Question about InFocus ScreenPlay 4805 Multimedia Projector
Infocus 4805 problem
I have re-glued the light tunnel after shadow problems.I cleaned and reassembled the unit. The projector operates as it should except the fan comes on at high speed although it is on low power, then runs fine for 5 minutes, shuts down and the led flashes three times. Help!
Thank you
Make sure that the lamp plug is properly plugged. 3 flashes indicate this or a faulty lamp.
Posted on Dec 30, 2007
Replace light tunnel infocus 4805
Hi, to get the basic instruction on how to clean/fix the 4805, click on this LINK...
Thank you.
Jun 06, 2012 | InFocus ScreenPlay 4805 Multimedia...
We have a screenplay 4805 by infocus. the right third has a dark shadow over the picture? the picture is lightly visible thru the shadow.
the light tunnel under the colorwheel has collasped or the projector has been jarred, knocking the mirror inside of the lens assy. out of alignment. Either way, it will have to be repaired by a technician.
Oct 03, 2010 | InFocus ScreenPlay 4805 Multimedia...
It has a shadow on half the screen
the light tunnel has collapsed. you can get the part from an infocus service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 18, 2010 | InFocus ScreenPlay 4805 Multimedia...
Dimensions of light tunnel for infocus 4805??
if you're intent on gluing one together or making one yourself, that's a bad idea. if it's off by a fraction of a millimeter, it's be obvious in your image. if you get the part new it's under $20, and replacing it is easy. just get one from an infocus service center, like av solutions in ny. they're really good. www.avsolutionsny.com
Jan 03, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have shadowing on the edges when in wide-screen. When in normal screen the image is fine. How do I get rid of the shadow? Also, is there a way to clean the mirror inside the unit?
the only way to properly and safely clean anything inside is with canned air. as for the shadow, replace the light tunnel. you can get the part from an infocus service center and replace it yourself, or send it in for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 25, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have a InFocus 4805. Half the picture is darker
Your light tunnel may have collapsed. This is made up of 4 tiny rectangular mirrors glued together to make a tunnel.
Sep 26, 2009 | InFocus ScreenPlay 4805 Multimedia...
New Problem after fixing Light Tunnel on a SP 4805
It sounds like you have mounted the replacement light tunnel incorrectly. It is a common error. What has happened is you have the light tunnel sitting on yop of the positioning stop which is opposite from the color wheel side. If you take it back apart you will see that it's not laying parallel to the casting. if you reposition it so it is just touching where the opening is in the clamp on the color wheel side you will feel it fall into place.
Jan 22, 2009 | InFocus ScreenPlay 4805 Multimedia...
Shadow
try ot clean the mirrors first if it didnt work check the light tunnel if it is misalign realign it or replace the light tunnel hoe this would helpo you thanks
Jan 20, 2009 | InFocus ScreenPlay 4805 Multimedia...
Glass prism
Greetings,
Thanks for contacting us regarding your product questions or concerns. It appears you are wanting to know how to reach the glass prism from your 4805?
My initial question would be, why are you looking to access the glass prism in your 4805? This is a very dilicate process internally of your projector which helps it opperate. Are you trying to self-repair your projector?
Let me know. I'll be waiting for your reply.
Dec 28, 2007 | InFocus ScreenPlay 4805 Multimedia...
4805 shadow
Regluing the light tunnel i'm afraid. Not for the fainthearted.
Dec 18, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
247 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
