Question about Craftsman Garden
Leafblower won't start - Craftsman Garden
  • 101 Answers
I assume this is a Gas blower? So first off is the gas bad? Did this blower sit for a prolong time? These do require premix fuel and you must add 2 stroke oil to the gas ... if you don't you will ruin the motor. Check the spark plug for corrosion. Also it should have a gas bubble to prime the Carburetor with ... make sure gas is flowing through this bubble you can tell buy pressing the bubble you should feel and hear the gas squish thou it. Also check inside the gas tank look at the feed tubes make sure they are not deteriorated if they are you may just need to get a new one. Good Luck
Posted on Sep 29, 2009
My echho pb250 leafblower stopped running and now it wont start
There is a very small screen inside the carb that gets blocked up from the additives in gas. Clean it up and use a stabilizer in your gas/oil mix.
Nov 13, 2014 | Garden
Echo leafblower starts but no power
Could be Excessive carbon build up in exhaust caused problem. Remove muffler and clean exhaust side of cylinder.
Oct 04, 2013 | Echo Gas Blower 162 MPH 450 CFM Blower...
LEAFBLOWER WON'T START
check fuel lines inside fuel tank, see if will run on a shot of starting fluid e85 gas eats them
Sep 01, 2012 | Weedeater 2 Speed Gas Blower FL1500LE ()
My echo pb-2601 leafblower wont start
if you have spark then you have a fuel delivery problem or exhaust clogged
Nov 12, 2011 | Garden
My poulan pro leafblower won't start, feels like there's no compression
Check that the spark plug is snug. If that is not it, then you should check the tightness of the head bolts. Sometimes they loosen. After that it could be a blown head gasket or a stuck valve.
Aug 11, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Brand new leafblower first use and it stalled after 5 minutes. tried to re-start and the pull string will not move?
hopefully unless it is a 4 cycle? you mixed 2 cycle oil and fuel together as one and put it in the fuel tank? you can use a 40:1 mixture 3.2 oz of 2 cycle oil to 1 gallon of fuel 87 octane will work or 89 octane is better.
if its a 4 cycle (10w-30 for oil) and fuel go in a seperate area?check your manual to verify what they would like you to use
Jul 03, 2009 | Yard Man Garden
Craftsman leafblower running worse
Check the exahust screen (if fitted) for blockage. or exahust port...If it is clean port and or screen and use correct type/ ratio mix.
Dec 14, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
109 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
