Question about Remington Electric Chain Saw
SAW BAR PART #EL16SB OR 107704-02
SAW BAR
    President:
  • 2,220 Answers
Enter either part number in the "Part #:" window here:
http://shoppingcart.msservicecompany.com/Default.aspx
Both cross to a 16" bar, $22.99 each. HTH
Lou
With the correct model you find it cheaper here:
Bar Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Enter "Remington" then "model number", the rest pretty easy.
Posted on Sep 30, 2009
How do I adjust the chain ie tighten?
1st shut saw off
2nd obtain wrench that fits bolt to hold bar on (theres only one)
3rd lose en the bolt for bar by only one turn !!
4th locate screwdriver (or a dime works too) and turn small screw next to bar just before it connects to saw
observe chain tension , stop when you can no longer lift the chain up from bar , don't overtighten!!
5th retighten the bolt that holds bar to saw , Tight!!!
6th restart saw and cut wood !!!
Apr 14, 2015 | Garden
Husqvarna 235 is not oiling.Hole and groove on bar have been cleaned. The saw does drip oil with the bar off when running.All parts are clean but bar is not getting oil.Hope you can help,thanks.
With saw running and high speed hold saw close to a piece of wood and check for oiling. If still no oil, then use air pressure at hole in bar to clear.
Sep 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a husqvarna 257 with a 20inch bar and having oiling problems, is getting hardly any to no oil and have the oil adjuster screw the whole ways out, is the oil plunger bad?
If you take the bar off, and then run the saw, does oil come out of the saw? If it does, then the oil pump is likely working O.K.
If the oil comes out of the saw and does not make it onto the chain, it is possible that the oil exit slot on the saw, and the hole on the bar are not lining up properly. This happened on my Husqvarna 141 saw. The oil was coming out of the saw fine, but it never made it to the bar and chain. As a consequence the chain was always dry and very, very hot.
The other saws we use, always have plenty of oil on the chain. I think Husqvarna may have made a design flaw on some of their saws, and the exit point of the saw and the entry to the bar are not properly aligned. I wonder how many saws this affects.
Sep 14, 2010 | Husqvarna Chain Saw 20" Bar
I can't find a replacement saw blade for my remington M30016aw saw
Are you aware RemingtonPower is no longer in production (name purchased by MTD)? I am not certain whether you need a bar or chain so I provide both. I ask you retrace my steps to verify the part numbers I supply.
A link to an OM for your saw follows:
http://www.desatech.com/manuals/Chainsaws/model_m30016aw_manual_113005-01g.pdf
A parts listing is near the end of the manual. Items 2 (bar, pn EL16SB if 16" $22.99) and 3 (chain, 16SC if 16" $17.99) apply.
Both are available here:
PartsFor.com (authorized parts supplier)
http://www.partsfor.com/
Please use the phone and a credit card to protect yourself should problems arise; get the name of your service rep.
Please count the drive links (the part that fits in the bar groove) and verify there are 58 (16" chain).
You can likely take your existing chain to a local chainsaw seller/mechanic where it can be duplicated cheaper in about 5 minutes.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 06, 2010 | Remington Electric Chain Saw
Where can I find a replacement bar and chain for my saw?
Remove the bar and chain from the saw. Take these parts to a saw servicing dealer who can match the bar and chain. Be sure to clean the area where the bar mounts. Run the saw for a few moments--the oil port in the side of the case should ooze out oil. Install the bar first, then thread the chain onto the sprocket, then work it over the bar. Pull the bar out until the chain is fairly tight, then fit the cover, but leave the mounting nut(s) finger tight. Turn the chain adjuster until the chain doesn't droop from the bar, but still be able to turn the chain by hand. Tight the mounting nut(s) and recheck tension. Run the saw at full speed with the tip near some cardboard--it should throw off a thin line of oil onto the cardboard. Hope this helps!
Jun 10, 2010 | Desa International 100089 06 Electric...
Where can i find a 16" blade for my remengton electric chain saw. part #097572-03s
Afternoon Lionel;
A replacement bar can be found here:
Remington.com
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Your part number returns replaced with;
Part #: EL16SB Price: $22.88
Description: BAR REPLACEMENT SPROKET NOSE HEAVY DUTY
or
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
Part #: EL16SB DESA SPECIALTY PARTS: BAR GUIDE 16IN (107704-02) (REM-SH5) $22.99
or
This is worth a look IMO, given an Oregon part number you may find a local source (often saves shipping and handling fees).
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Select "Remington; YourSawModelNumber; 16; All; All; All".
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 06, 2010 | Remington 16" Electric Chain Saw
Where can I find a new chain bar adj screw for WEN 3818 gas saw?
Most older chainsaw adjustments are visible when the saw is viewed from the end of the bar back to the saw. More modern ones are near the bar nuts (side). Lou
Aug 26, 2009 | Electric Chainsaw Sharpener
The chain on my Remington electric saw keeps jumping the sprocket. Solution? Thanks.
Depending to what model you have, the Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. Or your cahin is not tensioned properly. According to the manufacturer... "The adjusting block on the adjusting screw isn’t inserted into the adjusting hole on the guide bar. Reinstall and align the sprocket cover by first removing the sprocket cover from the saw. Turn tensioning screw on the sprocket cover counter-clockwise until it stops. Pull guide bar away from saw body to remove slack from chain. Insert sprocket cover tab into saw body tab slot and lower sprocket cover into guide bar bolt. Finger tighten guide bar nut onto guide bar bolt. Slowly push guide bar toward saw body until adjusting block on the adjusting screw drops into round adjusting hole on the guide bar. Securely tighten guide bar nut after properly tensioning saw chain." If these tips do not work, you may need a new chain. You can order an new chain on-line at www.masterparts.net. I hope this helps you!
Jul 01, 2009 | Remington Electric Chain Saw
I have a homelite chain saw that the bar oil is not dispenseing
May be oil port on saw clogged. Remove side cover, remove bar and chain. Remove giude plate if equipped. Check to see if small oil hole on saw is open and clean. You can start the saw with side cover removed to see if oil is coming from oil hole or not. If it is coming from oil hole when running the problem is most likely dirty bar .If bar is dirty check to see that groove is clean and the oil hole along the edge of bar is clean also. The hole is at same end of bar that attaches to saw.
May 08, 2009 | Homelite Garden
Remington Electric Chain Saw  Logo
361 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
