Question about Onkyo DV-CP704 DVD Player
Region Fix for Sony BDPS 300
How do I unlock this player from zone 4 to multizone?
Thanks
  • Anonymous Jul 15, 2008
    I cannot find an unlock code to make my player region free.
    Is there a region unlock code available for the Sony BDPS-300 ?
Bdps answer
Posted on Mar 20, 2008
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
Dec 05, 2017 | Televison & Video
How can i unlock the region code? i want it to be multizone....thanks
i have a panasonic dvd-ls83 and it has region 4 on it i would like it multi region can you help, thanks
Nov 17, 2010 | Panasonic DVD-LS83 Portable DVD Player
Can I make sony NS400D multizone and if not, what does it play...we got it secondhand..ngcosgrove@hotmail.com
on the rear of the player will be a region code plate with a picture of a globe and a number next to it.
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Mar 21, 2010 | Sony DVP-NS400D DVD Player
Sony dvp-ns400d player won't recognize dvd's
This DVD player unfortunately does not support most of the Copied DVD /CDs.
it works stemless with only genuine / original CD and DVDs..
If your DVD or CD originally recorded by manufacturers but still can not read ,
than I recommend you to obtain and apply it to clean your laser eye of the DVD player.
The second problem is related with
factory locked multizone feature..
number next to it.
If you DVD disc does not have the same ZONE number ,it wont work.
But in order to convert your DVD to a multizone you need to make some additional adjustment.
Hope it will solve your problem.otherwise ask me to give you more on unlocking multizone feature.
Please remember to vote me too..
Regards
Compatible disc formats: DVD, CD, CDR, CDRW, Video CD
Feb 25, 2009 | Sony DVP-NS400D DVD Player
Region Unlock TEAC PL-D3200
Multizone code for Teac PL-D3200 Here is the procedure to unlock your Teac PL-D3200 to play all zones of DVD's.
Using your remote control:
1. Switch power on 2. Open the dvd tray (leave it open with no dvd in it) 3. Press "stop" 4. Press "734466" 5. Use cursor to scroll up or down until it says "Region 0" 6. Press "OK/Enter" 7. Switch power off 8. Switch power on
It will now play all region DVD's! :-)
Nov 28, 2008 | Teac DV-H500 DVD Player
Teac PL - D3200 unlock coce
Apr 14, 2008 | Televison & Video
Unlocking code for Philips HTS 3500s DVD
Eject disc. While open press 99990. Thats it.
Jan 24, 2008 | Philips HTS3500S System
Multizoning my Phillips DVD player
The same thing happened to me. To fix, follow the instructions below. 1. Turn your machine on. 2 Press Setup on the remote. 3. Press Preference. 4. Type on remote 9653. The use arrow keys to select Region "0". 5. Then click OK and the machine should now recognise multiple region zone DVDs.
Sep 28, 2007 | Philips Televison & Video
Hacking code for Teac PL-D3200
Sep 16, 2007 | JVC TH-S8 System
Onkyo DV-CP704 DVD Player Logo
174 people viewed this question
Top Onkyo Televison & Video Experts
Steve
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
