Question about Texas Instruments TI-84 Plus Calculator
Every time i try to graph it tells me error window range
  • 53 Answers
Change the x and y range. u can change it by pressing the window key and entering them into the min and max of x and y in ur problem
Posted on Sep 29, 2009
Range error on casio graphing calculator
Open the window configuration ans set Ymin to -10. You can also access the ZOOM function and select Zoom Standard.
May 07, 2012 | Casio FX-9860G Graphic Calculator
Every time i enter in something to graph like Y =5X-4 and i like graph my calculator says ERR:WINDOW PAGE 1:quit
There is no such error message from the TI 83PLUS. Did you mean WINDOW RANGE?
The easiest way to correct the messed up window dimensions is to reset them. You can press the Zoom button and select 6:ZStandard
Apr 26, 2011 | Texas Instruments TI-83 Plus Calculator
For my ti-84 I try to graph & it says ERR:window range...but when i try to fix the range it won't allow it...is there a good widow range to have for all graphing purposes?
There is no one good window range for all graphs, since graphs can have different areas of interest.
Press the ZOOM key, then select ZStandard. This will restore the window settings to the default range, which will at least allow the graph to be displayed. You can then change the window range and/or zoom as desired.
If this doesn't do it, please reply to this post, giving the function(s) you're trying to graph and your current window settings.
Feb 15, 2011 | Texas Instruments TI-84 Plus Calculator
I am using a casio graphing calculator and I am trying to graph a parametric function. I put the mode on Param and I inserted xt and yt and i press draw. It draw but then stops and gives me an arugment...
The argument error must have something to do with the parametric functions you are drawing. I do not think anybody would know where to look unless you give us the functions.
As to the range of the T-variable, you can set it by pressing [SHIFT][F3] to open the (V-Window) configuration screen. It starts showing Xmin, Xmax. etc. To get to the T range, use down arrow (about 7 times).
Dec 06, 2010 | Casio FX-9750GPlus Calculator
Every time i try to graph something it says ERROR: WINDOW RANGE. how do i fix this?
Press ZOOM 6 to reset the window range to the standard default and you should get a graph of some kind. If this is showing you the wrong area for whatever function(s) you're plotting, press WINDOW and set the range appropriately.
Nov 14, 2010 | Texas Instruments TI-83 Plus Calculator
I entered a polynomail function in the Y= window and I pressed GRAPH. I can't see the graph now. What do I do?
This sounds like a range problem; meanaing that the calculator has probably graphed it but it is not in your window.
Heres a simple solution:
First make sure that the graph has been highlited so that it is being graphed.
Secondly; try the z-fit function on the graph menu as oppesed to Z-standard ot Z-trig. This might make sure that the range "fits" into your window.
Thirdly and this one might make you smarter, this is not the easiest, but the best; Check your function numerically so that you have some idea of the range. Plug some numbers in numerically into the domain, x, to see twhat the output of the y would be. This might tell you if the graph might be growing so fast or slow that it is not showing up in your normal range.
There are also other ways; buyt these should suffice and get you more familiar with your calculator.
Good luck and happy graphing!
Jun 30, 2010 | Texas Instruments TI-83 Plus Calculator
Graphing
If you do not get an error message, then the graph is out of range. Try to zoom out, or play with the window dimensions.
Hope it helps.
Sep 17, 2009 | Texas Instruments TI-86 Calculator
How do you set up window range?
or press ZOOM, option 6 (ZStandard).  That instantly resets the window range.
Jan 20, 2009 | Texas Instruments TI-84 Plus Silver...
Can not use graph function
How do I fix my Ti 83 calculator's window range error and do the graph?Because without that fixed I can't do my graph atall.
Oct 19, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
367 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
