Question about Mitsubishi LT-46246 46 in. HDTV LCD TV
Cable card won't initialize. was working fine...then it appears that whatever reads the cable card inside the tv went out. had cable co. bring out a new cable card...problem repeated itself. menu states "please wait while cable card initializes" this process usually takes only 20-30 seconds followed by the message "cable card is initialized" now, the "please wait" message stays on the screen for 1-2 minutes followed by that menu disappearing and the cable card still not initializing. additionally, the tv will not accept channel changes using the remote. for example, entered channel 67 followed by the enter command...nothing...tv reverts to the channel that was selected prior to the channel change attempt. when cable card is removed channel selection works again. My ?...what part is more than likely out in my tv Mitsubishi 46246 FYI, tv works fine w/a cable box
SOURCE: Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Posted on Nov 24, 2007
  • 1153 Answers
SOURCE: mitsubishi ws55809 tv tuner picture won't come on until tv warms up
www.ctechnicians.com
Posted on Dec 13, 2007
  • 126 Answers
SOURCE: ws-65611 won't power up
so will the set power up right now
Posted on Feb 18, 2008
techman
  • 3130 Answers
SOURCE: TV Won't Stay On...
fuse do not blow for no reason, th reason thy are blowing is he convrgence iC"s are going bad.
Posted on Aug 16, 2008
bobjrdns
  • 84 Answers
SOURCE: TV NOT TURNING ON
COUNT THE LIGHT FLASHES // FOR THE CODES
Posted on Oct 18, 2008
Help with HDMI cable error
switch the HDMI cable end for end, maybe try a different port
Jan 06, 2015 | Olevia 42" 242-t11 1080i widescreen hdtv...
DVD won't play
The DVD player appears to have more than one problem, I recommend it be replaced "far cheaper"
Mar 18, 2012 | Audiovox Televison & Video
Hello I hope whoever reads this can help me. I have a problem with my SanDisk 4 GB I been using it with problems I did used yesterday morning and it was fine. I wanted to use on my bigger printer and it...
Alright Alina ... try this out turn off the printer ... disconnect the power cable of the printer ... press and hold the printer power button for 30 secs ... plug the power cable back in and reinsert first a different card and if it reads the printer is fine try the card containing your father's funeral back in see if it works if it doesnt ... try plugging the card in a pc if you have .... if the pics do appear try connecting the printer to the pc and printing or doing whatever you want... the reason may be the printer is not able to hold the amount of memory on the card .....
May 05, 2010 | SanDisk 4GB Secure Digital High Capacity...
Lost BBC channels on my SAGEM PVR6200T during a retune
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Jul 06, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Can't recieve any stations
The remote would need to reprogrammed for the other devices. It loses its programming when the batteries are replaced. There may be a model number on the back of the remote or under the battery cover. With that information you can probably find the instructions on the manufacturer's website. Or you can purchase another remote if all else fails. They're pretty inexpensive.
There's nothing the remote can do that would affect your TV unless you hit one of the buttons, possibly switching to another input. Unplug the set and let it sit a few minutes. Plug it back in and go through the initial setup again. This should bring everything back to normal for you.
If you're still having problems, please post a followup comment and I'll try to help more.
Apr 22, 2009 | RCA F36690BC 36" TV
Intermittent low hum in TV/cbl mode works fine in tunner DVD mod
I switched out of the audio-out cables from the cable box to the audio in at the Denon receiver and went with a coaxial cable connection. That switch got rid of the hum. I don't understand why the initial connection produced the hum, but the unit is working fine now.
Jan 28, 2009 | Denon AVR-1908
Reading rca cables
Hi!
There is obviously a lot of background that is missing form your question, most specifically the kinds of equipment that you are using and the exact way that you have wired the components. However, I can tell you that a common problem when changing the "source" for DVD/VCR units is to also change the source settings inside the unit, which are usually accessed through the setup utility, which is usually in the menu of the DVD/VCR. To access the menu, you may have to have the coax cables hooked up, just until you change the settings to the RCA (component) cables.
Good luck, and let me know if this helps!
Bob
Oct 07, 2008 | Sanyo DVW-7200 DVD/VCR
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Panasonic TH-50PX60U 50 in
Try to open the back cover and remove the SD card cable from the connector.
Dec 28, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Female coax connector in tv bad?
Did the cable person take a reading on the signal level at the cable outlet on the wall and did the cable person check the TV setting to make sure they are correct. TV could be set on the wrong channel also.
Nov 08, 2007 | Televison & Video
Mitsubishi LT-46246 46 in. HDTV LCD TV Logo
336 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
