Rheem gas furnace blower unit not working properly
I have a Rheem gas furnace, model RGPN-10EAMER. The blower unit appears to work but air is not (noticeably) blowing from the ceiling air ducts. The burner unit is working fine. How do you adjust the blower speed to increase the air flow?
  • 24 Answers
Look at circuit board and follow wires that come from fan motor, if this is a standard motor black is high and it will be going to a prong that says cool, red is low and it will go to heat, you will have a yellow and a blue that are "parked" remove red park it were the blue is and put blue on heat, if this is a variable speed motor you will have to set dip switches via your equipment manual
Posted on Sep 30, 2009
Where is the filter on a rheem corsair furnace?
I'm not familiar with the Rheem Corsair gas furnace, but the filter will be somewhere, filtering the return air. Is the furnace installed as an upflow, down flow or horizontal? Locate the blower door, open it up then work your way back on the duct that is returning air to the blower. Sometimes homes will have a filter return grill in a hallway ceiling. The grill has a couple nuts that can be removed, the grill swings down and houses the filter.
Feb 05, 2018 | Heating & Cooling
Why will the pilot light on my gas furnace not stay lit?
You have either a defective thermocouple or a faulty gas valve.
Look online for methods of checking the thermocouple
milli-volts reading with a multimeter. 15 or 20 Mv is the average.
Nov 26, 2014 | Rheem Gas Furnace 75000 Btu 80% Afue. Rgpn...
Why is my 95% rheem furnace blinking code 2
Check condensate water /drain stopped up. It will allow a start after a reset but then it shuts the combustion air fan down and that shuts the unit down this will require a service tech make sure their familiar
with 95% units
Oct 19, 2012 | Rheem Gas Furnace 60000 Btu 95% Afue. Rgrc...
Rheem rgph 10eamer 8 yrs old ...blower motor wont stop running...i had the a/c on....decided to ck the furnace ...switched to heat...blower still running....no spark from direct spark...
Hi Richard. The switch they are talking about has a small tube coming from the induction blower housing straight to the switch. The best way to test it is to blow and **** on the tube while it is still connected to the switch. You should hear small clicking sounds coming from the switch, if not than it needs to be replaced. Another thing to try is a small wire or paperclip through the small opening where the tube came off. Sometimes this gets clogged and causes the same issue. Other than that, it can be a blocked flue or the inductive blower motor itself is not working properly. Hope this helps and good luck!
Sep 26, 2010 | Heating & Cooling
Does my Dayton Gas furnace have a air filter that I should be cleaning or replacing? I can't find it. Model #MGPH-10EAMER Serial # EV5D302F479702216
If you dont see one the you,re suppose to have one before the fan . This is your first line if defense. from air borne pathogenes..
Dec 17, 2009 | Dayton Gas Furnace Heater
No Heat and I'm Cold
Your preasure switch is closed
Dec 05, 2008 | Heating & Cooling
No heat and I'm cold.
Do you have the code reference on your furnace door? If so what does it say? The furnace has locked itself out, and we need to determine what in the world it needs..
Heating & Cooling Logo
863 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
