Question about HP Photosmart C6280 Printer
Will not print - HP Photosmart C6280 Printer
    Problem Solver:
Turned everything off, uninstalled and reinstalled Photosmart C6280.
Now prints!
Posted on Sep 30, 2009
Why does some txt print when using ctrl shift print to print a document or email and some lines do not print at all?
There are two way email e-print.
A> Open email and select print area and see preview, if preview ok then you given print. If not ok then go to printer setting option and set printer paper or text. Then see print preview if ok then given print.
B> Second option is copy email print job any doc file or then print select and command given. But print before also check it print preview.
If any issue create i share a print related problems link please visit and read it. I hope solved your issues.
Source..ePrint Job Did Not Print
Thanks,
HP Phone Number
Jun 23, 2014 | HP Officejet Pro 8600 e-All-in-One Printer
I have a pixma mp630 and i want to print just one page from multiple page in a document how can i do it?
Move the cursor to the page you want to print. Then click File - Print then in Page range select Print Current page - then click OK to print.
May 04, 2011 | Office Equipment & Supplies
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
What is the usual maintenance and wear & tear for a Canon Color Imagerunner C3220 copier?
Durables for IRC3220
[1] Waste toner container - 60,000 prints*
[2] Secondary transfer outside
roller (120/230-V)-300,000 prints* actual number of
prints
[3] Transfer cleaning unit 100,000 prints*
[4] Fixing roller 100,000 prints* actual number of
prints
[5] Pressure roller - 100,000 prints* actual number of
prints
[6] Transfer belt - 300,000 prints* actual number of
prints
[7] Drive roller 300,000 prints* actual number of
prints
[8] Primary toner roller -300,000 prints*
[9] Secondary transfer inside
prints
[10] Feed roller (each cassette
holder)
250,000 prints* actual number of
prints
Jul 15, 2009 | Canon Office Equipment & Supplies
Pls help in this VB code, Sato CX400 barcode printer
jst try this u create a label from label printing software using ato font then make a prn
then attach u r vb code in to prn it will work
rohitjain
prn example-------------
A
Z
A
CB+18
Z
A
CD250,3300
Z
A
AR
Z
A
A100950647
Z
A
%2h416v0072BG01031>H23456111
%2PSP02h573v0021L0101XS922
%2PSP02h618v0021L0101XS18K
%2PSP02h415v0089L0101XS17125
%2PSP02h416v0039L0101XSPO124
%2PSP02h416v0022L0101XS215gms
%2PSP02h618v0043L0101XSDR37/0.20
%2PSP02h618v0064L0101XSDR37/0.20
%2PSP02h618v0085L0101XSDT/B44/0.82
Z
vb code example------------------
Open "LPT1" For Output As 1
Do While rs.EOF = False
For I = 1 To Val(Text1.Text)
Print #1, "A"
Print #1, "*&"
Print #1, "Z"
Print #1, "A"
Print #1, "CB+18"
Print #1, "Z"
Print #1, "A"
Print #1, "CD250,3300"
Print #1, "Z"
Print #1, "A"
Print #1, "AR"
Print #1, "Z"
Print #1, "A"
Print #1, "A100950647"
Print #1, "Z"
Print #1, "A"
X = "%2h380v0065BG01031>H"
Y = rs.Fields(6).Value
X = X + Y
Print #1, X
Print #1, "%2PSP02h618v0085L0101XSKT"
Print #1, "%2PSP02h600v0085L0101XS", rs.Fields(1).Value
Print #1, "%2PSP02h618v0064L0101XSNetWt"
Print #1, "%2PSP02h600v0063L0101XS", rs.Fields(2).Value
Print #1, "%2PSP02h618v0043L0101XSDiaWt"
Print #1, "%2PSP02h600v0041L0101XS", rs.Fields(3).Value
Print #1, "%2PSP02h618v0021L0101XSColWt"
Print #1, "%2PSP02h602v0021L0101XS", IIf(IsNull(rs.Fields(4).Value), " ", rs.Fields(4).Value)
Print #1, "%2PSP02h430v0084L0101XS", rs.Fields(5).Value
Print #1, "%2PSP02h371v0028L0101XS$"
Print #1, "%2PSP02h405v0028L0101XS", rs.Fields(7).Value
Print #1, "&"
Print #1, "Z"
Print #1, " A"
Print #1, " #E5"
Print #1, " Z"
Print #1, " A"
Print #1, " CS2"
Print #1, " Z"
Print #1, "A"
Print #1, " 0000"
Print #1, "TEXT1.TEXT"
Print #1, "/"
Print #1, "Z"
Feb 04, 2009 | SATO CX400 Thermal Label Printer
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP Photosmart C6280 Printer Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
