Question about RCA HD52W59 HDTV Projection Television
RCA HD52W59 power light on for 10 seconds then off
RCA HD52W59 Problem i have replaced the flyback, resoldered another major piece (not sure of name, it's towards the back of the deflection board with a lot of copper wire in it) part 40322-139 (by Orega). i have also done the infamous convergence option missing kit from tvrepairworld.com to this set. at first there was nothing, just a high pitch siren sounding noise that would wail and pause and wail and pause.... until you unplugged it. at this point, i did the resoldering on the above mentioned 40322-139 part and the noise stopped. now i push the power button, and the light will come on for about 10 seconds and then the set will turn off. in the 10 seconds, there is no picture or sound. any ideas would be greatly appreciated. thanks in advance.
  • randbdabney Sep 30, 2009
    is that what is located in the front panel where the thicker of the 2 lines from the flyback plugs in?
  • RCA Master
  • 8,617 Answers
Possibly the HV splitter as that set is also famous for bad splitters.
Posted on Sep 30, 2009
  • Sonny Berry
    Sonny Berry Sep 30, 2009
    Yes thats the HV splitter. The flyback HV lead and one lead from each of the three CRTs plug into it.
I can't get my RCA HD52W59 to autoscan the digital tuner... only the analog tuner will work. Was working before we replaced the convergence fuse. Also, when you turn the TV on, it comes on in setup mode...
When you replace Fuse on the defection board Did you Resolder FBT flyback Tansfromer?
You also need to resolder around the Hori circuit ,in front of Hori output transistor.
Apr 09, 2011 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 flyback transformer
your model uses the 270125 flyback if both wires are red. If one is red and the other black then you have the 259296 flyback.
Mar 21, 2010 | RCA HD52W59 HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
Power light flashes 3 times and makes and alarm or chirping sound then nothing. its a 52 inch RCA hd52w59 itc222 chassis. I replaced cp150 and cp120/114 and also flyback transformer and still same thing? I...
Chirping sound is coming from coil on right side behind FBT, resolder then use Glue gun to glue on top of coil LL037,Make sure high voltage wire from FBT to Trippler is in Good this is what maybe causeing lines and fuzzy picture.Also make sure solder on all pinns of FBT are good.
Sep 22, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Power button lights three times when pushed and unit makes squealing noise each of the three times the light comes on then nothing. No power, no light, etc...
replace the flyback which is the 270125 flyback. You can get the 270125 Flyback repair kit at the following link which contains the flyback plus detailed instructions on CD
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
Top and bottom of picture is bowed.Images are doubled and letters
one more question , could or can you access the convergence menu ?
the fuse will be next to the flyback transformer ( high voltage ) and ill look tan in color( 3 of them )
also the flyback pins have to be resoldered also
Feb 03, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 wave
OK those are the correct fuses one in middle does cause lost of convergence FL231,recheck second ribbon connector, make sure it is in correctly also ck cp 150 it will be a green and gold writing on capacitor 2200uf 16v ,see if it is bubbled on top if so replace it and 2 other caps 220uf 35v,what you are saying about it waving could be a big capacitor on small AC board where ac fuse and cord plugs into ck them .Let me know if you need more help . Resolder all connection pinns on flyback.
Dec 03, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59
that model has been known foe having bad flybacks. more than likely the flyback needs replacing especially since you noticed a smell when it went out
May 25, 2008 | Televison & Video
RCA HD52W59 HDTV Projection Television Logo
287 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
