Question about Panasonic KX-P2130 24-Pin Impact Printer
Print is very light and I put in a new ribbon. This printer is hooked to a parallel port on an AVAYA phone system terminal. I don't believe there is an option to download drivers. Not sure why the new ribbon isn't working as I can see the print very very light on the page.
  • pkmartens May 11, 2010
    Since I had NO manual for the printer, I just started messing with the knobs. There was a page gap indicator knob and I set that to the lowest setting and I can now see my print. I'm not sure how long the printer ribbon will last, but it did solve the problem
  • 43 Answers
Hi
Check if the ribbon is seating correctly, the Avaya PBX does not have a driver for this that is correct also some printers have a "draft"setting make sure this is off as the printer will only go once over the print in draft
Posted on Jan 08, 2010
I have two identical 4420 printers. suddenly one prints much slower than the other. What mechanism needs replacing? I don't have any manuals or anything
I think parallel port issues. Assuming your fastest printer connected to onboard parallel port. connect slow printer on pci2parallel port.
Sep 18, 2014 | Intermec 4420e Easycoder Thermal Transfer...
Dell 2330dn - my printer won't print my work. It keep reading Parallel busy. What does this mean?
How is this printer connected to your computer? Is it connected by a parallel/centronics cable, or USB, or perhaps not connected physically at all, but via network (it's a network-capable printer)?
Also, you don't specify the operating system.
I would guess, that it was installed on the LPT (parallel) port, instead of a network port, and because in reality nothing is connected to the parallel port it is producing an error (explaining why it's called busy would be long and boring).
Anyway, please either check the setting of the port to which this printer is printing (find that in Printer Properties), or be more specific as to what your current situation is.
Dec 01, 2009 | Office Equipment & Supplies
Printer prints test pages but will con print from
Has this printer ever worked? If so, what changed between its working and failing
What is your method of connection, parallel port, serial port, USB 1 or 2 ports?
Are you running stand-alone tests to it or are you printing the test page from the operating system? What operating system do you have installed and is the printer and its related software approved for this operating system?
Do you have the correct driver for this printer and operating system?
Can your PC see (identify) that it has a printer attached to it?
Don
Oct 17, 2009 | HP PhotoSmart P1000 InkJet Printer
Can not print with Epson LX-300
The USB to parallel converter does not always work.
You should buy a Parallel port for your computer if you have can extra slot inside the machine. The cost for the parallel port is usually under $20.
thanks adi
Oct 03, 2009 | Epson LX-300+ II Matrix Printer
Bought new computer - no parallel port. bought
got to printer and faxes left click your printer and select properties then click "port" tab now look for USB and check mark it click aply and then close then try to print :)
Sep 23, 2009 | HP LaserJet 6mp Printer
Panasonic KX-P 1180 cannot print properly with win XP Pro SP2
when you loaded the driver did you select the correct port? many times I get calls where they hooked upto a certain plug in but chose the wrong port parallel needs the lpt1 port and if there are more then one listed it could be a higher number..lpt2...lpt3. goto the driver in printers and faxes and right click the chose properties then the ports tab and pick the port.
Jul 08, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Bad print out
I would recomend checking the ribbon cartride fitted in the pritner. Ensure the ribbon is correctly mounted on the ribbon drive shaft.
Ensure the ribbon is not jammed.
Ensure the print head gap is not set to close the ribbon is becomming jammed
Try changing the ribbon cartridge for a new one.
Dec 30, 2008 | TallyGenicom 2348 24WIRE 480CPS Draft 136...
My print out cat read some line very light and some line very dark priner is tally genicom 2348
I would recomend the following;
  1. Check the ribbon is seated correctly in the printer
  2. Check the ribbon is not jammed or tight to move
  3. Check the print head gap, ensure this is not trapping the ribbon
  4. Change the ribbon for a new one
  5. Check the ribbon drive is ok
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
Acer aspire t180 pc has parallel and usb ports printer does not work help
Did you update the lexmark printers drivers from their site I think if you do this you should have no prolems.
Sep 19, 2007 | Acer TravelMate 8006LMi Notebook
161 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
