Indesit washing machine, wil103
My door led is flashing fast with delay timer and stain removal,can any one help please,
this is a indesit wil 103 about 16months old. [ help please]
  • Anonymous Mar 09, 2009
    i have same problem with my wil103 had it for 5 years been good as gold till now but lights 1 and 2 flash with the rapid door lock light ive been told its a communication error and need a new pcb board you can get these off the internet for around £60 inc your vat
Sorry, meant to add, if you switch the machine off at the mains once you've cleaned out the filter (bottom right corener, front of the machine, behind a plate), leave it for 2 or 3 hours and plug in again, sometimes it works.
Mine worked again the first three times, but I think this time it's had it and it's engineer and pcb time.
Posted on May 13, 2008
From the looks of it, this is called an f12 lights 1&2, communication error
which seems to be quite common. I've got the same problem.
If there's nothing in your filter, it could be the pcb (apparently, according to the research I've done so far).
Quite expensive apparently (£200?), but these machines don't seem very reliable, lots of people on the web having problems.
I have an indesit wil133 .when one wash finished,the red flashing light came on ,so i could open the door,but also the delay timer & stain remover lights were flashing. now when i try to put another...
I would go to the manufactures website and download the user guide and look in the trouble shooting guide or I would check the water pump to see f there's not an obstruction in the pump preventing the pump from emptying the drum completely as if the water sensor is not telling the machine its empty therefore it cant start again
Jan 17, 2018 | Indesit W 123 Front Load Washer
Indesit washer/dryer widl 126s
Hi gmarf....to reset your machine to cancel those symptoms, Unplug your machine from the Wall Outlet for a minimum of 1 minute. Upon restoring power, it should be reset and ready-to-go.....If you have any further questions or issues please update your post....good luck my friend
Aug 12, 2007 | Indesit W 123 Front Load Washer
Indest wil103 has 3 flashing lights the power one and to green ones stain remover and extra rinse and want spin what is wrong please help
If the machin isnt able to evac the water, it wont spin. It will indicate error with 2 flashing lights + lock led. Check pump, drain hose.
Jul 26, 2009 | Indesit W 123 Front Load Washer
Indesit washer wil 103
Check your water inlet valves. Seems like the valves have went away. Also check the computer board and inline fuse to make sure everything is correct. Inlet valve are located behind the supply line hoses. Please rate. Thank you
Feb 14, 2009 | Indesit W 123 Front Load Washer
Indesit wil 103 door won't open...
Welcome to Fixya.
Try holding the Start/cancel button in for at least 2 seconds.
If there is another lamp flashing at the same time as the door lamp, then you will have to call an engineer.
Dec 18, 2008 | Indesit W 123 Front Load Washer
Washing machine fault
Usually indicates door is not closed properly.
If it is shut securely, and still does not work, then you could have a faulty door lock.
Another possibility is the control unit could be faulty.
Nov 29, 2008 | Indesit W 123 Front Load Washer
Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Jan 04, 2008 | Indesit W 123 Front Load Washer
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
505 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
