Question about Baumatic 23 in. BDW9 Built-in Dishwasher
Baumatic dishwasher BDW9
Will not turn on at main switch intermittently and when it does the LED is showing broken symbols. Can you help?
This looks to be the same problem I'm having with my dishwasher (BDW15) I have removed the control panel and have noticed the On Off button has started to burn out, thus cuasing intermitant power supply.
Solution is to replace the On Off switch with a new one, which I'm still drying to source as it's Christmas and everybody is shut.
Hope this helps
Craig...
Posted on Dec 28, 2007
Broken door spring
This should not be hard to replace. It would have helped if you had provided the model number of the dishwasher.
You need to buy a replacement spring (best to get the pair) which looks like this item.
BAUMATIC DISHWASHER TG5 DOOR SPRING for BDS461SS
To replace you need to locate the second spring on the other side of the dishwasher and remove it. The front base plate needs to be removed first to get access to the spring anchor points. Use a screw driver or a nose plier to grab it and dislodge. Always make sure the door is shut to ensure least tension in the springs. Put the two new springs and close the base plate. MAINS POWER CHORD SHOULD BE TAKEN OUT FROM SOCKET WHEN WORKING ON THE DISHWASHER
Aug 07, 2014 | Baumatic Dishwashers
Keeps stopping
sounds like the timer is bad
Jun 29, 2010 | Baumatic 23 in. BDW9 Built-in Dishwasher
Door rope replacement.
Check the old one. Fasten it in the same way to the rope with the correct rope length.
May 20, 2010 | Baumatic 23 in. BDW9 Built-in Dishwasher
My left hand side door cord has broken, how much of the machine do I need to take apart? do I need to pull the machine from under the counter top?
Yes you will have to move from under worktop and then remove the side panel that the cord has broken.It may be worth checking the other cord and replacing both if worn.Also check if something is catching to cause the cord to break.
Hope this helped.
May 16, 2010 | Baumatic 23 in. BDW9 Built-in Dishwasher
My Baumatic bdw9 dishwasher's door is leaking from the bottom, I dont know if it is over filling or the door seals have gone, any help would be appreciated
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Dec 26, 2009 | Baumatic 23 in. BDW9 Built-in Dishwasher
Right hand side nylon spring cord guide broken when cord snapped and now door return has no tension.
Searched for a nylon rope guide for a Baumatic BDW 9 but was unable to locate one. I found that many of the components for the BDW 9 also fitted the BDW 10. So I searched for the rope guide for a BDW 10 and found the correct product. Problem solved!
Nov 15, 2009 | Baumatic 23 in. BDW9 Built-in Dishwasher
Baumatic DW9
Hi - You can download the manual by clicking the link underlined in blue below:
Baumatic DW9
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 10, 2008 | Baumatic 23 in. BDW9 Built-in Dishwasher
I need to reset my dishwasher but don't know how!!
If it's any help then here is the link to the user manual (when you download it it applies to bdw13 as well even though it is labelled for the bdw14) http://www.baumatic.co.uk/products/discontinued-models/dishwashers/integrateddishwashers/BDW14 Best I could come up with is to try page 19 at the bottom of the "dishwasher doesn't run" section - there are two different types of reset which may do the job. Hope this helps :)
Mar 13, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic 23 in. BDW9 Built-in Dishwasher Logo
220 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
