Question about Dryers
Dryer turns on and runs gets hot an turns off smells hot and burnt. model #mde3000ayw
    Genius:
  • 1,036 Answers
It sounds as if the blower motor / fan is not working, or the ducting is blocked.
This needs to be checked ASAP as it can cause a fire risk in older models.
Posted on Sep 29, 2009
Ge duet dryer smells and is rattling
what is your model number is then we can get started then
Sep 09, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
Burnt rubber smell, dryer was overheated, smoke from back
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 11, 2011 | Dryers
Clothes smell burnt after drying
heatman101
Sep 10, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
MY VENT PIPE IS REAL HOT SMELLS LIKE BURNT PAPER CLEAN THE LINT OUT OF THE PIPE
heatman101
Apr 05, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Maytag Neptune MDE3000AYW. The start button on my dryer went out. It tried to start and then died and smelled burnt. I am guessing the switch burned up. Any thoughts on how to fix it? Thanks
sounds like motor is in a bind see if you can rotate drum by hand if you cant then your belt is hung up,or a belt pully is bad,if drum turns freely,sound like motor is going bad
Jan 23, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have the MDE3000AYW gas dryer and the roller
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 22, 2010 | Maytag MDE9316 Dryer
Smells like burnt diesel or very hot smell
Can't help thinking that either you don't have the revised operating instructions, or the "Sensor Dry System" is not working properly. Download the revised instructions here [http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6231 ] and see if this helps. Otherwise have the sensors in the machine tested.
Mar 12, 2010 | Crosley CDG6000 Gas Dryer
Just brougth used maytag neptune dryer.model MDE3000AYW
If you are connecting a power cord with a 3-wire configuration, you match the corresponding wire colors from the power cord to the wires on the terminal block in the back of the dryer. The correct color-code is as follows:
RED - HOT (120VAC)
BLACK - HOT (120VAC)
WHITE - NEUTRAL (0VAC)*
*There should be a ground strap or ground wire connected to neutral at the terminal block in a 3-wire configuration.
NOTE: If the wires are not color-coded, the outer two wires (Left and Right) are the HOT leads. The center conductor is Neutral.
If you have any questions, you can refer to this link for further explanation:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
This explains the difference in 4-wire and 3-wire configurations. I hope this helps you.
Mar 09, 2010 | Dryers
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
Burnt Rubber Smell
ok the rubber smell is your socks and underwear band,,and things with elastic in them ...ok open your dryer ,,look in the back where the hot air blows out,,,does it look like a burned iron..that where the clothe stick and melt too..just take a brillo with a little bit of water,,little dampness ans scrub the area..onthejob...
Feb 02, 2009 | Whirlpool LER7646E Dryer
Dryers Logo
115 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
