Question about Motorola Mobility RAZR V3
The phone only works when its charging. When i take it off the charger it turns off automatically shuts off . I think it has something to do with the charger port being a little bent but i'm not sure. thanks for your help.
Red light indicating fone charging has not shut off for around 20 hours.
My Vtech 6.0 charging light only turns off when I remove a handset from the charger base. I have had these three set for two years and they work fine. I think that the red light is just to let you know that the charger is working, if you loose power, or unplug one of the base units there is no indication of a dead battery.
Jun 11, 2011 | Vtech Cordless 6041 Phone
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
Away on holidays for 3weeks do I leave in on charge the entire time.I have posted my e-mail address but the stupid system keeps asking me for it
It's generally recommended to not keep electronics on the charger once they're fully charged because it can damage the battery/battery life. However, some phones come with an automatic shut-off feature so the phone doesn't keep getting charged after it's fully charged. You may want to look at the manual or see if the manufacturer has info on their website about it to see if they have a recommendation. That said, I always keep my phone on the charger and it still works; I don't think 3 weeks will kill it but if you don't need it immediately when you get back and don't find an answer specific to your phone, better safe than sorry.
Feb 08, 2010 | Uniden Cordless Phone
LG enV touch keeps shutting off when charging
I would replace the battery and see if that helps with this problem
Mar 30, 2017 | LG enV VX9900 Cellular Phone
My samsung phone has been fully charged. I try to turn it on, it says "initializing," then shuts down. When unplugged, it won't turn on at all. When plugged in, it shuts down, then blinks to the charging...
Are you sure it was fully charged before? Could you see the full battery bars?
It sounds like your AC adapter (the charger) has likely gone bad. The phone battery probably wore down, and when you plugged it into the charger, the charger couldn't charge it, so the battery remained dead.
Since the battery is not charged, you can't turn the phone on at all when it's not connected to the charger. And when you do connect it to the charger and turn it on, you get the intermittent charging because something inside the adapter has a faulty connection -- sometimes it works, sometimes it doesn't.
You can easily verify if the charger is the problem by getting a new charger (they're not too expensive) and seeing if the phone will work and/or charge with the new charger.
If the new charger doesn't fix the problem, post again here and we'll go from there, but I think the new charger will take care of it.
Hope that helps!
Jan 13, 2010 | Samsung SCH-u550 Cellular Phone
UT Blitz Has to be charging to work
could be either 1, needs a battery or a 2 new charger, even though it looks like it is charging.
Aug 26, 2009 | UTStarcom Blitz Cell Phone
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Feb 20, 2009 | HTC P3300 Smartphone
Motorola L6 Phone not charging or working
Well,
I solved the problem for my L6. IT appears that somehow the phone is software dependent. Meaning that you need to have the Motorola Software for the phone installed in your computer, connect the phone and voila! At least it solved my problem. All of a sudden it charged automatically and I can now charge with the power adapters too. (Yes I too went and bought a different charger, then when it didn;t worked I got a different battery..etc.) just give it a try. I think you can get it for free online somehow, just google it.
Jul 09, 2008 | Motorola Mobility L6 Cellular Phone
Motorola Mobility RAZR V3 Logo
65 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
