Question about Xerox Phaser 8500/DN Printer
Error: 09,035.43:27650 What is does this error message mean?
    Novelist:
  • 208 Answers
You have a Cyan ( blue) ink stick stuck or a broken ink stick in the ink loader.
Check the cyan slot carefully, one of the sticks has not moved properly, The machine is not seeing the ink loader moving indicating a stuck cyan stick, Here is the info.
Ink stick count faults (error code 09,03x.4x) are declared when the printer melts 2.5 ink sticks without tripping the color's ink out flag. The ink out flag is used to physically count ink sticks passing thru the ink loader.
Verify that the ink sticks are Xerox 8500/8550 ink sticks. Manually verify that the ink stick are correctly loaded and are able to advance in the ink loader chute. Check for broken ink sticks which can fool the ink out (ink stick counting) sensor.
The ink stick count fault can only be cleared by powering up the printer in internal diagnostics mode. Then scroll and to the Functional menu item Clear ICS Fault.
Posted on Dec 19, 2007
  • Rick Kasper Dec 19, 2007
    If not the cyan check all the slots for a broken or stuck ink stick.
    That is most likely the problem. It could be a bad ink loader, but I have never witnessed those fail, Just sticks getting stuck.
2 Suggested Answers
  • 81 Answers
SOURCE: xerox error code 09 035
What model printer?
Posted on Jun 10, 2008
Dcz625 has error 6
Q3 ERROR CODES - WHAT DO THEY MEAN? A3 Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
Error 8.Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9.Weak RF. Try alternate frequency
NO CD.CD error message. No CD is magazine or no magazine in CD Changer.
Clarion DCZ625 Owner Manual
Good luck.
Semper Fi,
Z
Feb 20, 2018 | Office Equipment & Supplies
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
What does error message number 9 mean on my kymco mini s mobility scooter?
hi, it's a controller trip error message this can mean a bad connection or at worse a controller fault ...
Regards
Rob
May 05, 2014 | Health & Beauty
Janome MemoryCraft 6500. What does error message "BM init error" mean? What does it take to fix it?
That's an initiation error. I would call Janome direct and ask them.
Dec 02, 2012 | Sewing Machines
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 25, 2011 | OKI C5200n Laser Printer
Error code OFOO:O75D error:OFOO:O244
Is this from a blue screen error ?
A "STOP" MESSAGE in white letters behind a blue background?
If it's a sata message (hard drive error message), this means that your harddrive is dead or about to die. Most likely its already dead, this error means also that the harddrive cant be read anymore.
Mar 05, 2010 | Dell Inspiron 1501 Notebook
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
TE message. machine turns on but nothing else. I found out the message means a thermastor problem
Perhaps the error is "[-E" and it means the thermistor is out of error. Replacing it will correct the problem
Apr 27, 2009 | LG WM2277H Front Load Washer
Help Toshiba E-Studio 162 Copier error
how can I reset the Toshiba estusio162 without calling for maintenance
Sep 03, 2008 | Toshiba e-Studio162 Copier
H02 Error Message
H02 error on AG-1980 is a "capstan motor error." most likely problem is a defective capstan motor.
Apr 02, 2008 | Panasonic AG-1980 S-VHS VCR
Xerox Phaser  8500/DN Printer Logo
747 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
