Question about Maytag Neptune MAH5500B Front Load Washer
Noisy during spin cycle - Maytag Neptune MAH5500B Front Load Washer
    Genius:
  • 1,036 Answers
This may be due to a worn belt (squeeks when changing speed), Faulty dampers - (banging about), constant rattling (rear bearing), or a motor on it's last legs (replace motor).
Most faults can be fixed by replacing those listed.
Posted on Sep 29, 2009
jsrock516
  • 5911 Answers
SOURCE: My Maytag PAV2300AWW Performa is noisy on spin cycle
If you are talking about a loud sqeaking noise, this is usually attributed to a worn snubber ring and/or brake assembly. You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is to get rid of most noise related problems (this will be the bottom round plate where it meets the casing of the machine). However, if the snubber is worn too much, or if the brake assembly is worn they must be replaced. I would recommend replacing the following parts:
Brake Stator: 1057484 Price: $7.45
Brake Rotor and Lining: 1032674 Price: $16.70
Snubber: 1055142 Price: $4.35
Brake Removal Kit: 997909 Price: $99.40*
*Brake removal tool is required in order to remove the brake assembly and/or to replace the snubber. There is a 200lbs spring located under the Brake Stator that must be compressed PRIOR to removal or you could cause injury to yourself.
You can find all your parts and information at repairclinic.com. I am not affiliated with the website. I am merely recommending them because I have used their service before. Plus, they use the same repair parts as your major appliance repair companies, but at a lower cost.
The parts required to make the repairs aren't very expensive, but the tool required to do it IS. Also, if you've never worked on this type of washer before, this is not a job that I would recommended to the average do-it-yourselfer. Maytag is real good abpout providing the necessary instructions with their parts, but this is a bit involved.
Post back with comments and let me know if this helps you.
Posted on Jan 29, 2008
futureloginn
  • 734 Answers
SOURCE: danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Dec 12, 2008
MNfisherman
  • 11896 Answers
SOURCE: Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Posted on Jan 28, 2009
localwonder
  • 6784 Answers
SOURCE: Front load Fridgidaire ftfb4000fs1 won't spin
This is a fault that resides within the motor control board. you will need to replace this failed module asap if possible. it has failed.
Posted on Jun 15, 2009
e-Guru
  • 3917 Answers
SOURCE: During the spin cycle, it sounds like a
This is difficult to work out as there are so many different symptoms. Here are my thoughts -
Dust from carbon rushes is black. Grey dust usually comes from a loose concrete weight. Loose tub weights are rare on this model but they cause a loud knocking noise which is often worse when the washing machine is revving up to spin and dying down from a spin (suspension problems are also often worse at this stage too). It's not normally a metallic sound though.
If the noise is coming from the motor banging against the sides of the machine then it will make the machine move when it happens. The whole machine may jump or move to one side. The motor often thumps the side of the washing machine on Hotpoint washers where the motor is fitted at the top of the tub and over to the right hand side. This is a daft place to fit a motor and only Hotpoint / Credo did it. I think they've eventually stopped now though.
It is normal to be able to push the drum to the side so that the motor hits the casing. If the suspension has gone, the tub should be twisted and leaning to one side more than the other or it just could be very loose. It's difficult to check suspension if you don't know how it should feel.
If the noise is coming from the inner drum hitting the heating element or throwing an object like a £1 coin (trapped between the inner drum and the outer tub) around, then the washing machine will be stable but the noise would still be a horrible metallic knocking. This is one because I suspect.
If the carbon brush is charred (as in these Hotpoint & Credo carbon brush pictures) then it's definitely faulty and needs replacing. This could cause the machine to bang about violently on spin but it normally wouldn't.
As for the clothes being covered in black marks. (Washing (laundry) is still dirty or has marks on it (marks on clothes) ). This sounds potentially ominous as it could be that the inner drum is catching on the inside of the outer tub which is often covered in gunge. As clothes are pushed through the holes in the drum on spin, this could cause them to scrape on the inner tub and pick up greasy marks. Check for play in the drum by lifting it up and down from the front. It should only lift up a mm or so. Then turn the drum so that one of the drum paddles is at the bottom. Pull the drum toward you at the point of the drum paddle. It shouldn't have any play in it. Turn the drum round and test the other two as well. If the drum spider and shaft has a crack in it then one or more of the arms will allow excess play when you pull the drum at the paddle points.
Carbon dust from a motor could never get onto clothes.
Thank You for using Fixya.com
Posted on Aug 13, 2009
The spin cycle is very noisy. What could be the problem?
hi robyn.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to yourwasher) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.27 Jul 2015
How To Fix A Washing Machine Making Noise During The Spin Cycle ...
https://removeandreplace.com/.../washing-machine-making-noise-during-the-spin-cycle-...
or try this link might help you.
washing machine spin cycle is very loud Google Search
Nov 18, 2017 | Washing Machines
Simpson 175 washing machine: spin cycle noisy and motor cuts out after short spin. Bowl feels stiff
Hi just read your posting.Now from the information on your posting the machine is noisy on spin and your motor is cutting out after a short spin.Is this correct?Now does the motor cut out during a wash cycle?If the motor only cuts out during the spin cycle , and with your machine being noisy on spin,I think the fault will be your bearings are corroded.With the bearings being corroded it puts more load on the motor causing the inbuilt thermal overload in the motor to activate and turning the motor off to save it from burning out.Please reply with additional information on, if it cuts out on wash and I am sure I can help you further.
Aug 07, 2010 | Washing Machines
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Very noisy during spin cycle
The drum balance ring cound be unliquified. Turn it when it is off. There should be sloshing. If there isn't, call in a repair man. He will try to fix it.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
OK during wash and rinse cycle but suddenly became very noisy during high speed spin cycle
If noise occurs only during spinning cycle, then the 2 bearings and seal need to be replaced.
May 23, 2010 | Maytag Neptune Washer
No spin & drum is very noisy during cycle ,like a jet engine
Sounds like the drum bearings have gone and the belts come off.
Im afraid this is an expensive repair and not a diy job.
Sorry to be the bearer of bad news.
thankyou for using Fixya.
Mar 15, 2009 | Washing Machines
You probably need new shocks for the washer as they break over time. They cost $37 each and you can replace them your self. If you don't fix these you may end up breaking the motor controller and while the part may be covered under the warranty the diagnostic and labor is not.
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
Feb 22, 2008 | Frigidaire FWT449
Danby washing machine noisy only during spin cycle
hi there,
Jan 13, 2008 | Danby DWM99W Top Load Washer
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Maytag Neptune MAH5500B Front Load Washer Logo
238 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
