Question about Amana ARGS7650SS Gas Kitchen Range
WHEN THE OVEN REACHES A CERTAIN TEMPERATURE, EVERYTHING SHUTS OFF. THE DIGITAL DISPLAY GOES BLANK. THE ENTIRE OVEN SHUTS OFF. WILL WORK AGAIN WHEN IT COOLS DOWN.
    Problem Solver:
  • 6 Answers
I had this same problem...I needed to replace the digital pad, cost about $200 online and took about an hour to replace. The heat from the oven wears out the electrical components in the pad...good luck!
Posted on Oct 10, 2009
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
JTP15 Oven - Shuts down after preheating
It sounds like the module is momentarily losing power when the bake relay clicks off. Does it do the same thing when you use broil?
Post back with the complete model number and I will try to find the wiring diagram for it and we will walk through checking it.
Thanks/Mike
Nov 03, 2007 | GE JTP15 Electric Single Oven
Sears kenmore oven shuts down while in use - display board goes blank - restores 30-45 minutes later
Hello there and welcome to Fixya
This problem has actually occured quite alot on these ovens so no you are not alone
Here is what they have found out and suggested
the oven controle panel has a micrprocessor IE computer built into it that is supposed to sence the correct temperature of the oven there tests have shown that this does not happenso what happnes is that the oven will run any where from 30 to 60 min then it will go blank and shut down and will restart after the computer resets itself after 30 min or so
Now here is the tricky part when they build the ovens there is a temperature sensor that is supposed to be compatible with the controle panel when assembled and depending where the oven was made that part was the wrong part ok? so that is why they are suggesting that you have the warranty used if you still have the warranty
However if it is not under warranty what you will want to do is to have the temperature sensor tested to ensure it is accurate to what the display is saying because if it is not then you may have the wrong sensor for the oven ok
In most cases people will just go ahead and replace the temperature sensor in the oven itself and it seems to solve the problem ok
But yes there are times when it turns out to be the controle panel is at faut which means you would have to replace that part ok
So keep me posted on what you find and i can help you test the sensor if needed ok
Best regards Michael
Dec 01, 2013 | Kenmore Ovens
The oven does not stay an even temperature and there is a gas smell. The broiler works fine! Only the oven....
By the parts diagram, it looks like you have a glow coil type igniter . Generally when the oven wont keep temperature, the igniter is failing to reignite the burner. The burner comes on till it reaches temp then shuts off until the temp falls below a certain temp then comes back on until it reaches temp again and so on and so forth. Most of the time the igniter has a very small crack in it and doesn't begin to fail until it cycles several times. I would check the igniter and the safety valves and coils on the valve
Dec 15, 2009 | Whirlpool Kitchen Ranges
Oven shuts off; display blinking
If you're inclined to fix this yourself and can't find a replacement control board (no doubt that's what you need), try www.fixyourboard.com They will repair your board and return it to you with a 1 year warranty.
May 06, 2017 | Amana ACS3350AS Gas Kitchen Range
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
My Kitchen Aid Supuerba top covection oven will heat to set temp 350-400 then drop over 100 degree's but still read on digital display 350 or 400
how do you know it is dropping 100 degrees ?
If the set temperature is 350-400 the heaters will work untill the thermostat will read that the temperature is reached - after that the heaters will shut down and the temperature will drop...and after few minutes when the temperature goes below thw set point (in this case 350-400) the heaters will turn on again - this will happen for the duration of the timing you have selected (example 45 minutes)
Oct 04, 2008 | KitchenAid Kitchen Ranges
Magic Chef Oven lights and shuts off
This could be caused by a lack of air within the oven cavity, once the air is used up the flame will go out, it will then work again once it is relite, but will probably do the same again, this could be dangerous and requires on site proffesional attention. Regards Engineer
Jun 10, 2007 | Magic Chef CGR1415AD Gas Kitchen Range
Oven not working
Per this page (http://www.repairclinic.com/0078.asp#Tappan), it sounds like you need to replace your oven temperature sensor.
Feb 23, 2007 | Tappan TGF363 Gas Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
191 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
