Question about Whirlpool RBS275PD Electric Single Oven
I recently put my oven through the self clean cycle then the next day neither the oven element or the broiler element will heat up. There is power to the control panel.
Probably the Thermal Overload Sensor burned out from the excessive heat during the cleaning cycle. It Is located on back side of oven.
Posted on Oct 18, 2009
Lamona 4601 double oven.Stopped heating up so presumed element had packed in?
Try this. ANSWER is not specific to your machine.
You dont need the element to be red hot to know its working,
If its not obviously getting hot after 30 seconds its not working.
I dampen a cloth and wipe the COLD element and then watch the moisture dissapear quickly if the element is working.
First, have you recently done a self-clean cycle?
If so we can suspect that the OVER HEAT cutoff switch was triggered.
BUT before we conclude anything, check the broiler element for operation.
If the broiler also does not work, then its highly likely that the overtemp cutoff relay was triggered. This generally requires a technician. BUT
If you have a schematic, it will show if this switch is a ONE TIME USE SWITCH and needs to be replaced, OR if it is a pushbutton resetable switch. In either case the oven needs to be dismantled somewhat to get at the switch... I would call a technicain.
Aug 20, 2015 | Ovens
Broiler wont light everything else works..model ffgf3023lwa
Hi Chris Stewart - If the bake element and the top of the range works, but just not the heating element, then you possibly have a bad broiler element or connection. However, if you are experiencing other performance difficulties, then the control board may possibly be faulty and needs replacing. Consult a professional for an accurate diagnosis.
Feb 02, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
After putting my 10 yr. old Whirlpool Model RBD276PD double ovens thru the self cleaning cycle the bake and broiler elements in the bottom unit stopped heating. All the controls on the panel work and the...
This sounds like it blew the thermostat on the back of the lower oven. They are inexpensive and easy to replace. You will need to uninstall the unit and remove the back panel to acess. Check it for continuity if none replace. This is a fairly common failure due to the heat of the self cleaning. Here is a link to your part and diagrams are also available there AP3055316
Sep 28, 2010 | Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not heat. Broiler comes on though.
One of the ends of the element may have come out of the terminal that it slips into...push the element back into the socket...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 25, 2010 | GE JTP15 Electric Single Oven
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
223 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
