Question about Whirlpool Duet GHW9150P Front Load Washer
I am getting dl /f message, What do I do.
I am getting dl/f message, I have never had a problem with my machine. We checked the conection, and fuses, All seem to be fine.
The last load I did was a drain and spin load.
  • 6,784 Answers
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.(Door lock assembly)
Posted on Sep 29, 2009
Testimonial: "Your advice was very helpful. Thank you. Cinnimom3"
I have a dl error message on the screen
You don't say what type of machine you have, but dL often times means that there's problems with the door lock, or most often, the control board in the machine is not getting the signal from the door lock (bad connection)
Dec 23, 2010 | Washing Machines
Cant get dvd player to work on samsumg 6
check the cable and conexion that worked good.
check region dvd format/image for example ntsc or pal
check region tv format for example ntsc or pal
conect your dvd in other tv or lcd or crt and checking
conect your dvd in audio component or home sound
oh, read step by step the manual of tv and dvd manual...
bye....
Mar 07, 2010 | Samsung LA40A450 40 in. LCD TV
Getting message F DL. ASSUME MEANS DOOR NOT
IT APPEARS YOU HAVE A MAGNETIC CONTACT FOR THE DOOR,YOULL HAVE TO HAVE A REPAIR MAN REPLACE THAT CONTACT,
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dl error message
This is a door lock error. Unplug the washer and inspect the lock and latch. If all appears well, check the wiring connections to the switch, and where thay connect to the brains. Also check that the lock and latch are tight. Tighten any loose fittings and connections. Usually the lock is at fault, but it can be the brain.
Best regards, --W/D--
Aug 09, 2009 | KitchenAid Washing Machines
Although the battery is brand new my v-strom dl 1000 wont start unless I jump-starting it conected to my car, reagrdless how long I do ride it for, as soon as I stop it and turn the key off it wont start...
It seems that your bike's battery is not getting charged while running, but if your Headlights are working then the Dynamo is OK but the rectifier/battery charging has conked out. It might be just a blown fuse or it could be in the rectifier coil/circuit. It would be best if you could get it checked from their authorized service center and get the part replaced since you said that the bike is brand new & even the distributor from whom you bought it should take responsibility for a faulty piece of equipment.................sodeep
May 08, 2009 | 2002 Suzuki DL 1000 V-Strom
Error code on the washer machine
DL/F is a door unlock error the door lock may be broken.
Mar 18, 2009 | Whirlpool Washing Machines
No power to ignition 96 camero dl
Check the wires to the distributer or to the modules could be poor or no conection. If you can turn the car over but no spark it's probably something to do with ignition, distributer, module, or wiring to the ignition.
Dec 28, 2008 | 1996 Chevrolet Camaro
Error message SC565
Check the connections on the contacts where the fuser unit plugs in for any possible broken pieces or connectors.
Oct 16, 2008 | Ricoh Aficio SP C811DN-DL Printer
Sony RDR-HX710
Check whether the discs you are using are compatible with the machine. I've just had the same problem using 8x DVD+R DL (Double Layer) discs, and after checking the users manual found that the machine only supports 2.4x DVD+R DL. I am now trying to find out if there is some sort of firmware upgrade available.
Sep 06, 2008 | Sony (RDR-HX710) DVD±RW Dual Layer...
What do I do for dL and F error message?
same problem..for a couple months I could get it to work intermittently but finally gave in and the repair guy is here putting in a new control panel. expensive sorry to say.
Jul 17, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
83 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
