Question about Airlink Computers & Internet
Airling ar315w does not connect to cable modem (comcast) no light on wan port, reset to defaults same condition, connection works with my Belkin
Router was defective, replaced
Posted on Oct 01, 2009
How do I connect the belkin surf N300 wireless N router to my comcast modem
LAN port on Comcast modem <-- Ethernet cable --> WAN port on the Belkin router
LAN port on the Belkin <-- Ethernet cable --> network port on your computer
Apr 03, 2011 | Computers & Internet
I have Belkin N150 Rouer. My internet is Time warner. It has no connection between the modern and Belkin router. How can I set up Belkin N150 Router to solve this problem?
f the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
NOTE : IF YOUR INTERNET SERVICE PROVIDER IS CABLE FOLLOW THE BELOW STEPS
3.Under Internet WAN , SELECT the connection type as Dynamic.->NEXT
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 60 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
FOR PPPOE OR DSL CONNECTIONS
1.Under Internet WAN , SELECT the connection type as PPPOE ->NEXT
2.ENTER THE USERNAME & PASSWORD PROVIDED BY YOUR IN INTERNET SERVICE PROVIDER
3.CLICK ON APPLY CHANGES
For any advanced help, revert asap!
Thanks and regards,
MILAN
Jan 20, 2011 | Belkin Connect N150 Wireless Router...
I changed my router wep key password code and now I cannot connect to the internet; how do I fix this problem? It does not recognize the connection now and I cannot go back in to change it back to the...
This is how you reset your router.....
Reset the router to factory default With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
How to setup new router:
  • 1 Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • 2 Unplug your router and your cable or DSL modem.
  • 3 Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • 4 Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • 5 Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • 6 Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • 7 Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1.
  • Read more: How to Set Up a Belkin Router ' eHow.com http://www.ehow.com/how_2292408_set-up-belkin-router.html#ixzz19MK9oA2A
    Dec 27, 2010 | Belkin Computers & Internet
    Idk what 2 do w/ this iview netbook my daughter just got for christmas! i have comcast internet. that modem did go into my desktop but my desktop just broke so now comcast modem runs to a belkin wireless...
    Under WAN settings: Enable Dynamic and Hostname : http://www.comcastbroadband.co.in (If above settings not works clone computer MAC address and assing to WAN port) You have to wait for 3min to max.then it will works. Step 2: By default DHCP enabled and IP will assigned to your computer and all connected devices. Step:3 First time you have to login with comcast website it may computer or laptop or any other device
    Simply copy the WAN configurations from your laptop to your netbook WAN settings
    Dec 22, 2010 | ASUS Eee PC 1000HE Netbook
    Modem light keeps blinking Have tried resetting. Restoring to default settings. If I hook the computer directly to the time warner modem I can acces the internet fine. Thanks
    If the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
    How to configure the router for Time Warner?
    3.Under Internet Settings, change the connection type as Dynamic.
    8. Wait for 10 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
    Thanks and regards,
    Arvind
    Jul 04, 2010 | Belkin F5D8236-4 Router
    How do I hook up a Berklin wireless router to my comcast internet
    Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
    Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
    Start Internet Explorer on your computer.
    Connect to the web-interface inside the router.
    Run the "network setup wizard".
    Run the "wireless setup wizard".
    Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
    Surfboard Cablemodem not communicating with Belkin Wireless Routr
    If the modem is actually passing out DHCP, then you have to connect the modem to the router 4 port lan side and not the wan port. Give the router a static ip like 192.168.1.2 and you can talk to it and configure the wireless features.
    Feb 17, 2009 | Arris SURFboard SBG900 Wireless Router...
    Set up my belkin g router
    You may have to configure the belkin router depending on the type of ISP that you have.
    Basically, you can do these to configure your router:
    1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
    2. turn off the modem, router and the computer for 30 seconds
    3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
    Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
    Network switch
    Sounds like you know what you're doing... but.. based on what you've typed..
    You need to make certain the comcast cable modem is plugged into the seperate port on the back of the router called WAN and not next to the other LAN connectors.
    The network is seperate from the internet. The router acts as a firewall and shares the WAN with the LAN internally and automatically.
    I assum that you have one red light on WAN.. and three green lights for LAN..
    Jun 18, 2008 | Arris Wireless G Broadband Router (wr850g)
    Computers & Internet Logo
    82 people viewed this question
    Top Airlink Computers & Internet Experts
    Prashant M
    Prashant M
    Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
