Question about Maytag Neptune MAH5500B Front Load Washer
I have an MAH8700AWW Maytag Neptune Front load washer. Get error code of 3E Ran diagnostics and completed service mode with washer testing out fine. After it came up we did a quick spin test reached 690RPM on display. Then ran it with full load of laundry did it again it went down to 0 paused and then 3E again. Door remained locked. Exited quick spin. Paused it than remained locked. Once reached 0 exited quick spin door unlocked spin LD lit door locked after 6min of spin 3E comes back. Spin light stays on. After all that put back into service mode again, and in service mode did quick spin test this time hit 1100 RPM on display now I am stumped.Other history, 3E sparatic and intermitent sometimes during wash other times at the end than sometimes it can go without any interuptions.
  • rkj4me Sep 29, 2009
    I have an MAH8700AWW MaytagI have an MAH8700AWW Maytag Neptune Front load washer. Get error code of 3E Ran diagnostics and completed service mode with washer testing out fine. After it came up we did a quick spin test reached 690RPM on display. Then ran it with full load of laundry did it again it went down to 0 paused and MoreI have an MAH8700AWW Maytag Neptune Front load washer. Get error code of 3E Ran diagnostics and completed service mode with washer testing out fine. After it came up we did a quick spin test reached 690RPM on display. Then ran it with full load of laundry did it again it went down to 0 paused and then 3E again. Door remained locked. Exited quick spin. Paused it than remained locked. Once reached 0 exited quick spin door unlocked spin LD lit door locked after 6min of spin 3E comes back. Spin light stays on. After all that put back into service mode again, and in service mode did quick spin test this time hit 1100 RPM on display now I am stumped.Other history, 3E sparatic and intermitent sometimes during wash other times at the end than sometimes it can go without any interuptions. We checked all the connections as well
  • Maytag Master
  • 19,396 Answers
3E is wrong voltage detected on motor. The motor contacts must be tested, if they are OK, the motor may need replacement.#
I see if I can find parts and schematics.
Posted on Sep 29, 2009
    President:
  • 1,865 Answers
3E is an overload condition. Your symptoms indicate a loose connection. Remove the plug-in connectors, spray them with contact cleaner, if possible use needle nose pliers to squeeze the tubular connectors so that they are tight fitting.
What's your problem? I am getting a 3E code during wash and the machine stops
3E == overcurrent detected at the motor.
Open the control panel, there should be a tech sheet in there that explains how to put the machine into service mode (press chime and extra rinse keys for three seconds) and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes... and lots of other stuff that'll help you track this down.
You can also go ahead and check out the windings on the motor. Unplug harness connector and test from wire insertion side.
Pin #1 and Pin #2 of CN9 == 11.6 ohms
Pin #1 and Pin #3 of CN9 == 11.6 ohms
Pin #2 and Pin #3 of CN9 == 11.6 ohms
Nov 13, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer giving error code A0
Maytag Neptune Priority One Service
(888) 462-9824 call to the company to due the error code.
God bless you
Aug 01, 2012 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune MAH8700AWW with error code tE, lower case t and upper case E. What causes it. I finally got it in diagnostic mode and it says U133 but wont go any further.
"te" error code is caused by a faulty thermistor; likey cause is:
a. Loose wiring at the control panel (directly behind the cycle selector knob)
b. Broken wire at the thermistor (located at the bottom/front of the tub)
To access the wire plug connectors at the control pannel, remove the top cover of the washer. Stand in front of the washer and look for the plug connectors behind the control panel. Pull apart the plugs and re-install.
Test the washer. If the "te" error still occurs it will be neccesary to remove the front panel as well (two sets of special plier-type tools are needed).
Inspect the thermistor closely, with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
Just like a reference guide, this service manual could helpful: MAH9700AW
Hope this helps.
Oct 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
Code E 3 On Maytag MAH8700AWW
3E means overcurrent detected at the motor.
Open the control panel, there should be a tech sheet in there that explains how to put the machine into service mode (press chime and extra rinse keys for three seconds) and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes, and lots of other stuff that'll help you track this down.
If the error code somes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Hope helps.
Apr 18, 2011 | Maytag Neptune Washer
What is the error code dS for Neptune Maytag Washer MAH8700AWW?
Please advise me on any recalls and technical information involving error code 3E during a wash load, which appears related to be a faulty control panel. My machine is always shutting down each time it reaches the rinse cycle. Numerous consumers have been complaining about this same model at consumeraffairs.com. Replacement of the control panel is expensive at an average cost of 298 dollars and appears to be the corrective action for other consumers with error code 3E. Over current is not being detected at the motor. I'm disappointed with the quality of this washer considering I purchased it in 2005 for over 1,000 dollars. This problem has forced me to use a local laundry mat to wash my clothes. This error code is not listed in the User manual.
Aug 24, 2010 | Maytag MAH8700A Front Load Washer
What does a 3E error code mean? i have a maytag
Trouble shooting guild for this machine indicates this means Motor Failure. Over current is detected
Feb 08, 2010 | Maytag MAH8700A Front Load Washer
Cycle stops 3E code appears
Well the error code 3E means that the overcurrent is detected at the moter.
Please check it if you have some overcurrent problem!
Thanks!
mannu_rakesh
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Getting error E3
Open the control panel, there you will find a tech sheet that explains how to put the machine into service mode and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes. You will also find serveral other diagnostic service notes. Read them and follow the instructions to test the motor, motor control, and main control board. Hope this helps.
Jul 16, 2009 | Maytag Neptune Washer
Maytag washer 3e fault code
Jan 14, 2008 | Maytag MAH6500 Neptune Front Loading...
Error code OE does not finish whole cycle
Just resolved same problem...it is the pressure switch aka water level sensor.  OE is overflow error.  Pressure switch is located under top cover on front right hand side.  It is round and has a rubber tube leading down to the drum and a electrical connection to the board.  Paid maytag man to diagnose/install cost me about $150
Oct 11, 2007 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
196 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
