Question about Whirlpool Duet GHW9150P Front Load Washer
Receiving error message F06. The cycle stops. The only way to restart is to power off and on?
  • 6,784 Answers
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after three minutes.
Possible Causes / Procedure
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Replace failed component.(Motor Control Unit)-(MCU)
Posted on Sep 29, 2009
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
What does this error message mean?
Dear BreeAnn,
I would reboot the machine. That means. Turn it off pull the plug and restart or cold Boot Strap. Further open your manual and look for a factory reset. Remove the disc if it came with one and reinstall it.
Save all your creations to file if special programs are developed before the new startup. Manually assist the machine through a hand cycle. Moreover, check to see if all the e-stops are satisfied. That means switches stuck open or closed.
Blow out dust from working areas. It appears from a remote view. Having worked fine. It is a matter of oversight. I hope you get back into creating soon.
The rest of the links are search sites. If you become stumped.
Here is the most direct answer I can find for you. Become a member and place you direct information into the link after reading the reflection.
What is F06 Np Sensor Break on Baby Lock Sewing Machine Yahoo Answers
Here is an E HOW site others are drawn too for answers on that subject as well to expand an accomplishable solution.
Troubleshooting Brother Sewing Machine eHow
Here is another member offering contact sources and a direction on procedure on our network.
F06 np sensor break on brother se400
They are general links. I recommend tech support directly with a talk through. The information should reside in the manual. Fare. Well.
Jun 25, 2014 | Brother SE400 Computerized Embroidery and...
What does Error code F06 mean
Try this:
Possible Causes / Procedure1. Verify the shipping system including shipping bolts, spacers
Read more: http://forum.appliancepartspros.com/washer-repair/11384-front-load-maytag-what-error-code-f06.html#ixzz33vFGkt1n
Apr 23, 2014 | Maytag Dryers
"system error power cycle"
Disconnect the power cord and USB cable (or printer cable) for about 30 seconds then restart. That will usually clear error messages.
Jan 27, 2011 | Samsung CLX 3160fn All-In-One Printer
F06 error message with flashing remaining minutes
Here is what the manufacture says about F06 - my comments will follow these.
DRIVE MOTOR TACHOMETER ERROR
minutes.
motor.
Phil's comments--->
If you just set the machine up be sure the shipping bolts have been removed, this is the most common reason for F06.
Other than that there is some type of communication error between the three main components (motor, Motor Control Unit and Central Control Unit) or the wire connectors between the three.
If you have had the unit a while and it is not related to the shipping bolts I would recommend calling Whirlpool
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is the problem when I get F06
F/06 says: Drive Motor Tachometer Error. Check Wire Harness connections between the Drive Motor/Tachometer and Motor Control Unit and between the Motor Control Unit and the Central Control Unit. Check the Drive Motor, Motor Control Unit, and Wire Harness. Hope this machine is still under warranty! Good Luck!
Dec 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F06 Error Code
"F06" is a Motor Speed Error. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Read through the link provided and let me know if you have questions. In most cases this problem is attributed to a tachometer failure on the Motor Control Unit (MCU). If the this is the case, the MCU must be replaced.
If you require additional assistance, let me know. I hope you find this information helpful.
Sep 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I'm getting a F06 error message.
f06 is a fault in the motor controller assy, located on the bottom left corner behingd the lower acess panel. check the wiring prior to rplacing the board though
Apr 20, 2008 | Kenmore Elite 45986 Front Load Washer
Error message
OPEN TOP COVER CLEAN ALL RUBBER PAPER FEED WHEELS WITH RUBBING ALCOHOL APPLIED TO A MICROFIBER TOWEL.
THEN LOOK AT CARRIGE BAR THE BIG SILVER BAR THAT INK CARTRIDGES RIDE ON APPLY TWO OR THREE DROPS OF 3 IN 1 OIL AND TOP THE TOP OF IT AND RESTART PRINTER
Jan 17, 2008 | Epson Stylus Photo R340 InkJet Printer
Whirlpool Duet GHW9150P Front Load Washer Logo
104 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
