Question about Yamaha RX-V650 Receiver
The unit will not turn on, checked the plug fuse and internal fuse. there is 240 into the unit
My Simpson Esprit oven is not supplying power to the heating element. The fan and light run normally but no heat. Do these ovens have an internal fuse for the element? I checked the element for continuity...
Check to make sure that there is 120 volts from each oven wire seperately. Together they should be putting 240 volts to the oven unit. Do you have a fuse box instead of breakers in your home? It could be that one of the two fuses is bad. The oven needs two legs of 120 volts to heat up. Usually there is no internal fuse on a stove, just on clothes dryers.
Jun 10, 2010 | Kitchen Ranges
Turned on for a second, shut off, wont come back on
Ouch! This is not looking good for for this A/C if you were somehow able to plug it into a 240 volt outlet. Very few of these appliances have fuses or other overvoltage / overcurrent protective devices built in.
Electrical outlets are designed to reject plug connected appliances that (1) draw more current (or amps) than the circuit can safely provide, and / or (2) those appliances that operate on a different voltage than available at the outlet. So, it would be pretty hard to get a 120 volt appliance to plug into a 240 volt outlet - UNLESS you have "modified" the plug's prongs. Tearing out ground pins and / or twisting blades with pliers definitely falls into the "modified" category. It can also happen if a "handyman" installs a 120 volt configured outlet on a 240 volt circuit and simply tells you it is 240 v, not 120 v.
The compressor motor is probably toast, as are any electronics used to control the unit. Nothing is unrepairable though - it just comes down to how much you are willing to spend on fixing a 3 year old unit - compared to the cost of brand new.
I hope this helps - and good luck!
Jun 07, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
Dryer will not turn on. It is a electric dryer and YES unit is plug into the wall. PLease help?
the dryer is 220/240 volts check the (2) fuses that supply electricity to the unit.
Dec 23, 2009 | Whirlpool Dryers
Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Nov 28, 2009 | Sony SA-WX700 Subwoofer
How do I remove the built in oven to replace the
there are no internal fuses, chk your houses main power panel and stove plug to make sure you have 240 volts for proper unit operation
Nov 03, 2009 | KitchenAid KEBC107 Electric Single Oven
No power to the unit at all
recheck the breaker first put off and on if still same status then there is a fuse inside but check again the breaker or switch before
Sep 02, 2009 | Heating & Cooling
I have a REX3514P0 Dryer. In the middle of drying, it stopped and won't turn back on. Has the thermal fuse blown? If so, how do I fix or replace it?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail are inside the rear cover. On the blower housing to the left is a thermal fuse (white plastic) about 1.5" long. Can be continuity checked easily. Always disconnect wire on one side of what you are testing. Will likely be open.
The thermal fuse usually fails due to poor air flow. Always check internal air flow, Filter, piping and blower, as well as vent pipe inside home. If internal piping seems clear be sure flow to outside is nearly as strong as air flow with dryer disconnected from wall.. Good Luck
Aug 27, 2009 | Roper REX4634KQ Electric Dryer
Oven and burners will not heat up
have you checked your fuse/breaker panel for 120/240 volts and again at unit plug,sounds like you lost one leg of the 240volts and you only have 120volts and if its on the clock and timer side they will still work,but need 240 to heat elements fully
Jul 06, 2009 | Kitchen Ranges
Amana Comfort Zone will not turn on.
Power coming from circut board? If yes, check the capacitor. Low voltage fuse good? Transformer good?
Jun 08, 2009 | Amana Comfort Zone 12M32PBEH Air...
Yamaha RX-V650 Receiver Logo
278 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
