Question about Amana NTW5205TQ Top Load Washer
Installing a new belt on a amana wash machine
SOURCE: new belt
For the Maytag about which I was asking, one must
roll the belt off the agitator/drum pulley
remove the motor/water pump assembly (1 electrical connector, two hoses with clamps, four 1/2" bolts).
remove the water pump (three torx screws).
Posted on Oct 28, 2007
sir fixalot
  • 146 Answers
SOURCE: washing machine belt replacement
I found the exploded parts views for that model number branded as a Maytag. Look to see if the are the same on the link below:
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LWA60AW&mfgModelNum=PLWA60AW&fkMfgID=1
Use the parts diagrams as a reference.
Remove drain hoses, motor
Move motor inward while removing belt from pulley under tub
Three screws with star heads hold pump to motor and careful when removing pump--it could crack if it is frozen to motor shaft.
Posted on Jan 04, 2008
the dr
  • 447 Answers
SOURCE: replacing belt on Amana LWD70AW top load washing machine
There is a post for this in my solved solutions. If you cant find it......amasuperbike@comcast.net
Posted on Jan 10, 2008
  • 71 Answers
SOURCE: My Amana washing machine stopped spinning.
moz-screenshot.pngac4805b.gifhere is the image on how to change the belt......it's pretty easy to do as you can see by the diagram.PS2027742 is the part number on the belt.
Posted on Oct 03, 2009
  • 110 Answers
SOURCE: Tighten the belt on an Amana washer?
The belt should already be pretty tight after wrapping around the barrel and the motor pulley. The belt may be worn and should be inspected and probably replaced.
To prevent similar problems in the future I suggest you be aware of how big of a load you put in the washer.
Posted on Mar 13, 2010
Amana LW8303L2 will not spine
http://www.washerhelp.co.uk/washing-machine-repairs.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Belt replacement on these is a slightly intimidating job to the uninitiated, but possible.
http://www.american-appliance.com/se...stic-Chart.htm
http://www.applianceaid.com/amana-wash.html#belt
Lots of pictures and help at these sites.
Main thing is use ONLY the factory-authorised replacement belt on these. It is designed to have the right amount of slip/grip to enable your washer to work properly. This is CRITICAL on Amanas.
Apr 14, 2010 | Washing Machines
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Apr 05, 2010 | Amana ALW895 Top Load Washer
Hello! The belt broke on our Amana Mod.# DLW330RAW . Could you explain how to install the new belt? Thanks Ron
Remove the bottom kick plate.
Remove 4 big bolts and unplug the motor. Move the motor assembly to a work bench. You need a T-20 torx driver to remove the pump screws and remember the rear pump leg goes between the belt. I have your Amana washer repair manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 17, 2010 | Amana DLW330RA Top Load Washer
Will not spin,belt slips,new transmission.Seemed to work fine without inner tub installed.
Belt loose or not the right size. Find belt tensioner if equipped and consider tightening belt a little more.
Mar 12, 2010 | Amana ALW480DA Top Load Washer
HOW TO REPLACE A BELT ON AN AMANA LWA65AW wash machine
FIRST DISCONECT FROM POWER AND THEN REMOVE ALL SCREWS HOLDING MACHINE PANELS IN PLACE , LOCATE BELT TIGHTINER LOOSEN AND REMOVE OLD BELT , THEN FIT NEW BELT AND AJUST TENSION .
Nov 01, 2009 | Washing Machines
I need to replace the belt on my Amana ALW480DAW. The other one burnt up and broke. I have the new one. Do you have a diagram I could view to help me install the new one?
I used the following links:
http://www.partselect.com/ModelFrames.aspx?ModelID=29693&ModelNum=ALW480DAW&mfgModelNum=PALW480DAW&ManufactureID=1&Selected=31971&Position=7&mfg=Maytag&Type=&Mark=7
Oct 21, 2009 | Amana ALW480DA Top Load Washer
Oct 03, 2009 | Amana ALW480DA Top Load Washer
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washer belt
To replace the belt on your Amana washer, pull the unit forward then tilt the top of it back to about a 45 degree angle. Once you get the right angle, the unit will rest against the wall behind it instead of falling forward. Take your new belt (availble through local appliance parts stores or on line from the manufactures web site) and first put it in the track around the large pulley, then the track on the smaller pulley on the right. Lastly, the pulley on your left should be moveable. Move the final pulley so that you can get the belt over it. It will then move back to a tensioning position.
May 14, 2008 | Amana NAV5800A Top Load Washer
Open Questions:
Amana NTW5205TQ Top Load Washer Logo
32 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
