Question about Samsung SCX 4200 All-In-One Laser Printer
Missing print The print on the bottom of an A4 document is being missed when photocopying. Only started happening about a month ago. Please help! Claire X
  • 417 Answers
Check the paper size within the menu as sometimes causes this fault.
Thanks J
Posted on Jan 17, 2008
Printing Result of an A4 Master Page is Equal to A5
The problem is with the "Automatic Paper Size Sensor" / APS sensors, which are located near LENS / CCD UNIT, under the platen glass.If you can open and remove the platen glass by yourself then open it and clean the APS sensors with soft cloth damped with alcohol. If the problem is still there, then please go to the service mode of your photocopier machine.
(Press "Utility/Counter"
press "Check Details" > STOP > 0 > 0 > STOP > 0 > 1, for service mode)
When you are in service mode then go to "System 1" and then into "Marketing Area" , When you are in this option, select marketing area "US" and then press "OK" . Now exit from the service mode and place A4 original on platen glass and check the size showing in the display.
Do not worry whatever size is showing, you will get your complete copy.Now press start button to make copies. When you will make a copy you will get your complete print out.No print area will be missing.
Best of Luck!
Apr 08, 2014 | Konica Minolta Bizhub 500...
What happens if the oil dip stick is missing for 2 months
A missing oil dipstick will not cause any issues with your engine.
Jul 22, 2013 | 2007 Saturn Vue
Bottom of borders missing
Check to see if your paper setting is A4 instead of 8 1/2 x 11. If so change it.
Jul 04, 2010 | Dell 924 All-in-One InkJet Printer
When photocopying, leftside print missing/text
it is only happned when you takes only photocopy ? or Printing... The same will be affect while printing and copying may be the problem related to Laser Supply unit, open the LSU and clean the LSU mirror with a cotton waste. Your issues must be solve....
before that pls. check your cartridge unit...
Apr 24, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Missing text and top of some text is missing
* Perform Step 2 in the following HP web link:
If the issue persists, please print a self test page from the unit and verify whether the unit prints the test apge fine. Step are given below:
  1. Load U.S. Letter, A4, or legal size paper into the input tray.
  2. Press the Setup button.
  3. Press 1 to select Print Report , and then press 1 to select Self-Test Report .
  4. Press OK . The self-test page prints.
:) Dr Tony
Apr 20, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Prints photocopies fine but pages of text have lines missing
Run a nozzle check to see if all inks printing out correctly.
Apr 11, 2010 | Epson Stylus DX6050 All-In-One InkJet...
Sending print job from pc to IR5000 prints with missing letters
I doubt it's the copier, sounds more like a application or board problem, my first suggestion would be to re-install the driver. the other would be to target the hard drive or memory/ mother board of the network of the copier
Nov 12, 2008 | Canon imageRUNNER 5000 Copier
Photocopy problem
try to check the flatbed area there's a small parts that will missing.
Feb 15, 2008 | HP LaserJet 3030 All-In-One Printer
Missing characters, missing print barcode lines
Hi, It's been a while since I worked on these, so I'll go out on a limb (as far as my rating goes) and say that the few times I've seen that happen usually results from a bad network card. Now you may not be using a network card, so if your not then I'm not really sure what would cause that to happen on the printer side. The environments that I've seen that happen in are with an AS400 and the network card just gave out. You most likely tried this, but you might want to make sure that the computer isn't using one driver for both printers. Good luck.
Aug 28, 2007 | IBM 4039 Model 16L Laser Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
50 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
