Question about Hotpoint Aquarius WF220 Front Load Washer
Not spinning or agitating after flooding
There was blockage in the pumpout hose. While spinning, the water went everywhere else but out the hose. I managed to clear the blockage, but not only the pump works and not the agitator or spin. I suspect something (brushes or circuitry) got wet. Will air drying remedy this?
  • Ed Vaisvilas
    Ed Vaisvilas Sep 29, 2009
    "but not only the pump works", should read "but NOW only the pump works".
    Problem Solver:
  • 6 Answers
While turning the motor by hand, I applied medium heat and high fan with a hairdryer. Strange remedy, but it worked, and all is back to normal.
Posted on Oct 01, 2009
My GE washer leaks from Hose Flood during agitation - how do I fix it?
It should be connected right next to the drain hose.
Jul 04, 2014 | GE Washing Machines
Over flow , flood
Bottom plastic hose came off of the water level switch.
Caused no pressure to go to the water level switch.
Jan 04, 2009 | Maytag Washing Machines
White-Westinghouse washer will spin but water will not spin out
no its a remote electric pump,no belt.its ither blocked or fail.cut power,pop top remove frount cover an you will see pump.white or tan.remove hoses[watch out 4 water and check 4 blockage
Jan 02, 2009 | Westinghouse WWS833ES Super Capacity Top...
Whirlpool ultimate care 2 water wont stop filling...over flowing everywhere.
Your level switch hose has come loose.first open the display panel to check in back of water level switch,and look for a hose that is not attached to the back of it.
Jun 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer Dryer flooding at spin cycle
Nicola...not sure what you mean by floods. If you mean that water is coming out of the top of the machine basket as a result of either overflow or splashing, each is different from water coming out of the drain hose.
Generally, washers which are spinning are also completing a rinse cycle...the program adds a bit of water to the spinning load to drive out the last of the detergent.
If you've got a problem in spin with flooding out of the top (basket full), this is probably a timer issue (or...less likely...a sticking water valve). If the problem is splashing, you should keep the cover closed for safety. If the drain hose is overflowing, the problem is lack of capacity to take the pumpout. Clean the drain.
May 29, 2008 | Washing Machines
Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
Nov 08, 2007 | GE WDSR2080D Top Load Washer
Does not spin
the machine will agitate and pumpout the water but it will not spin
Aug 05, 2007 | Kenmore 23822 Top Load Washer
Hotpoint Aquarius WF220 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
