Question about Boating
2000 Evinrude 70hp 4-stroke. Solenoid bad, I want
2000 Evinrude 70hp 4-stroke. Solenoid bad, I want to pull the starter/solenoid. Have all bolts out and cables off, but it won't come out--top of shaft won't clear the flywheel to tilt out--do I have to pull off the flywheel, or both the flywheel and the mount plate (on top of block under flywheel)?
  • tenpiloto Sep 29, 2009
    Thanks
    Can you suggest the proper way to stablilize the flywheel so I can loosen the flywheel bolt?
    Guru:
  • 1,326 Answers
You shouldnt have to pull the mount, try removing the flywheel first and it should allow enough room to manuever the sarter out...
Posted on Sep 29, 2009
  • James Brooks
    James Brooks Sep 29, 2009
    Normally you can put a small extension though the flywheel holes to hold it in place then remove. You can also clamp a set of vise grips on the opposite end of motion to lock it in place. If not a air ratchet or 3/8" impact wrench does them very well. Just keep in mind the torque when retighting start by hand to avoid cross threading and then do not over torque as stripping may occur..
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
How do u take a stater relay off a vl 125
Follow the live lead from the battery it will go to the starter solenoid,disconnect it from the solenoid by undoing the bolt that holds it on then undo the other fat lead that goes to the starter motor then the smaller wires that are in a connected block.pull the solenoid off its rubber holder,that's it
Feb 27, 2015 | 2000 Suzuki VL 125 Intruder LC
Hi i have a 1984 35 hp evinrude electric start E35RLCRR that wont start or turn over
If you are sure that all connections are clean and bright, including the battery to the ground and battery cable to the solenoid, jumper from the battery (+) to the solenoid (+). If the solenoid clicks, but motor doesn't turn over, your solenoid is bad. Try jumpering momentarily from the battery (+) to the starter (+) and that should cause the starter to rotate. If that makes your starter rotate, your solenoid is still bad. Be sure that your starter has a good ground connection
Dec 23, 2014 | Cars & Trucks
Why electric start does not work and pull start works
1. Need a new battery
2. starter solenoid is defective
3. starter needs rebuilding...
Does Solenoid click when trying the electric starter? CAREFULLY jump the two terminals on the solenoid (SPARKS WILL FLY).. IF the engine turns over or starts, THE SOLENOID IS BAD. just replace it.
If it clicks when you are trying to start it electrically, use a multimeter (voltmeter) to see if you are getting 12v to the starter connection while you are trying to electrically start it. (+) lead on starter bolt and (-) to a motor mount bolt. If you get 12v+, starter needs rebuilding!
Jul 05, 2014 | Arctic Cat 2005 500 4x4 Automatic
How to replace a starter??
Ford Excursion, Expedition, Lincoln Navigator 2000-2005
Starter
Print
Removal & Installation
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    Negative battery cable
  2. Raise and safely support the vehicle.
  3. Remove or disconnect the following:
    NOTE To disconnect the hard-shell connector from the solenoid S terminal, grasp the plastic shell and pull off; do not pull on the wire. Pull straight off to prevent damage to the connector and S terminal.
    Starter terminal cover Terminal nut and separate the battery starter cable from the starter motor Solenoid S terminal connector, if equipped with a starter mounted solenoid
  4. Remove or disconnect the following:
    Starter motor retaining bolts Starter motor from the vehicle
To install:
  1. Install or connect the following:
    Starter motor and retaining bolts. Tighten the bolts to 15-20 ft. lbs. (20-27 Nm). Bttery starter cable and a terminal nut to the starter motor. Tighten the terminal nuts to 79 inch lbs. (9 Nm). Slenoid S terminal connector, if equipped with a starter mounted solenoid Sarter solenoid safety cap, if equipped
  2. Lower the vehicle.
    Ngative battery cable
  4. Start the engine several times to check starter motor operation.
  2. Remove or disconnect the following:
  3. Raise the front of the truck and install jackstands beneath the frame. Firmly apply the parking brake and place blocks in back of the rear wheels.
    Wiring from the starter motor terminals Starter motor retaining bolts, loosen Starter retaining bolts while supporting the starter motor Starter from the vehicle
To install:
  1. The installation is the reverse of removal. Tighten the starter retaining bolts to 15-20 ft. lbs. (20-27 Nm)
4.6L, 5.4L & 6.8L Engines
  1. Before servicing the vehicle, refer to the precautions section.
  2. Disconnect the negative battery cable.
  3. Raise and safely support the vehicle.
  5. Remove or disconnect the following:
To install:
    Starter motor and retaining bolts. Tighten the bolts to 15-20 ft. lbs. (20-27 Nm). Battery starter cable and a terminal nut to the starter motor. Tighten the terminal nuts to 79 inch lbs. (9 Nm). Solenoid S terminal connector, if equipped with a starter mounted solenoid Starter solenoid safety cap, if equipped
  3. Connect the negative battery cable.
6.0L Diesel Engine
  2. Disconnect the battery ground cable.
  3. Remove starter solenoid protective cap.
  4. Disconnect the starter motor electrical connections.
  5. Remove the bolts and the starter.
To install:
  1. Installation is the reverse of the removal procedure. Tighten the starter bolts to 18 ft. lbs. (25 Nm)
7.3L Engine
To install:
Testing & Troubleshooting
Feed Circuit Test
  1. Make sure the battery is fully charged.
  2. Disconnect the Inertia Fuel Shutoff (IFS) switch.
  3. Connect a remote starter switch between the starter solenoid S-terminal and the battery positive (+) terminal.
  4. Connect the Rotunda 73 Digital Multimeter positive lead to the battery positive (+) post. Connect negative lead to the starter solenoid M-terminal.
    Fig. Motor feed circuit-S-terminal (1), remote starter switch (2), battery (3), Rotunda 73 digital multimeter (4), B-terminal (5), M-terminal (6)
  5. Engage the remote starter switch. Read and record the voltage. The voltage reading should be 0.5 volt or less.
  6. If the voltage reading is 0.5 volt or less, go to the Motor Ground Circuit Component Test.
  7. If the voltage reading is greater than 0.5 volt, indicating excessive resistance, move the Rotunda 73 Digital Multimeter negative lead to the starter solenoid B-terminal and repeat the test. If the voltage reading at the B-terminal is lower than 0.5 volt, the concern is either in the connections at the starter solenoid or in the solenoid contacts.
  8. Remove the cables from solenoid B-, S- and M-terminals. Clean the cables and connections and reinstall the cables to the correct terminals. Repeat Steps 3 through 6. If the voltage drop reading is still greater than 0.5 volt when checked at the M-terminal or less than 0.5 volt when checked at the B-terminal, the concern is in the solenoid contacts. Install a new starter motor.
  9. If the voltage reading taken at the solenoid B-terminal is still greater than 0.5 volt after cleaning the cables and connections at the solenoid, the concern is either in the positive (+) battery cable connection or in the positive battery cable itself.
  10. By moving the Rotunda 73 Digital Multimeter negative lead toward the battery and checking each mechanical connection point, the excessive voltage drop can be located. When the high reading disappears, the last mechanical point that was checked is the concern. Repair or install a new connection as required.
Ground Circuit Test
A slow cranking condition can be caused by resistance in the ground or return portion of the cranking circuit. Check the voltage drop in the ground circuit as follows:
  1. Disconnect the inertia fuel shutoff switch.
  2. Connect a remote starter switch between the starter solenoid S-terminal and the battery positive (+) terminal.
  3. Connect the Rotunda 73 Digital Multimeter positive lead to the starter motor housing (the connection must be clean and free of rust or grease). Connect the negative lead to the negative (-) battery terminal.
    Fig. Motor ground circuit-Rotunda 73 digital multimeter (1), battery (2), S-terminal (3), M-terminal (4), B-terminal (5), remote starter switch (6)
  4. Engage the remote starter switch and crank the engine. Read and record the voltage reading. The reading should be 0.2 volt or less.
  5. If the voltage drop is more than 0.2 volt, clean the negative cable connections at the battery and body connections, and retest.
  6. If the voltage drop is greater than 0.2 volt, determine which way the current is flowing in the cable.
  7. Connect the Rotunda 73 Digital Multimeter positive lead to the end of the cable nearest battery positive.
  8. Connect the multimeter negative lead to the terminal at the other end of the cable.
  9. Crank the engine and observe the voltage reading. The voltage reading should be 0.2 volt or lower. If the voltage drop is too high, clean the terminal ends. Retest, and if still high, install a new cable. If the voltage reading is less than 0.2 volt and the engine still cranks slowly, install a new starter motor.
Voltage Drop Test
WARNING When servicing the starter motor or performing other underhood work in the vicinity of the starter motor, be aware that the heavy gauge battery input lead at the starter solenoid is "electrically hot" at all times.
WARNING A protective cap or boot is provided over the battery input terminal on all vehicle lines and must be installed after servicing. Be sure to disconnect the battery ground cable before servicing the starter motor.
Always make the Rotunda 73 Digital Multimeter connections at the component terminal rather than at the wiring end connector. Making a connection at the wiring end connector could result in false readings because the meter will not pick up a high resistance between the wiring connector and the component.
Aug 05, 2012 | 2001 Ford Expedition
Unable to remove starter on a lincoln navigator 2000
Where are you stuck?
Removal & Installation 1. Disconnect the negative battery cable. 2. Raise and safely support the vehicle. 3. Remove the starter terminal cover. 4. Remove the terminal nut and separate the battery starter cable from the starter motor. 5. Disconnect the solenoid (S) terminal connector, if equipped with a starter mounted solenoid. NOTE: To disconnect the hard-shell connector from the solenoid (S) terminal, grasp the plastic shell and pull off; do not pull on the wire. Pull straight off to prevent damage to the connector and (S) terminal. 6. Remove the starter motor retaining bolts. 7. Remove the starter motor from the vehicle. To Install: 8. Place the starter motor in position and install the starter motor retaining bolts. Tighten the bolts to 15-20 ft. lbs. (20-27 Nm). 9. Install the battery starter cable and a terminal nut to the starter motor. Tighten the terminal nuts to 79 inch lbs. (9 Nm). 10. Connect the solenoid (S) terminal connector, if equipped with a starter mounted solenoid. 11. Install the starter solenoid safety cap. If equipped. 12. Lower the vehicle. 13. Connect the negative battery cable. Start the engine several times to check starter motor operation.
Let me know how you make out..
Feb 17, 2011 | Lincoln Navigator Cars & Trucks
Need to know how to install starter on 2000 lincoln town car
Please see my tip at http://www.fixya.com/cars/r5973094-starter_replace . These are generic instructions. Specific instructions for your car from autozone.com are pasted below. Please get back to me if you have any questions.
  1. Remove or disconnect the following:
    Negative battery cable and properly isolate to prevent accidental reconnection Red solenoid safety cap Wires from solenoid 2 upper bolts 1 lower bolt and starter
Fig. Starter motor mounting
To install:
    Starter and lower mounting bolt 2 upper mounting bolts. Tighten all 3 bolts to 15-20 ft. lbs. (20-27 Nm). Wires from solenoid and tighten the nut to 40-50 inch lbs. Red solenoid safety cap Negative battery cable
Oct 29, 2010 | 2000 Lincoln Town Car
I can't locate the starter solenoid on my 2000 chevy silverado. Where is it?
(Starter) Solenoid - Removal & Installation
  1. Remove the starter motor.
  2. Reposition the M-terminal stud weather cover.
  3. Clean the epoxy coating from the M-terminal stud.
  4. Loosen the M-terminal stud nut.
  5. Remove the cable from the M-terminal stud.
  6. Remove the solenoid bolts.
  7. Separate the solenoid from the housing and unhook the solenoid plunger from the drive gear lever.
  8. Note that the spring (3) is positioned against the drive gear lever (1) and the drive gear lever is placed inside the solenoid plunger loop (2).
    Fig. Spring (3) is positioned against the drive gear lever (1) and the drive gear lever is placed inside the solenoid plunger loop (2)
  9. Remove the solenoid housing.
  10. If necessary, remove the solenoid plunger and spring.
To install:
  1. If necessary, install the solenoid plunger and spring.
  2. Using Three Bond silicone 1207B, GM P/N 97720043, seal the starter solenoid attachment area.
    WARNING Make sure that the drive gear lever (1) is properly installed into the solenoid plunger (2) loop. Improper installation of the drive gear lever will cause an abnormal or no operation condition of the starter.
    Fig. Make sure that the drive gear lever (1) is properly installed into the solenoid plunger (2) loop
  3. Install the solenoid, making sure to insert the drive gear lever (1) into the solenoid plunger (2) loop, perform the following:
    1. Pull the gear lever (1) out away from the starter housing and pull the plunger (2) out away from the solenoid.
    2. Tip the solenoid and insert the lever into the loop, push the solenoid against the housing.
  4. Install the solenoid bolts and tighten the bolts to 89 inch lbs. (10 Nm).
  5. Wipe the excess silicone pressed out during the solenoid installation from around the base of the solenoid to make a weather proof seal.
  6. Install the cable to the M-terminal stud between the washers and terminal nut.
  7. Tighten the M-terminal stud nut and tighten the nut to 71 inch lbs. (8 Nm).
  8. Using Three Bond silicone 1207B, GM P/N 97720043, seal the M-terminal stud connection.
  9. Reposition the M-terminal stud weather cover.
  10. Bench test the starter in a free-run condition prior to installation.
  11. Install the starter motor.
To install:
Hope helped with this (remember rated this help) Good luck.
Nov 04, 2009 | 2000 Chevrolet Silverado
I think my starter is bad. How do I confirm/fix?
Make sure the small wire on the solenoid has a good contact. If it does, check that there is +power to there when trying to start. If there is power and a good contact, and the starter still won't crank, try shorting the two bolt terminals on the solenoid (carefull, it will spark). If the starter cranks then it's okay, suspect solenoid.If the solenoid is okay you should hear it kicking in.
Aug 02, 2009 | 1999 Land Rover Discovery
How do i remove starter on 2001 ford f350 dually (7.3 l powerstroke)
Starter
Removal & Installation 1. Disconnect the positive and negative battery cables.
ø To disconnect the hard-shell connector from the solenoid (S) terminal, grasp the plastic shell and pull off; do not pull on the wire. Pull straight off to prevent damage to the connector and (S) terminal.
To Install:
13. Connect the positive and negative battery cables.
14. Start the engine several times to check starter motor operation
May 27, 2009 | 2001 Ford F350 Super Duty SuperCab
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
