Question about Roper REX4634KQ Electric Dryer
Banging sound while running - Roper REX4634KQ Electric Dryer
  • Roper Master
  • 7,482 Answers
The banging sound your hearing is normally caused by drum rollers having flat spots on them or in need of lubrication.
If it is a front load machine you will need to remove the front of the machine off, then that will expose the drum and belt...then remove the drum and belt and the will expose the drum rollers...
I hope this helps
Posted on Sep 29, 2009
Mazda b3000 pick up truck had loud clicking sound from dash behind airbag panel, while engine was NOT running. Lasted about 10 minutes and stopped.
Sounds like the recirculation door on the cabin air filter access.
Does the noise go away if you turn auto climate off and just choose recirculate or non-recirculate (one or the other). Sounds like the door is off the gears and that's whats causing all the clacking. and is probably happening because when you have it on auto or fresh air mode it is attempting to close the door, and one of the gears is probably broken and it is slipping causing the bang bang bang sound of plastic on plastic.
will go to recirculate to shut off vent to outside when you power off.
Hope this helps a little.
Just use recirculate mode if you don't want to pay to have it fixed. $$$
Jan 09, 2018 | Mazda Cars & Trucks
I just had a new COZY L.P. GAS CDV336C installed... Every few minutes it makes a loud bang noise...It then makes pinging noises that gradually fade out...This happens 2-4 times every hour. The bang is loud...
Hi Loretta:
I'd contact the installer. This sounds as if there may be a slow leak. When the gas concentration is high enough it will ignite which would be the bang that you hear. The popping sound could be the flame at the leak source point re-igniting for a few times.
DEFINITELY CONTACT YOUR INSTALLER OR GAS INSPECTOR. THIS IS A SAFETY HAZARD.
Mar 11, 2015 | Dryers
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
Why does my frigidaire electric dryer make a banging sound when running
Because the dryer bearing is mostly probably gone. i worked on one with a similar problem and video taped it. I put a service manual and other things there too
Frigidaire repair page
Jan 14, 2013 | Dryers
I have changed water pump, thermostat, and radiator. my car still running hot. sound like a banging noise as it heats up.
First check that the cooling fan is operating properly. The bang may not have anything to do with the overheating.
Mar 12, 2011 | 2005 Pontiac GTO
IN A 1993 BONNEVILLE SHOULD THE HORMIC BALANCER SPIN PART WAY AROUND WITH THE BELT OFF? AND WHY WHEN IT'S RUNNING DOES IT MAKE A BANGING SOUND
You should change the balancer .They should NOT spin . The banging sound is the engine not balanced.
If left too long you can break crankshafts
Apr 05, 2010 | 1997 Pontiac Bonneville
My bran new acer laptops webcam will not work
What operating system are you using.?
Sounds like driver issue.
Goto start -> run -> devmgmt.msc and lookout for devices with yellow bangs, if you see a yellow bang or red cross that means u need to installll drivers.
Mar 28, 2010 | Acer Computers & Internet
Bang, Bang, Bang. That is the sound my dryer
try taking yoga classes and put your dirty yoga clothing in the dryer and that should calm her (meaning your dryer) down.
May 06, 2009 | Dryers
Dryer banging
the drum rides on rollers it sounds like the rollers are bad
Nov 29, 2008 | Maytag Dryers
Roper REX4634KQ Electric Dryer Logo
79 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
