this helped, i tried locating the manual at asus.com but was unsucsessfull. thank you tom19511, your link lead me right to it.this helped, i tried locating the manual at asus.com but was unsucsessfull. thank you tom19511, your link lead me right to it.
You can't post conmments that contain an email address.
Dear Friend, Your I-Omega case might be bad or the controller inside that connects everything. I suggest you to get: http://www.walmart.com/ip/Apricorn-Universal-Hard-Drive-Adapter/10811435. and pulled your hard drive enclosure apart, then removed your hard drive and connect with the external adapter. Usually comes with a SATA or IDE connector for data and power adapter. After connecting everything plug into your PC and it should be able to recognize.
Good Luck#
go to www.gunpartscorp.com and then go to e-commerce and then go to winchester and then go to model 94 and you will see a schematic of this rifle. hope this helps you. Jeepfxr
its not the relephone plug the 24 v wires sound about right i believe the telephone plug would be for credit/debit card sales via a built in modem and magnetic card reader hook up the wires first by stripping them back and electrical taping them together put drawer in and plug it in should work if not switch wires try again once it works either solder or use a **** conector or wire nut and tape to ensure it doesnt ground out
a standard propane regulator should work. check on the required pressure for the unit and get a compatible regulator. try grainger supply. thermostat connections are usually 24 volt two wire, opens on temperature rise. connections on the burner relay are indicated TH-TH.
