Question about Nortel Meridian M7208 Corded Phone
I need an extra line to ring on my phone
I have a new phone line but I dont know how to program my phone sa that it will ring on it. And the company I got my phone from is no longer in business. It is a Norstar M7208
    President:
  • Nortel Master
  • 860 Answers
First, you'll have to know what the line number is in the system for the new line.
To get the line port number, on the set/s that the new line appears on press feature *0 and the the new line.
The display should say for example L025:LINE 05.
The port number of the example is port 025.
write the port number of the new line down for future reference.
ProgrammingI need an extra line to ring on my phone - 2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear& ring
press next key (lower right arrow)til you see the line port number you wish to program
The display should say line 0xx: appear only
press the Chng key till it says appear & ring
press the release key when finished
Posted on Sep 29, 2009
Am getting Silent Mode On and New CID:49
f you have a landline phone, plug that into the Demarc either inside/outside of your house, if you dont know what that is, its a grey box where your phone lines come in and you will see customer service side. Get a phillips screwdriver and open that side up and plug your phone in. If it doesnt ring there, your phone company has to fix the problem.
Jan 28, 2016 | Uniden DECT 6.0 Cordless Telephone...
I have 10 Panasonic KX-T7730 using 8 phone lines. I've confirmed with AT&T that all 8 lines are setup for caller ID. I've confirmed that all 8 extensions have the Caller ID enabled. Two of the
Firstly, you have not indicated which phone system your phones are connected to, e.g. KX-TA824, KX-TDA50 or other, so I'm a little in the dark. That being said, most of the Panasonic Systems only display Caller ID information (CID) to phones that are programmed to "Ring" on the line with the incoming call, and the line button flashes green to show it's ringing... so you must "system program" ringing for the line(s) on each phone. If the CID is not displayed on a particular phone, then that line is likely not programed to ring on that phone (it's light may flash red instead of green). After you "system program" the line to ring, you can still shut off the ringing sound on a phone using the slide switch on the left edge of the phone if you don't want to hear ringing, and this will not interfere with the CID display. Also, on a second note, CID does not display on the first ring coming in from the phone company (TELCO). The CID signal is sent from the TELCO to your system after the first ring has ended, during what would be the silence period that would occur before the second ring, if there was no CID. It is for that reason that most knowledgeable installers program lines with a five second delayed ring; in this way, you don't know the call has arrived until after enough time has passed for your system to receive the CID signal... this is why it seems the CID appears instantly, with an incoming call. Check out the line programming for each line and set it to ring with a 5 second delay. If you don't set up a delay, your phones will ring and if you answer the call immediately, its likely it won't allow the system to receive CID, so no CID will be displayed for that call.
Oct 28, 2014 | Panasonic KX-T7730 Corded Phone
Nortel T7316E that has several different phones lines and we would like to program a different ring tone to the different lines or be able to turn off(send to voicemail) a couple of them when they are not...
You need software version 6.1 or above rod Distinctive Ring tone for lines. programming via Config/Lines/Data
You can setup night services for each company via Service Modes.
Complex programming.
best to call a vendor/tech in for this....roughly one hour call.
Sep 22, 2012 | NorStar T7316E Corded Phone
Our company has purchased a Nortel Norstar Meridian M7310 phone system, that has been previously used. We didn't know, but it did not come with voicemail, so it is tough to get calls when I am not here....
Programming2.gif is done on M7310, M7324 and T7316 sets.
The display should say line 001: appear only
press the Chng key til it says appear and ring
The display should say line 002: appear only
Continue til all of your active lines say appear and ring
press the heading key(top left arrow) till the display asks for another extension number
repeat line programming for that extension
Aug 30, 2010 | NorStar Meridian M7310 Phone
Trying to make every phone ring when the main phone rings
Well that is better than most people in finding the arrows...
Ok, first you need to know the extensions that you want to program to ring, and the lines, record these numbers... if you do not know the extension numbers and actual line numbers; going to each set, and doing a FEATURE * 0 and the Intercom and line buttons this will tell you the extension number and line number (this also tells you what is on every button).
Then goto your set and put in:
-> FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will have to look at your LCD for 3 arrows
<- Heading....Enter->
<- Back .......Next->
You will not see these words in the LCD display, you just have to look for the arrows that correspond.
-> you will now see “TERMINALS&SETS” and press Enter (the top right arrow key)
-> now put in the extn that you want to change (Eg. 227).
-> you should now see the extension number “227: NAME”
-> press Enter (the top right arrow key) again
-> you will now see “LINE ACCESS
-> press ENTER
-> you will now see “LINE ASSIGNMENT
-> and Enter
-> now you can type in the lines that you want to ring on this extension (Eg. 025 for line 5)
-> hit CHANGE till it says "APPR&RING" (Appear and ring means that the line will have a button on the set)
-> hit NEXT to save changes
-> press FIND to look for more lines and change the appropriate lines to appear and ring
-> then the RLS button (the little orange button) to exit programming.
After this programming is done, dial Feature * 0 and look for these new lines.
Good luck.
May 05, 2009 | NorStar Meridian M7310 Phone
Ring tone file size
i have found about 15- 17 seconds is as long as it can be. less than 290kb. you need a music editing program. also making it mono instead of stereo helps to squeeze that extra second in there.
Apr 15, 2009 | LG Vu CU920 Cellular Phone
HP officeJet 4215
Here is a link to the user guide.. This should provide info on how to program the fax to answer o n the second ring. I don't know however how you have 2 numbers assigned to one line?
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=351106&lc=en&cc=us&dlc=en&lang=en&cc=us
Nov 03, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Lucent Partner 18D - stop ringing of line 2 at phone
From extension 10 or 11
Press feature 00
Left intercom
Left intercom
right intercom
enter your extension number
all lines that are programmed on your phone will light up.
Solid means immediate ring. Slow flash means delayed ring. Really fast flash means no ring.
Press the line you wish to not ring, 2 times.
Feature 00 when you are done.
Oct 14, 2008 | Lucent PARTNER18 Corded Phone
Norstar Phones - Turn off ringer on phones
You have to go in to programming and set the phone in the shop to ring on line 3 only and the phones in the office to not ring on line 3.If you don't know how to go in to programming please inform me.
May 14, 2008 | NorStar M7310 Corded Phone
Fax ring tone or ring leader
im sorry to say the machine you have does not have DRD distinctive ring detect.
Jan 21, 2007 | Panasonic Workio DP-2330 Printer
Nortel Meridian M7208 Corded Phone Logo
498 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
