Question about HP L1706 17" LCD Monitor
My monitor back ground shade is yelloish is it ok showing used hours 18000 showing backlight 17000 how much its life remaining
    President:
  • 1,187 Answers
That LCD monitor has a 3-year warranty.
The lamp should last 50,000 hrs. (HP specification).
http://h18000.www1.hp.com/products/quickspecs/12271_na/12271_na.PDF
Posted on Sep 29, 2009
Testimonial: "Thank you , but yelloish shade is by default"
Dv9220us video is not working!!
well your Display is dead, internal if the key stroke below fails.
this PC is HP retired status now, no docs, or support.
what OS, XP
did you press fn+F4 key and set the screen setting to both?>
so both screens run at same time.
if the screen is dead in BIOS (you said nothing that means no text ever shows up, like hit esc key to enter bios" is gone.
next is what the flash light trick pointed add screen see words now?
yes, bad backlight, CCFL lamps? or bad back lamp inverter
do this yet. (if you see data, then LCD id good, and is a dead back lamp. all old LCD do this at 20k hours life, span.
http://pcdied.com/monitors.html#flashlighttest
fix that our use an external screen for the remainder of its short life.
its old, so, use up the "remaining life"
Aug 21, 2017 | HP Pavilion dv9220us Notebook
Tmy monitor shows the images only for 20 seconds, then it turns black.
Hi hope your monitor issue has resolved. I would suspect the problem is a hardware issue then a software setting. Since the monitor is over three and half years old, if your monitor is a LCD with CCFL back light and had been used almost every day, there may be 3 possible hardware issues. First is the internal power supply, that can go wrong due to heating problem within the monitor, this problem usually cause the monitor to display poor quality picture and may show interference lines on screen prior failure. Secondly, it may be the inverter that drives the back light, which may fail due to the safety circuit kicks in, because it involves with high voltages. Thirdly it may be the backlight itself, which is like most compact CCFL energy saving lamps that flickers or turn itself off when it reaches the end of its service life. This problem usually caused the monitor to show redness or yellowness images prior failure.
All of these can be resolved by qualified electronic repairers, all the best.
Nov 10, 2011 | Computers & Internet
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
A carpenter was contracted to repair a kitchen for $18000, the work took him 6 hours more than he has estimated and as a consequence, he earned $100 per hour less than he had estimated. how many hours had...
I will try to solve it systematically so it will be easier to understand. Note: The solution involves solving a quadratic equation.
Let amount of hours estimated be x:
Expected rate: $18000/(x hours)
Time spent extra: 6 hours.
Totals hours spent: (x + 6) hours
New rate: $18000/(x+6 hours)
Now:
18000/(x+6) x
The new rate is less than old rate by $100, therefore we can make the above inequality equality by adding $100 to the new rate.
18000/(x+6) + 100 = 18000/x
Solve by cross multiplaction:
(18000 + 100(x+6) * x = 18000 * (x+6)
18000x + 100x(x+6) = 18000x + 108000
Simplify:
100x(x+6) = 108000 (cancel 18000x on both sides)
x(x+6) = 1080 (divide by 100)
x^2 + 6x - 1080 = 0
Solve the above quadratic equation by any method (completing square, factorization or quadratic formula)
x = (-b+-(b^2 - 4ac)^.5)/2a where a = 1; b = 6; c = -1080
x = 30 or -36 (hours cannot be negative so disregard this result)
Therefore x = Estimated time = 30 hours
Check:
18000/30 = $600 per hour x+6 = 36 $18000/36 = $500 or $100 per hour less than estimated
Nov 12, 2010 | Office Equipment & Supplies
How to check the backlight life of my hp l1706
Claimed life for the lamp is 50,000 Hours, but in real life, no way to tell. You can look here what is failed in the backlight lamps, it can be from worn out (blacken ends is one sign of bad lamps, same as home fluorescent lamp), poor soldering works on the lamps. see pictures here: http://s807.photobucket.com/home/budm/allalbums
What is the problem with your monitor anyway?
Mar 30, 2010 | HP L1706 17" LCD Monitor
E1705 Monitor is black also, but can see this screen fine on tv
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 09, 2009 | Dell Inspiron E1705 Notebook
Backlight Life
Yes by leaving the laptop on all the time you could burn out the laptops back light. Set your power settings to turn monitor off after so many minutes of non use to save this. Further more I would recommend a chill pad under the laptop to help keep the CPU from getting to hot.
Jun 21, 2009 | HP Compaq Presario V5000T Notebook
Backlight is acting like a bad flour. tube .. everthing else OK
Normaly the backlights have a life of around 40k hours of working.
If your monitor is 3-4 years ,the backlight tube/s could be defective.Your description seems to indicate tube aging.
It's possible to replace the tube but needs a good amount of technical skill.
Do write if you need more help,Please indicate make exact model no etc.
Samir
Mar 22, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Acer travelmate does not work from battery
lcd going bad then and maby the power suply sending the power underpowering it overheating maby also is it getting hot on u clean it out cheak cables on it take it apart pop fornt part up out to cheak cables
Jan 01, 2008 | Acer Ferrari 4000 Notebook
HP L1706 17" LCD Monitor Logo
123 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
