Question about Kicker Comp VX CVX15 Car Subwoofer
How would i wire a dual voicecoil 15in kicker cvx
  • JMFT May 11, 2010
    What amp are you using and what is the lowest impedence it is capable of? What impedence are your voice coils on the sub and how many? Model numbers of associated equipment is helpful as well...
  • 15,935 Answers
What impedance are you looking for?
Posted on Oct 01, 2009
How do i rebuild the voicecoil on my kicker l7 15in speaker
I dont think that kicker has a recone kit available for L7, after they started building the cone as a one piece structure without a dustcap, making it impossible to align the coil in the gap.
Myself, i have considered the possibility of using the carbon fibre maxxonics recone kits, it may need some tweeking to make it work. but will be quite strong and you could try different coil impedences, aluminum formers etc.
if you dont feel adventurous, than you might be able to send in your sub to kicker for service. i think they just send off a new sub to you, at a discount......
Apr 14, 2014 | Car Audio & Video
06 kicker zx750.1 fuses melted opened amp and 2 capacitors blown
Better off getting it repaired through kicker.....Most of the time you cant find parts for their amps online or anything. Was the amp 2 ohm stable????? Is it still under warranty????
Mar 17, 2012 | Kicker 06ZX750.1 Car Audio Amplifier
How to make a kicker cvx 12 inch dual coal subwoofer 4 into a 2omh
Ok, follow closely. This is called the parralel set up. This is the easy way.
1. Identify the possitive on your amp or box you are installing in. Run the possitives of both voice coils to this. (yes, you will need two lengths of speaker wire)
2. Identify the negative on your amp or box you are installing. Run the negatives of both voice coils to this
How to figure ohms R1 x R2
R1 + R2 So your load 4x4=16 divided by 4+4=8 16/8 = 2
Ohms loads seem difficult at first, but they are easy if you think about it. We are taught in school that parallel means side by side, right. The same applies for wiring. A parallel set up means that both voicecoils are receiving the power from the source. If you look at your wires when you are done, both wires are "side by side", hence parallel. Now series means going from one thing to the next thing, right. So it is in wiring. Power would go from the source to the positive of one voice coil, the from the negative of that same voice coil to the positive of the next voice coil, then from the negative of that voice coil back to the source. I hope this helps
Aug 14, 2011 | Car Audio & Video
I have two dvc cvx andbrutus 1608d mono need help
Both Positives on both subs ultimately to + on amplifier
Both Negtives on both subs ultimately to - on amplifier
This will net a 1 ohm mono load for your amplifier.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 20, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
I cant remember how to install the kicker 12 l7
Your subwoofer is single or dual voicecoil? And what amplifier Make/model are you putting it on?
Thanks!
Nov 04, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
I wonder if i get two kicker cvx 10 can be push by jl audio 500.1
It can but it'd be a waste for your subs. 1 of those by itself will handle that amp. it'll push them just not really hard, i'd recommend an upgrade to a 1100-1200 watt rms amp if you're gonna run 2 cvx's. if you only run one sub that amp'll work well...
Oct 08, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
I have 3 Kicker solobarics Hooked to 1 ohm, But
It likely has a blown voicecoil - or the voicecoil is damaged in a certain spot - so when you play a certain frequency it cuts out.
Aso check the integrity of the tinsel wires - if they are loose or hitting the basket, it would stop playing.
BTW - it is impossible to wire a 1 ohm load with (3) single or 4ohm voicecoils.
Be sure your wiring is correct - or the amplifier will be the next thing to go.
Thanks for using FixYa - Rating this FREE answer is appreciated.
Jul 05, 2009 | Kicker Solo-Baric L7 10'' Car Speaker
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
How do you wire up 2 4 ohm dual voicecoil subwoofers for 1 ohm?
Both + on Both Subs to + Terminal on amplifier.
Both - on Both Subs to - Terminal on amplifier.
Jan 15, 2009 | Kicker DCVR124 -- 4 Ohm Dual 12in CompVR...
Kicker Comp VX CVX15  Car Subwoofer Logo
87 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
