Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Hi my Printer isn't working... I added new Ink and it keeps telling me that paper is jamed.... what can i do and how do i solve it... Also were do u put the paper in the top or bottom.. ... And how do you get it 2 print do you have to press any buttons....... Thanks
SOURCE: Epson stylus photo R1800 printer
http://www.fixyourownprinter.com/forums/printer/35608
this website will answer all your problems
Posted on May 27, 2008
SOURCE: I Have An Epson Stylus DX6000 Printer Problem
Yes I had the same problem. Well we looked online and found the answer. Pick up the printer and shake upside down (Carefully) and an EPSON badge fell out. On reboot of the printer the error E-04 solved. Printing happily. Well it worked for us.
Posted on Jul 24, 2008
SOURCE: Printer will not print ,paper comes out blank
Put new in cartridges in printer.
Page prints out blank.
Have cleaned the print heads 3 times.
Need help!
Posted on Dec 01, 2008
gwbm
  • 353 Answers
SOURCE: epson stylus c42 plus
If both red and green lights are blinking, it usually means that your waste ink pads need replacing. This requires dismantling of the printer and resetting of the protection counter. If you feel up to it, respond with your e-mail address and I will send you instructions - but it's not easy.
Posted on Jan 31, 2009
  • 7 Answers
SOURCE: paper jam in printer
Check the path path by pulling out the cartidge/ drum unit, the tray(s), and check the fuser(hot, turn off the printer and let it cool!) in the rear of the printer there is an access door(green/ blue tabs show where to open and look:).   If your still showing jams sometimes a sensor (small black arm) is dirty (blow with compressed air), out of place, snagged, or faulty.
 Blow compressed air around the arms and look at the sensor arms. They should be able to move freely. (paper can get torn and wrapped around the sensor arm causing a fault: tweezers and patience)
Turn on the printer and see if that works for ya.
The only other jams come from the feed tires not being able to pick up the paper or the resist pad/roller being worn out and letting two sheets or more in at once (but this doesnt sound like your problem).
Much luck
Posted on Mar 19, 2009
I put paper on my hp printer and keeps jaming up wht can i do to fix tht problem thank you get to asap thanks again
60 Second printer paper jam fix by hp technician solves feed ...
? 4:56
www.youtube.com/watch?v=BdFvyDZmiFI
Oct 25, 2011 - Uploaded by BrokenPrinter1
60 Second paper jam fix by hp technician how to solve feed ...I've been trying to figure out why my printer has been jammingfor days! Days I ...
Fixing a Paper Jam - HP Deskjet 3050 All-in-One Printer ...
? 12:07
www.youtube.com/watch?v=suiQgoH-8cM
Jul 5, 2011 - Uploaded by HP Printer Support
My hp printer was working great until yesterday when I seemed to be taking ... I was able to fix the paper jam error on my friend'shp desktjet ink ..
Oct 20, 2015 | HP Office Equipment & Supplies
I just replaced an ink cartridge and the printer keeps telling me to load paper then press OK, but I already have paper loaded. The machine keeps trying to pick up the paper, but unsuccessfully.
Hi, Please check the paper and the paper tray. The paper or the the paper tray is inserted properly. Turn off the printer and turn it back on after 10sec. and try to print that should work. Please get back to us if this information helps you solve the problem.
Jul 07, 2011 | HP Photosmart C5580 All-In-One InkJet...
When i print the documet the paper torn & jame . i pick out the ink also same problem
Please check if there is a little piece of paper blocking the paper path or a part of the printer is not properly in place... try to print and when the paper jam turn off the printer and look on to the paper the lead edge of the paper what is blocking. I hope this information might help you solve your printer problem.
HRH
Jan 03, 2011 | Office Equipment & Supplies
My paper keeps jaming
paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
Nov 09, 2010 | Brother MFC-3240C All-In-One InkJet...
Hi I've got an epson stylus dx4400 printer. The printer is a little strange because two of the ink cartridges are reading full, even though one of them is completley empty and the other is about a quater...
There is no sensor that reads actual quantity of the ink in the printer. The measurements are based on calculations how many pages are printed and what has been printed after last ink cartridge replacement. Probably the printer has been tricked that there is a new ink cartridge, but there is the old one.
Often a small object can fall in the paper tray and go down the paper path, preventig paper from picking up and moving. Rotate the printer with the front side up and try with thin and long flat skrewdriver to rise the thin long rollers that hold the paper to the feed roller, one after another. These rollers are held there by springs. If someting is stuck behind them, it should fall down. I've found there coins, pensils, rullers, paper-clips and so on.
Jun 15, 2010 | Office Equipment & Supplies
Keeps telling me the paper is jamed
Hi there
You not say what printer you have but with some printers you are able to try this.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 09, 2010 | Office Equipment & Supplies
Error 2,114,0
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Mar 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Help! New ink instaalled, both lights flash back and forth.....
Hi luverlynne,
Hi there have you tryed to to see if the paper is jamed if not them try to take the ink cartriage out to give the cartriage head a clean with a tissue then reinsert the cartriage back in. if that dont work then uninstalll and reinstall the printer drivers.
Jan 15, 2008 | Epson Stylus C40UX InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
