Microsoft Windows XP Professional With Servise Pack 2  for PC
Problem for Microsoft Windows XP Professional With Servise Pack 2...
Os errer
By naseem baig on Dec 19, 2007
You can attempt to repair this file by starting windows setup using the original setup CD-ROM
Solution #1
posted on Dec 19, 2007
Not Rated)
Slimsl
Rank: Wiz
Rating: 83%, 169 votes
To repair Windows OS system files you can use SFC Command and if you wish to replace windows installation you can boot from CD and go to setup then it will detect old installation then you can press "R" key, I'm not sure that what kinda files you trying to replace so try sfc first and if not go for the 2nd option
System File Checker gives an administrator the ability to scan all protected files to verify their versions. If System File Checker discovers that a protected file has been overwritten, it retrieves the correct version of the file from the cache folder (%Systemroot%\System32\Dllcache) or the Windows installation source files, and then replaces the incorrect file. System File Checker also checks and repopulates the cache folder. You must be logged on as an administrator or as a member of the Administrators group to run System File Checker. If the cache folder becomes damaged or unusable, you can use the sfc /scannow, the sfc /scanonce, or the sfc /scanboot commands to repair its contents. Back to the top
System File Checker Tool Syntax loadTOCNode(2, 'moreinformation'); Sfc [/Scannow] [/Scanonce] [/Scanboot] [/Revert] [/Purgecache] [/Cachesize=x]/Scannow: Scans all protected system files immediately and replaces incorrect versions with correct Microsoft versions. This command may require access to the Windows installation source files. • /Scanonce: Scans all protected system files one time when you restart your computer. This command may require access to the Windows installation source files when you restart the computer. The SfcScan DWORD value is set to 2 in the following registry key when you run this command: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon/Scanboot: Scans all protected system files every time you start your computer. This command may require access to the Windows installation source files every time you start your computer. The SfcScan DWORD value is set to 1 in the following registry key when you run this command: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon/Revert: Returns scan to the default setting (do not scan protected files when you start the computer).The default cache size is not reset when you run this command. This command is equivalent to the /Enable switch in Windows 2000. • /Purgecache: Purges the file cache and scans all protected system files immediately. This command may require access to the Windows installation source files. • /Cachesize=x: Sets the file cache size to x megabytes (MB). The default size of the cache is 50 MB. This command requires you to restart the computer, and then run the /purgecache command to adjust the size of the on-disk cache. This command sets the SfcQuota DWORD value to x in the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\WinlogonFor additional information about the Windows File Protection feature, click the article number below to view the article in the Microsoft Knowledge Base: 222193 (http://support.microsoft.com/kb/222193/EN-US/) Description of the Windows 2000 Windows File Protection Feature
Was this helpful?
Yes
No
Popular Solutions for Microsoft Windows XP
Questions and Unsolved Problems for Microsoft Windows XP
Do you recommend Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC?
Answer
Answer
i have wipro laptop model no 7B1110, which was formatted , now i want to install drivers couldnt... (More)
Answer
AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: Unknown... (More)
Answer
I'm having trouble getting my Verizon MyFi card to configure on my Dell PC w/ XP or my Dell laptop... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Operating System Experts
Top Computer & Laptop Repairmen
in , HI
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
