Question about Troy Bilt Tb70ss Gas Trimmer
Weedeater will start and run at idle speed, as soon as you gice it throttle, it will cut off. Also what is the Carb settings for this mower. Thanks for you help. Hambone
smartr10U
  • 1305 Answers
SOURCE: weedeater starsts and ildes won't run or accelerate
Make sure your gas supply is fresh...not from last year...
Secondly, clean and service the air filter element... you may need to reoil it before installation...check your manual.
Disconnect the fuel line and drain it and what little is in the carb...push on the prime bulb if it's got one...
Then with a clean air filter and fresh gas... give it a start and after start, disengage the choke..
Let me know how you do..
K
Posted on May 28, 2009
#1 Taper
  • 1041 Answers
SOURCE: Troy-Bilt TB75SS 31cc string trimmer dies when given throttle.
Your carburetor needs cleaned. Disassemble carb. and spray with carb. cleaner. Make sure that the small screen is free of debris. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Reassemble and start. If this doesn't work for you then you will have to buy a carb. kit and replace all appropriate parts. If you need further assistance, just let me know.
Jim
Posted on Jun 08, 2009
  • 81 Answers
SOURCE: weed eater will idle but shutdown upon giving gas
Cleaning the screen on the muffler will help but the muffler itself is what needs burned out. This can be done with a fire or a torch. Let the muffler cool on it's own as use of water can warp it. Parts can usually be purchased at any small engine repair shop that represents Mtd. That's who make the weed eater.
Posted on Jun 22, 2009
2strokeJim
  • 577 Answers
SOURCE: I have a TroyBilt trimmer Model TB25CS 2 cycle. I
first remove your muffler and check to see if screen is plugged in exhaust..this will cause it not to rev. Also if you rebuilt your carb you neglected to pull your jets out and flush them out, pull both caps off adj screws with small screwdriver and try to adj "H" turn counterclockwise 1/8to 1/4 turn and see if it improves any if so keep turning till rpms start to slow back down then slowly turn back clockwise just till on edge of rpms speeding back up ,also did you change your fuel filter? hope this helps you!
Posted on Apr 14, 2011
rycgl
  • 1545 Answers
SOURCE: I have a craftsman 32cc
The motor dies because it is "going Lean" at that point and not receiving the influx of fuel it needs to throttle up. A couple of elementary things cause this. 1. The fuel pump diaphragm inside the carburetor is not functioning properly due to losing its flexibility. 2. The carburetor L mixture screw needs adjusting.When you open that throttle you are telling the carb, OK. playtimes over, let's go. The carb is supposed to respond with fuel from the L (idle) circuit and the H (high speed circuit) mixture areas. It dies "lean" because the fuel from the carb isn't getting to the main jet or it is insufficient quantity, because the L speed circuit is NOT contributing enough fuel
So adjust the L screw (one closest to the engine) on the carb OUT 1/8 to 1/4 of a turn. Unconventional heads on thes carbs require special tools or a little ingenuity to get ahold of them.
You may need to install a basic gasket and diaphragm kit in the carb to restore the functionality of the fuel pump and the fuel control system. Here is a carb adjustment tutorial.
http://www.zamacarb.com/tipspage.html
Posted on Jul 21, 2011
What is the setting or turns on the jet screw
both screws all the way in then back out 1 1/2 - 2 turns
hold at full throttle and start and keep at full throttle
adjust the screw closest to the air cleaner until the engine runs at full rpm easily
no slowly let off the throttle until and idle is reached and adjust the other needle ( closest to the butterfly) until it idles easily
adjust idle speed using the screw on the end of the cable
May 18, 2018 | Weedeater Garden
Cub cadet lawn mower suddenly decreases power at full throttle
check the spring tension on the carb linkage
May 11, 2012 | Garden
Johndeere c1200 weedeater
Clean air filter and check fuel lines for trash.If that isnt the problem your carb may have trash in it.Thanks for asking and I hope it helps.
Jul 16, 2010 | Garden
My chain saw will not start. I gave it to a guy who messed up the carb adjustments. Need to know the initial carb setting.
Turn both jet screws CW to stops (lightly), then back each out CCW 1-1/2 turns. This is a basic setting and should allow the engine to start and run. Start the engine and allow to warm up, then pull the throttle full on. Turn the H needle CW until the engine starts to speed up, but still 4-strokes. Correct adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle so that the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jul 11, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Chain saw carburator settings for husqvarna 61
Turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow the engine to warm up, then pull the throttle full on. Turn the H jet screw CW until the engine starts to speed up, but still 4-strokes. Proper adjustment occurs when the engine is 4-stroking, but immediately 2-strokes when cutting. This gives best power and lowest heat. Release the throttle and adjust L jet CW until the engine idles fairly well, but will allow the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 06, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Dec 24, 2009 | Garden
No power fs66 stihl weedeater
Hi When you cleaned the muffler out did you also clean the carbon out of the port on the cylinder as this can be blocked as well. Also you will have to retune the carby, There should be 2 screws 1 for low speed marked l on the carby body and 1 marked h for high speed to start with they should be set at 1 & 1/2 turns out from closed the low speed you set at an idle and the high speed you set at full throttle. Hope this helps.
Aug 03, 2009 | Garden
Hyosun Scooter Carb Adjustments
Very good thought process on the adjustments. The throttle screw sets the idle speed and the air screw sets the fuel mix at idle speed. The stock setting is 1.5 turns outward. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward.
From this point you adjust the idle speed then adjust the air screw for fastest idle speed at that throttle screw setting. If the idle speed becomes faster than desired after adjustment, just reset the throttle screw and then reset the air screw.
A “very helpful” rating for this answer? Thanks!
Jun 27, 2009 | 2002 Hyosung Comet 125
Troy Bilt Tb70ss Gas Trimmer Logo
624 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
