this helps
Aug 04, 2008 | Epson Stylus CX9400 Photo Printer
149 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
