Question about Lands Phones
Plunger on 1 of my phones is broken. can i order a new plunger?
  • yitz682 Sep 30, 2009
    i do not see any NEC parts on any of these sights. Please advise.....
  • 3,741 Answers
Click this link directlyhttp://www.ttechnologyinc.com/nec.asp ----------------- also click this link for more help. http://www.twacomm.com/catalog/jmp_NEC/dept_id_354.htm ------------------ this will help.keep updated.thanks.
Posted on Sep 30, 2009
  • 11,896 Answers
You should be able to get one at amazon.com or possibly newegg.com or lastly bizrate.com
Posted on Sep 29, 2009
My Kenmore Elite dryer has power & you can select a cycle, but pressing the start button does nothing. The timer flashes and makes a buzzing sound.
Check door switch plunger, it protrudes into the switch to make contact and may be broken, if OK, check for broken door switch. Order parts from repairclinic.com
Sep 18, 2015 | Kenmore Dryers
Refill cap center plunger is broken
I dont see any other way to fix other than purchase another cap...
I ordered 2 replacement caps from here they were the cheapest tat I found http://www.jardenstore.com/productdetails.aspx?BrandId=494&pid=1783 but they seem to be out of stock at the moment These http://www.appliancefactoryparts.com/humidifiers/holmes/holmes-water-tanks.html are 3 dollars more here hope this helps
Jan 29, 2014 | Holmes Products Warm Mist HM5700...
I need the required valve & inyector clearance on a M11 engine
Cummins M11
Intake valve clearance 0.010 inch
Exhaust valve clearance 0.024 inch
The firing order is 1-5-3-6-2-4 and that is the order the valves should be adjusted started with first timing mark on main pulley adjust cylinder number 1 The valves and injector should be adjusted at the same time The crankshaft is then rotated 120 degrees to next timing mark and cylinder 5 is adjusted, the crank is rotated again 120 degrees to next timing mark and cylinder 3 is adjusted.then back to the first timing mark, cylinder 6 is adjusted, etc/
Adjusting nut on plunger should be adjusted to the point where you feel the plunger just reaches the bottom.of travel/bottoms out.
Feb 15, 2012 | Cars & Trucks
My porter cable c2002 150 psi gal compressor the pressure regulator is always set at 0 and no air at outlets, but the tank is fill of air 150psi. what could be the problem
According to Porter-Cable (Delta) themselves, they had lots of bad regulators on these compressors. I'm waiting for one myself. Same issue
Jul 10, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Starter motor does not spin throws the jack shaft out but does not turn the engine over
This sounds like the large copper contacts in the starter solenoid are burned. On the end of the starter, there is a pentagon (5 sided) plate. Unplug the single wire above this and remove the three bolts. Remove the plate and you'll find a spring and a plunger behind the plate. Remove the plunger and on either side of the solenoid, there are two large copper contacts. These contacts are probably burned down about 1/8" or so. Enough so that the plunger does not make contact across them. An aftermarket kit is available and it's not difficult to replace these contacts. Simply replace the old contacts with the new ones and your set to go. Just get someone to order you a starter rebuld kit for your model bike.
Apr 18, 2010 | 2002 Harley Davidson FXDWG Dyna Wide Glide
Broken screen and save contact to SIM card
u can do 1 thing connect ur mobile wit computer load SE pc suit then all ur mobile data can be saved into ur computer also phonebook
Aug 18, 2009 | Sony Ericsson K750i Cellular Phone
Hitachi NR83A air leak
Most all Hitachi nailers that use the plunger style of firing/safety mech will leak air past plunger (part #877-339) when firing, however should not leak when connected to air or resting. If air is leaking past plunger when connnected to air check following:
Remove head to reveal cylinder plate (part#877-318). Remove plate and check outer oring for nicks or broken. If nicked or broken, replace and problem solved. If in good condition, remove cylinder guide (part #877-310) and check two outer orings for nick /cut. Use caution when removing/installing cylinder guide. It is easy to pinch orings when installing causing air leak at plunger. If orings are in good shape then problem is warped body of gun not allowing outer orings to seal. To check for warped body, use the cylinder plate as a guage by lowering it into the area where the cylinder guide rests. Good Luck with your repair.
Mar 12, 2009 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Need new clutch nut and plunger
I just ordered a plunger by phoning waring at 1-800-4-waring It was just about $20 for the part and shipping.
Apr 29, 2008 | Acme 6001 Juice Extractor
Batteries out
You can reset it with holding [SF] + [M1] ( the big button with denso on it) +[0]+[PW] simultaniously
WARNING it will clear all existing programs running on it.
After you reset it you should be able to upload new software on it
May 10, 2007 | Denso Nippondenso BHT3000 (bht3041)...
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
