Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
Fax test fails on "Using Correct Type of Phone Cord with Fax"
  • 58 Answers
HP printer will support only cable with 2 wire in it.
they are designed in such a way. use the cable that came with the printer
Posted on Sep 29, 2009
The fax appears to dial the number successfully. The receiving fax is turned on. It apprears to try for a long time. The error report says "no answer."
It is not your fax line is the other party.did you try any other number?
Post back.
Solution one: Perform a fax line test Perform a fax line test to check whether the fax line is properly connected. Step one: Run a Fax Test
  1. Press the Setup button (c01395353.jpg ) on the product control panel.
  2. Use the Arrow keys (c01073166.jpg ) to select Service , select Fax Service , select Run Fax Test , and then press OK . The Fax Test prints.
    • If the report passes, try to resend the fax.
    • If the report fails with the message 'Fail - the phone line is not active,' plug the cable into a working telephone jack, and then try to resend the fax.
    • If the report fails with the message 'Fail - the cord is in the wrong port,' continue to 'Step two: Change the cable to the correct port.'
Step two: Change the cable to the correct port Make sure the telephone cable is inserted in the correct port. Remove the cord for the fax line from the port labeled with a telephone, and then insert it into the correct port. Figure 1: Fax portsc01756259.gif Scanner error message The message 'Scanner error ' displays on the product control panel while sending a fax. Solution: Check paper size This product only supports paper less than 381 mm (15 in). Use only letter, A4, or legal sized paper for sending faxes. To send this fax, copy or print the original document onto shorter paper, and then resend.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 10, 2010 | HP Laserjet M1319F Laser Multifunction...
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
Hp photosmart c309a I get error 387 after my first send fax. what shall i do?
there are 3 possible reasons you are getting this error.
First :It could be a bad phone cord connected. try with another phone cord.
Second : the phone cord you are using is 4 wire conductor ( HP printers use 2 wire conductor ) and
3rd : It could be faulty line ( There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.)
Solution : Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Try running the Fax Test from Printer Setup Menu.. Press Setup and under Tools - you will find Run Fax Test - Check which all parameters it did not pass.
Jul 01, 2010 | HP Photosmart Premium C309A All-In-One...
Fax will not work at all. I have reloaded the software, unplugged and replugged everything, talked with HP(they want a fee to talk) When you turn it on, it is a "fax failure" message. Will not send or...
Try to Run Fax Test
Press the Setup button on front panel
Scroll to Tools - Press OK
Choose Run Fax Test - Press OK
It should print the Fax Test Report.. it will list you the possible cause why you are getting Fax Failure..
If it says Hardware Test Failed..do a Reset on the Printer ( Hard Reset )
this will printer reset the settings to Factory default like your rings to answer will change to default, Speed Dial list will be wiped off
Steps to do :
Disconnect the Phone cord from EXT 1 of printer
while the printer is on, Disconnect the power cord from back of printer. While holding the # and 6 Buttons, connect the cord back and release the buttons after 5-6 seconds..
go thru the alignment process and re-align the printer
Connect the Phone cord back and try to Run the Fax Test and check if everything passes in the list.
Jun 25, 2010 | HP OfficeJet 6310 All-in-One Printer...
I have a HP 4315 officejet all in one and it prints fine...but when i try to fax a page it fails every time...why?
Good Day Sir, I have a solution to your problem, hope this will help you.
"HP 4315 officejet fax failed"
solution:
  • Turn off the machine by using the ON button and then unplug the power cord from the back of the machine. After a few seconds, plug the power cord back in and turn the power on.
  • Try to send or receive a test fax.
  • If you are running the test from the Fax Setup Wizard (windows) or Fax Setup Utility(Mac), Make sure the Machine is not busy completing another task, such as receiving a fax or making a copy. Check the display for a message indicating that the machine is busy.If it is busy, wait until it is finished and in the idle state.
  • Make sure you use the phone cord that came with the machine. If you do not use the supplied phone cord to connect from the telephone wall jack to the HP All-in-One, YOU MIGHT NOT BE ABLE TO SEND OR RECEIVE faxes. then after you plug run the test again.
  • If you are using a PHONE SPLITTER, this can cause faxing problems. connect the machine directly to the telephone wall jack.
run the test again to make sure it passes and the machine is ready for faxing.
Goodluck and God bless.
May 22, 2010 | HP Officejet 4315 All-in-One Printer
When i receive fax my fax says line error
You configure you fax program.Such as line type,fax number,or you follow user manual,how can use it?
It is problem setup or configure not problem machine.
Dec 03, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I can send a fax, make copies, but cannot receive a fax on my HPL7590. Help
hi tbacsa02,
this was a solution i posted earlier with someone that has the same problem like yours.
follow this few steps;
first can you try this;
You can test your fax setup to check the status of the device and to make sure it is set up properly for faxing. Perform this test after you have completed setting up the device for faxing. The test does the following:
• Tests the fax hardware
• Verifies the correct type of phone cord is connected to the device
• Checks that the phone cord is plugged into the correct port
• Checks for a dial tone
• Checks for an active phone line
• Tests the status of your phone line connection
The device prints a report with the results of the test. If the test fails, review the report for information on how to fix the problem and rerun the test.
To test fax setup
1. Set up the device for faxing according to your particular home or office setup instructions.
2. Make sure the ink cartridges are installed, and that full-size paper is loaded in the main tray before starting the test.
3. From the device control panel, press Setup.
4. Press right arrow to select Tools, and then press OK.
5. Press right arrow to select Run Fax Test, and then press OK.
The device displays the status of the test on the display and prints a report.
6. Review the report.
• If the test passes and you are still having problems faxing, check the fax
settings listed in the report to verify the settings are correct. A blank or
incorrect fax setting can cause problems faxing.
let me know.
Jan 21, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Fax
To test your fax setup
1 Press Setup.
2 Press 6, and then press 5.
This displays the Tools menu and then selects Run Fax Test.
The HP all-in-one displays the status of the test on the color graphics display and prints a report.
3 Review the report.
– If the test passes and you are still having problems faxing, check the fax
incorrect fax setting can cause faxing problems.
– If the test fails, review the report for information on how to fix any problems
found. For more information, you can also see the next section, The fax test
failed.
4 Press OK to return to the Setup Menu.
Make sure you used the phone cord supplied in the box with your HP all-in-one
to connect to the telephone wall jack. One end of this special 2-wire phone
cord should be connected to the port labeled "1-LINE" on the back of your
HP all-in-one and the other end to your telephone wall jack
This special 2-wire cord is different from the more common 4-wire phone cords
you might already have in your home or office. Check the end of the cord and
compare it to the two types of cords shown below.
If you used the 4-wire phone cord, disconnect it, find the supplied 2-wire cord,
and then connect the 2-wire cord to the port labeled "1-LINE" on the back of
your HP all-in-one. For more information on connecting this phone cord and
setting up your HP all-in-one for faxing, see Fax setup.
information see The phone cord that came with my HP all-in-one is not long
enough.
● Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP all-in-one and check for a dial tone. If you do not
hear a dial tone, contact your telephone company and have them check the
line.
● Other equipment, which uses the same phone line as the HP all-in-one, might
be in use. For example, you cannot use your HP all-in-one for faxing if an
extension phone is off hook, or if you are using your PC modem to send an email
or access the Internet.
● The phone line connection might be noisy. Phone lines with poor sound quality
(noise) can cause faxing problems. Check the sound quality of the phone line
by plugging a phone into the telephone wall jack and listening for static or
other noise. If you hear noise, turn Error Correction Mode (ECM) off and try
faxing again. For information, see Use error correction mode. If the problem
persists, contact your telephone company.
● If you are using a digital subscriber line (DSL) service, make sure that you
have a DSL filter connected or you will not be able to fax successfully. The
DSL filter removes the digital signal and allows your HP all-in-one to
communicate properly with the phone line. Obtain a DSL filter from your DSL
provider. If you already have a DSL filter, make sure it is connected correctly.
Make sure your HP all-in-one is not connected to a telephone wall jack that is
set up for digital phones. To check if your phone line is digital, connect a
regular analog phone to the line and listen for a dial tone. If you do not hear a
normal sounding dial tone, it might be a phone line set up for digital phones.
● If you are using either a private branch exchange (PBX) or an integrated
services digital network (ISDN) converter/terminal adapter, make sure the
HP all-in-one is connected to the port that is designated for fax and phone
use. Also, make sure that the terminal adapter is set to the correct switch type
for your country/region, if possible.
Note that some ISDN systems allow you to configure the ports for specific
phone equipment. For example, you might have assigned one port for
telephone and Group 3 fax and another port for multiple purposes. If you
continue to have problems when connected to the fax/phone port, try using the
port designated for multiple purposes; it might be labeled "multi-combi" or
something similar. For information on setting up your HP all-in-one with a PBX
phone system or ISDN line
you may also refer to the manual for this unit here
if you go there please refer to page 82 of the manual or chapter 10
Aug 02, 2008 | HP Photosmart 2710 All-In-One InkJet...
Our new HP Oficejet Pro L7780 can send faxes but can't receive
First things first, i really want to know how things being setup in your end. Let say for example, from the walljack what is the device connected to it. Or if your using one line for both incoming calls and faxes. Or if your using a DSL also for that same phone number for faxing/incoming calls.
Those are just severa factors that affect your problems. Meanwhile, i cant give you a solution on your issue since i still dont have a clear picture on are the devices connected with each other. ALso, its really advisable that you need to use the telephone cord that came out with the box.
Thank you so much. I remain.
adonscott
Apr 23, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
100 people viewed this question
Seeker5211
Seeker5211
