Question about Watches
My watch, Seiko Kinetic Auto-Relay (5J22-OD60), no longer holds enough energy to keep working overnight, the second hand starts moving at two-second intervals and it stops before morning.
You have a bad capacitor. You can either try to repair this yourself with a special upgrade kit for about $20 (and maybe screw it up) or pay an expert who will do it right for $67.
http://www.qualitywatchrepair.com/seiko_kinetic.htm
For an extra $20 he'll do a pressure test on it to be sure it is water-proof but since this is a pro you really don't need to worry about it on a non dive watch.
Posted on Jun 13, 2010
This watch actually contains a small rechargeable battery that must be replaced every so often (10 years?). Make sure you use the correct rechargeable battery - this is NOT a normal watch battery.
Posted on Dec 20, 2009
I have purchased a new Seiko kinetic SUN007 mens watch. After hours of swinging back & forth to charge the watch, the 'second' hand still moves in two-second increments. (After charging via movement,...
I have a Seiko kinetic watch and it has behaved perfectly for over two years and therefore I think that yours is faulty.
I suggest you send it to Seiko to have it repaired or replaced under warranty.
Apr 05, 2011 | Seiko Sun007 Kinetic Watch for Men
I do not know how to wind up my watch, while a swing to a later no.Please answer me.Model hours a Seiko Kinetic 5M62-0B40.Thank you
This watch operates on a capacitor which is charged by movement. It does not wind, but it has a weight that charges the capacitor by motion.
Take the watch in hand by placing your fingers under the caseback and your thumb on the crystal. Use a horizontal motion (landscape) to move the watch back and forth quickly approximately one foot left and right. You should feel the internal weight move.
Do this for at least five minutes. If the watch does not start to operate (the second hand does not move at one second increments) then either the capacitor must be replaced, or the movement is defective.
You may send the watch directly to Seiko for service, or I would strongly suggest visiting your local Certified Master Horologist for what is usually a free assessment and estimate of the repair.
If you are following the above directions, you have done nothing wrong, but the movement or capacitor needs to be replaced.
If you have just purchased this watch and the instructions do not resolve your situation, I would promptly return it and exchange it, as the model may have been sitting for a while, and have a bad capacitor.
Feb 23, 2011 | Seiko Kinetic watch
Seconds hand stops moving
1st reason. This means your oscillating weight and paired gears are not generating enough power to charge capacitor, thus not be able to move hand properly. 2nd reason. Capacitor can not recharge itself to full power and needs to be replaced. 3 reason. Seconds or chrono wheel has a mechanical fault developed over the time and needs to be cleaned or replaced. Those are 3 reasons why the seconds hand stops moving in Kinetic watch. Which one is right, you will find out only after visiting watch repair shop, because I can not give correct estimate without seeing the watch myself.
Rate me, plz.
Jan 11, 2010 | Seiko Premier KineticĀ® Perpetual Watch for...
SEIKO 7D48.... WATCHING SHOWING CORRECT TIME(WORKING PROPERLY).. BUT SECOND HAND NOT MOVING.
Second hand could be stuck against the crystal inside or it is slipping on the shaft. Both of these conditions can be fixed but the case back would have to be removed and the movement removed to fix this problem
Nov 05, 2009 | Seiko Kinetic watch
Can I use an ordinary button cell in a seiko kinetic
I have been trained by a Master watch maker and I have worked on many Seiko Kinetic watches. Yes the original watches came with a capacitor that is charged by your arm movement. But unfortunately, they seem to only last a few years. All replacements are now done with a Lithium Ion battery that is much better and lasts longer than the original capacitor. This is the correct solution and don't try to use a battery type that is used in other quartz watches.
Oct 01, 2009 | Seiko Kinetic watch
Watch stopped while in hospital and now, although running again, has the second hand moving in two second intervals
Some Seiko kinetic watches and other self charging watches do this when the battery is low. If it relies on you moving to keep it charged that may explain why it stopped in hospital. Try giving it a good shake and see if it starts moving smoothly again
Aug 10, 2009 | Watches
I have not worn my SEIKO kinetic wrist watch for a
Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
Jun 05, 2009 | Seiko Kinetic watch
Second hand moves three seconds at a time
You have to replace capacitor in your watch. After that it will run like new.
Jan 03, 2009 | Seiko Kinetic watch
Seiko kinetic
I habe seiko kinetic work and stop work
Feb 07, 2008 | Watches
Watches Logo
1,691 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
