Question about HP LaserJet 4650 Color Printer
Large envelope printing
Im trying to print directly onto an envelope that is 11 15/16" by 9". Is this possible on this printer?
  • 708 Answers
If it will fit nto the feed tray yes. you have to go into options when you print and enter the size of the envelope. you may have to enter it as a custom size.
Posted on Sep 29, 2009
I'm having trouble addressing an large envelope the printer wants to print from the upper photograph tray and not accept the envelope from the lower tray. I have the MX922 printer.
The upper tray on my 6120 has adjustable guides on either side of the document and can be set from 2" to 8.75" wide. It is not intended just for photos! I use it for ALL envelopes that will fit. I use the MS WORD "Mailings", "Envelopes", "Options", "Envelope Size" menu to tell the printer what size the envelope will be (any size not listed in the standard list can be customized from the CUSTOM option at the bottom of the envelope list). Your word processor should have something similar. Running from the tray should be a straighter run and will actually place less distortion stress on the envelope.
Use a mailing label for anything larger than 8.75". You can download a program from Avery (and probably other label manufacturers) that really makes labels simple to produce. Labels should also be run from the rear tray if possible so they won't wrap around your rollers.
Happy Printing.
Feb 10, 2015 | Canon Pixma MX922
Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Aug 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
Stopped printing envelopes in proper direction
What software are you printing from? It sounds more likely to be software causing the issue.
Sep 05, 2007 | Brother HL 1440 Laser Printer
Envelope printing error - when printing from the MP tray, envelopes are wrinkled
nothing im afraid mfps crinkle copiers all you can do is try to reduce the wrinkle try putting the flap inside the envelop sorry but other than that's theres not much your can do
May 14, 2014 | Kyocera Office Equipment & Supplies
Brother 7340 wont print on envelope just keeps getting stuck, tried opennig the back like the book says but still gets stuck
Are you trying to print from the main paper tray with the envelope or from the auxiliary single page feeder? The auxiliary insert should be directly under the "Brother" logo on the front of the printer. Insert the envelope there. If it's a standard light weight envelope and it gets stuck still then I'd suggest there is a paper jam somewhere or possibly the fuser is going bad.
Oct 29, 2010 | Brother MFC-7340 All-In-One Laser Printer
Printer will not print the address onto the envelopes, it just keeps flowing them through
the envelope size is not selected in the printer properties. check the settings in the print properties and select the paper type as envelope and size of the envelope.
Oct 01, 2010 | Pitney Bowes AddressRight DA300 Printer
Need to pring envelopes on my konica Minolta hub 350 printer
Place envelopes in either drawer 1 (top drawer) or the by-pass tray. Generally, the envelope is placed side to be printed down. (On the printer you can set up custom envelope sizes.)
Select Print. Click 'Properties' for the printer. In the resultant dialogue window, set the printer to print to the 'envelope' print path.
Click OK, click Print. (test print direction first)
Check your printed envelope. You may need to change the orientation of the envelopes to print with the opening at the top.
Jul 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Printing on a #10 envelope
Go into your Word Document and print from "Tools" then "Letters and Mailings" and click on Envelopes and Labels. Sometime the perimeter isn't defined and it is on there but it's outside the scope of your envelope, especially if the return address isn't in the correct place also. You may even be able to correct it where you are by decreasing the "window" of your typing space, it's just too large.
Jan 17, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
How to print #10 Envelopes
How to copy/print onto envelopes.
Solution
Konica Minolta does not recommend copying/printing onto envelopes, asthe MFPwas not designed to run envelopes. Additionally, envelopes do not meet the
standards set for paper specifications. Their multi-layer make-up, adhesive, and odd size make it unreliable and potently damaging to the MFP.
Nov 13, 2007 | Office Equipment & Supplies
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
HP LaserJet 4650 Color Printer Logo
111 people viewed this question
Seeker5211
Seeker5211
