Question about Sharp Audio Players & Recorders
CD player changes disks, but doesn't play any of them. The disk player changes from one to another. All (I hope) dust has been blown out. Removed player however everything seems to be OK. Do not have manuel. System was manufactured 6-94.
  • scootslee Sep 29, 2009
    Sharp is the manufacturer, model SG-A350AV (BK), System consists of 5 disk player, synthesizer tuner, integrated stereo amplifier, and stereo cassette deck.
  • 615 Answers
I am sorry but I am getting a very little information from your post…it say that unit not working and moving…could you please post more information that can helps everyone reading the post and safe everyone time? Name of Manf., model #, type, etc.so I may be able to get copy of the user manual
Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
Posted on Sep 29, 2009
  • showme41507 May 22, 2011
    hi my name is rick im having the same problem it skips thur all 3 disc but wont play them????
    model CD-C420 serial no.71276827
    manf. in dec97 sharp 3 disc player you can write back to showme41507@ yahoo or ill check back on here thanks foryour help
What is wrong with my CD player?
Great player. Although the manual does not say a thing about this error, I'll try.
I think you use normal CD's and not disks you or someone burned for you.
The only thing I can think of is the CD must be dirty to scratched.
Or if you try to play disks, burned in a PC, that could cause trouble too. Although all CD and DVD burners in a PC, can play these disks, not all CD players can. Only the ones where the manufacturer says the drive is compatible with CD-R and or CD-RW.
A normal CD has metal as a reflector and gives a clear image from the ones and zeros on the disk. CD-R and CD-RV only have a dye on which a laser has changed the colour. Not giving a clear distinction between ones and zeros. The better CD players, have a stable motor and so on, but the laser is not set up for the dye disks. And although sometimes a disk can be played, for the player it looks lie a "dirty" disk.
I hope this helps.
If not, perhaps you should clean the laser, with a special cleaning disk. DONT open the player and DONT touch the laser.
Jul 25, 2014 | Cambridge Audio Azur 840C CD Player
Toshiba DVD SD73000KU will not recognize ANY disk
hi
have you been tried to clean the lazer lens with a cd lens cleaner. if doesn't work you can do with manual cleaning using a fiber cloth moist with alcohol damped gently the laser lens which may be dirty causing not to detect a disc. now if those tries still doesn't work your last option to make an adjustment on the speed settings of the drive motor. at the lower portion of the lens their is a trimmer adjustment, you can used a small flat head screw driver then try to adjust the trimmer just a little bit counter clock wise, make sure the player is unplugged for safety. then try to plugged it and turn on the player, insert now a cd and observed. if the motor doesn't rotating, removed then check if worn out, replaced a new one if needed.this will worked now.
hope this will helped thanks for consulting the fixya.
Dec 25, 2011 | Toshiba Televison & Video
I had bought a regular cd from hmv with music on it & when i put the cd in the cd player,it wont play & reads NO DISC also does not reads the amount of music on the cd,why does it give me this...
1. Check that the disc is free of scratches and dirt or dust. If the disk is dusty, use a soft, lint-free cloth and wipe the disk gently, using straight strokes from the center of the disc to the outer edge.
2. Make sure that you are inserting the disk with the plain, reflective side down.
2. Try listening to another CD (not burned) that you have purchased. If the other cd is giving you the same error message, return the cd player to the store, because it is defective.
3. Ensure that the disc you are using is not a DVD disc. It is easy to confuse the two.
Hope that helps! Good Luck!
Mar 13, 2011 | Panasonic SL-SX420 Personal CD Player
When i put a cd in the player it says bad disk and when it does play it just stops in a middle of a song and freezes what can i do
Generally this is caused by lint or dirt on the lens of the disc player.
In order to resolve this you will need to buy a cd cleaning disk.
They are about $10 and they have tiny brushes on the bottom of the disc to remove dust from the eye of the laser that reads your disk. Just follow the instructions after you put in the disc.
Hope this helps!
Aug 01, 2010 | Car Audio & Video
Will not play. message is Dirty Disc.
If this player has been used often you may need to run a cleaning disk thru it.It is just a CD disk with little brushes glued to it.This is to brush the dust off of the optical pick up lenz inside.I did have a sony 5 disk that conked out after 3 years and was very seldom used.Well hope this helps and good luck.
Mar 14, 2010 | Sony Televison & Video
2001 Lexus LS430 6 Disk CD Player ''CD ERROR''
The sixth place is where the cd that was being played has to be put before it can take another cd to play. there should be a reset button some where im not sure where yet but I will find out and let you know shortly.
Aug 27, 2009 | Car Audio & Video
I got a Adobe Acrobat 8 Standard CD and trying to
check the CD for defects, or dust, there are commercially available kits for repairing scratched, or damaged disks, as long as the " silver " looking portion of the disk is intact.
You may be able to download the software directly from Adobe and install it using your installation code.
Mar 05, 2009 | Adobe Acrobat 6.0 for PC
VCR will play, DVD returns disk with"check disk"-will not accept
Dirty or defective laser lens. try manual cleaning of the lens if you know how to open the unit top cover. manually clean the lens using cotton swab gently rubbing it in circular motion. blowing of air to remove dust will not really help clean the lens.
Jan 03, 2009 | Samsung DVD-V4600 DVD Player/VCR
No play
Sounds like the drive belt that spins the disk is slipping or broken. You have only one actual cd reader so no matter what slot the disc is in it has to go to the same cd reader drive.
Hope this helps...
Dec 27, 2007 | Technics SL-MC7 110-Disc CD Changer
CD player stops to read disk two and nothing happens and won't play cd's
there could be a wine gum jamming it up honest i had the same trouble hope my knowledge helps u
Jun 30, 2007 | Emerson MS3100 3-Disc CD Changer
504 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
