Question about Dishwashers
Water coming in stops short of the proper level - not enough water comming in to clean properly. I have to add water.
    Problem Solver:
  • 5 Answers
Most dishwashers fill level is determined by time.
If the water pressure is to low, or the flow is restricted by sand or rust cloging the water valve, the unit will not fill with enough water to clean the dishes.
if you are willing to try, and you can use basic hand tools, you might be able to clean a clogged water valve.
first make sure the ELECTRICAL POWER to the unit is up-plugged or turned off. turn off water supply.
Valve is located under unit most can be reached by removing panel on lower front of unit. disconnect water pipe at valve and look for a filter screen inside the valve, remove it, clean it, reinstall it. now reconnect water pipe, and turn water and power back on look under unit and check for water leaks before reinstalling panel.
Posted on Sep 29, 2009
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
Water level adjustment
If it has a ballcock bend the ball upwards till you have a high enough water level
Nov 26, 2013 | Toto Home
Is there special directions to put coolant in?
Welcome to FIxYa.com
How to Fill Coolant
If the coolant system has been flushed, first add 100 percent ethylene glycol in
the amount listed for the appropriate engine application. Then slowly add clean
water to the system until the level of the coolant mixture has reached the base-of
the radiator neck. Wait for two minutes and recheck the level of the coolant
mixture. add clean water if necessary to restore the coolant mixture level to the
base of the radiator neck
When refilling the engine cooling system, add three engine coolant supplement
sealant pellets, GM RN 3634621 or equivalent, and GM approved new Ethylene
Glycol Coolant DEX-COOL GM RN 9985809.
If the cooling system is being refilled ONLY (no flush), a 50 percent ethylene
glycol and 50 percent clean water mixture should be used to fill the system. Fill
the system until the level of the 50150 mixture has reached the base of the radiator
neck. Wait two minutes and recheck the level of the coolant mixture. add a 50/50
ethylene glycol water mixture as necessary to restore the coolant mixture level to
the base of the radiator neck.
Install the radiator cap making certain the arrows line up with the overflow tube.
Close all air bleeds. DO NOT over torque the air bleed valve. The air bleed valve is
made out of brass.
Fill the coolant reservoir with a 50 percent ethylene glycol and a 50 percent clean
water coolant mixture. The proper amount of this mixture to be installed into the
coolant reservoir is listed below:
Add 0.65 liters (0.68 quarts) of a 5010 mixture of ethylene glycol and clean water
to the coolant recovery reservoir.
CAUTION: The low coolant indicator lamp may come on after this procedure. After
operating the vehicle so that the engine heats up and cools down three times. if at
any time the "TEMP' warning indicator comes on. Immediate action is required.
Air bleed vent is at the thermostat house
Thank you for using FixYa.com
Regards, Lee Davidian
Nov 09, 2010 | 1997 Pontiac Grand Prix
My humidifier all of a sudden just stopped working. Can you tell me of any common issues and their remedies for this humidifier ?
From the troubleshooting section of the manual (http://www.crane-usa.com/manuals/HumidifierManual2008.pdf):
Problem Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Solution Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float ? If humidifier does not work at all: ? Ensure it is properly plugged into a power outlet. ? Check that the switch is in the ON position. ? If Power On indicator light does not come on, bring to authorized service station.
Nov 01, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
Doesn't clean dishes .I rinse dishes off before putting them in dishwasher.This is the 3rd time I have washed them and they are still really really dirty.I checked all the lines under my sink to see if...
water temp plays a big role in proper washing the temp coming into the machine has to be a minimum of 120 degrees.
next thing to check is proper water level,there should be standing water in the bottom of the dish washer when it has completed it filling cycle.
try and add some water with out over filling the machine once the fill cycle has stop then run it through again and see what happens.
the main wash motor may have to be replaced
Apr 09, 2010 | Dishwashers
Water not filling.
r u using auto fill mode?if u r then try selecting high medium or low. check water pressure coming out of inlet hose, could b faulty valve not letting enough pressure thru.please reply if u need more help
Mar 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
The top does not wash and the bottom some what works. no water pressure
First thing to check is your in coming water pressure and temp.The internal water temp has to be at least 120 degrees to properly clean the dishes.
Second after the machine has stopped filling with water open the door and look at the water level in side you should have 1/2" to 1" of water and it should be hot.
Third if there is not that much water add a few cup fulls off water unit the whole bottom of dishwasher is covered in water. Then start your machine and let it go through a cycle.
If your unit cleans the dishes then you may need to replace the water fill valve,if it does not clean the dishes and the results are the same you need to replace your main wash motor.Remember water temp has to be 120 degrees.
I hope this helps with your dishwasher and you get it fixed fast.
Feb 06, 2010 | Dishwashers
Too little water comes into machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work properly. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Dec 29, 2009 | Bosch Washing Machines
Ford escort temperature gauge going into the red enough water in the radiator
you need to see if the fan is working properly,eg;you can feel air being pulled through the radiator,or if its electric does it turn on and run quickly enough.It may even be the thermostat is not working properly,it could even be the water pump impeller(like propeller,pushes water through system)is corroded and water doesnt flow properly,but you can see by taking the radiator cap off and running the engine and holding the revs up and you will feel the water flowing past your finger ...pumps probably ok,try these things ,,,good luck
Nov 20, 2009 | 1998 Ford Escort
Hobart lxih
E4 indicates water level has not reached top water sensor. Check for proper flow-water pressure to machine (15-25psi) and clean sensor in wash tank
Jul 16, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
Owen Barnes
