Question about Panasonic CQ-RX400U Car CD/ MP3 Player
IM PANNISONIC HEAD DECK WANT PLAY RADEO AND WHEN
IM PANNISONIC HEAD DECK WANT PLAY RADEO AND WHEN THE AIREIL IS NOT PLAGED IN THERE SO NO POWER TO HEADDECK
Tascam 302 Tape Deck - When I press play it rewind/fastfoward
There is either a cam belt that is lose or the flywheel assist can not move the head base due to hardened grease. It needs to be serviced.
May 16, 2013 | Tascam 302 PRO DUAL CASSETTE DECK Single...
What is the bias control's function?
The Bias control is used during recording. If you turn down the bias, you will get more highs, but the distortion will increase, and then start to increase dramatically if you back off the bias more.
As far as playing tapes from different decks goes.......
1..Does the tape that you recorded on your deck sound OK on your deck ?
2..Does the tape that you recorded on your deck sound OK on other decks ?
If 1 and 2 are true, then your deck is OK.
If the tapes recorded on a specific deck sound bar on yours, but 1 and 2 are true, then the other deck is faulty.
When a deck leaves the factory, the head is aligned to a " standard " tape. By standard tape I mean a very special tape recorded in such a way, that a tech can tell if the head is out of align and "tweek " the physical alignment of the tape head..
All decks are aligned just a little differently, but fairly close to each other.
first do the mechanicals....is the head of your deck spotlessly clean ?. Use 99% pure isopropanol alcohol and a cotton swab. Never use anything metal to clean the tape head. If you scratch the head, its toast.
If your deck is clean, plays its own recordings well, and those recordings play well on other decks, then your deck is not the problem.
Hope this helps,
Rob
Mar 24, 2012 | Audio Players & Recorders
The intior lights went out and none work. I tryed to put in a new radeo and it wont even turn on. how can I fix the wirering so that it will start working and the radeo will play?
Sounds like you may have crossed a wire and perhaps blown a fuse..
have you checked your fuse box? If not, you may also still have a crossed wire or otherwise a short existing somewhere.. retrace your steps and take a closer look around you will find either a short or otherwise a wire which may be unplugged...
Ck
Feb 13, 2011 | 1998 Dodge Neon
I have a stereo cassette deck RS-TR280 which eats any tape I put in. Is there something I can do to fix this problem?
try buying a casset head cleaner. they are pretty rare now but radeo shack may carry them or can order them. also you can clean the rubber wheels that move the tape through the head.
Jan 29, 2011 | Technics Audio Players & Recorders
Poor sound clarity
get some q-tips, peroxide. power off and a cassette tape you been playing...open compartment door... poor a cap full of peroxide in cap.. take one q-tip dip in peroxide.. now take q-tip and wipe the recording head, erase head and play head (do not saturate) each tip should be black or dark brown now take another q-tip to dry the same heads and the roller... let the air hit it for about 5 min... power on insert tape press play ... how do it sound...
Aug 15, 2010 | ION Audio TAPE2PC Single Cassette Deck
Acer Computer Speakers- no sound!
Try Updating Flashplayer from get.adobe.com/flashplayer
May 03, 2009 | Computers & Internet
Losing power
mine does this too, I have the deck on my boat and on land the deck cuts out when a bass line hits or loud music comes in, cuts out at about 20 on the volume level, however, when on the water and the motor is running, my voltage is up to 14 vdc or so.. At this point, I can crank the deck up to 30-37, and it will scream , doesnt cut out or lose power just rocks. I have heard that kenwood decks are competition stereos and require 14-16vdc, but I have never found any proof of this. One thing you can do is order a battery from summitracing.com that runs higher than 12vdc. But then again im just speculating
Mar 05, 2009 | Kenwood KDC-MP538U Car CD/ MP3 Player
Cassette tape spins fast
Hi Chris..
It's not worth repairing. I would find something else in good condition
Feb 01, 2009 | Onkyo TA-RW244 Single Cassette Deck
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
DDV9475 faulty power on?
Best thing for you to doif you dont know where to start is open and check the fuses if this dosent help then contact Rio at www.govideo.com there located in Arizona in the United States Im sure theres other repair places but this is the main place Good Luck
Nov 14, 2005 | Rio Go Video DDV9475 Dual Deck VCR
Panasonic CQ-RX400U Car CD/ MP3 Player Logo
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
