Question about Compaq Computers & Internet
Cd is not working. it says it is missing or damaged
  • 736 Answers
If your CD is SATA then the early SATA cables fail frequently .. usually intermittantly .. if reseating helps then replace the cable .. if its PATA (wide cable, older systems) . check the cable to make sure it its still plugged in correctly at both ends .. your CD drive could have failed .. a new one is not expensive and usually easy to replace ... or better yet you can replace it with a DVD drive (allows playing DVDs) or even a burner .. locally DVD burners are only about $24 .. of course they do CDs as well .. CD drives cost even less ..
Posted on Sep 30, 2009
My computer is saying BootMgr is missing !!!
Bootmgr is missing is an error from your system. The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose hard drive interface cables. you can fix it by the following steps:
Firstly, create a bootable CD/USB byWindows Boot GeniusSecondly, set the computer boot from CD/USB after enter into the BIOS menu.Thirdly, start Fix "Bootmgr is missing" with the CD/USB created at the first step.
Source:http://www.windowspasswordsrecovery.com/fix-windows/bootmgr-is-missing.html
Feb 19, 2013 | HP Computers & Internet
My CD drive panel stays open/down after a cd has been insertedhe cd works - how do I repair the door unit ?
the exterior door is spring loaded, so the door is either in a bind or the spring is damaged or missing.
If you can't fix the spring/door, you can get a replacement here:
http://shop.ebay.com/i.html?_kw=530&_kw=Inspiron&_kw=front
Jul 16, 2011 | Dell Inspiron 530 Desktop Computer
My xp ntldr is missing, kindly fix it...
Boot from XP CD and open up recovery console, type in chkdsk /r, if this doesn't fix it boot XP CD again, run repair install. If this still doesn't work use a hard disk test utility to check your disk for physical damage. If damaged replace disk and re-install windows from XP CD. If not damaged, you will have to re-install windows.
good luck!
Oct 29, 2010 | Computers & Internet
Cd rom will not read disk, cd rom runs and open and closes. Is the drivers missing?
no the driver is not missing... but maybe the connection into that driver is damage or not properly inserted
Sep 24, 2010 | Computers & Internet
Dell M1530 doesn't recognise cd drive.
If the CD drive is damaged you may need to replace it but if you may have had a file or driver problem, you can do the fallowing and it may restore your missing driver files.
Enter your device manager and look for flags or exclamation marks.
If found, remove them all and reboot unit.
If when the unit restarts it finds the missing device, it will automatically load the driver.
If it does not and you still do not have access to your CD drive, go back to your device manager and open you drives category and look for your CD drive.
If you see it, remove it and reboot your unit and again, it will load the appreciate drives required.
Hope this works for you.
Nov 24, 2009 | Dell XPS M1530 Notebook
Zoostorm pc
http://www.kellys-korner-xp.com/xp_sys32.htm
This issue can occur if the System or Software hive for the Windows XP installation is missing or damaged.
This Is not an easy process but it will work. Go to the info on if you can not boot from xp cd.
Good luck. Please rate me.
I have had this problem many times before this fix will work if do correctly, but like I said it is not an easy task. If you need more help let me know.
Jan 14, 2009 | Microsoft Windows XP Professional for PC
Dvd/cd rom will not work.it says missing file (code)39
Not very much information was provided in your problem. The issue could be many things. The disc may be damaged. Or, if it was burned on another DVD/CD device, it could be incompatible. Note that when burning a CD or DVD, it is best to use a slower speed. Higher speeds can result in a disc that may not work in slower drives.
Jan 01, 2009 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Missing cdrom drive
Is the LED of your CD ROM blinking? If yes then go to device manager by right clicking the My Computer icon and then click the Properties command. In the Properties window select the Hardware tab and then click the device manager. Is the CD ROM entery there! yes> right click and enable the device. If no then reformat your hard disc and reinstall.
In case your CD ROM's LED is not blinking (Rarest case) then simply check all the cables connected to it, atleast the power cable. if it is still not working, your CD ROM got damaged and there is a time to change it.
Feb 04, 2008 | Computers & Internet
Console is ruining games by putting grooves in them?
if you have a bad laser it will ptu a ring around the games and not let you play them anymore or mess them up halfway through a agme or so
Dec 30, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
20 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
